No console access on Cisco switch
norius
Hello: I recently received an ASA 5505, which I can use as a switch, and I started to learn the switch configuration. but I can't connect swich to console.
I also installed the cisco usb console driver, but still got the same error.
6 Replies 6
  • Does your Serial connection work to *any* other system?
  • You talk about the switch config. Does your login to the ASA on SSH/ASDM work?
  • You mention that you get an error; which error?
Yes this connection confirmed itself by working on other systems.
Don't I need to connect to the console first to configure this switch?
I made a mistake by saying error, sorry please.
Did you power up the ASA with the console connected? Do you see anything?
Did you press return after connecting the cable?
Yes i tried everything. cable works fine. and Power, Status, active leds also light up.
I assume it is a used device. Perhaps the speed was changed to something else. Although you often see "strange characters" on the screen when the speed is wrong, I would also try other speeds, starting with 115200 and testing down.
balaji.bandi
have you tried below Option :
Configure the PC terminal emulation software or terminal for 9600 baud, 8 data bits, no parity, and 1 stop bit.
as per information you confirmed console cable working  - so i suspect the ASA  Console port may be faulty ?
BB
