no mls qos command 7206vxr 12.2
lkadlik
HI,
I do not have the option to run sh mls qos commands. I am trying to look at the cos-map on my 7200 router. The code I am running is
c7200-p-mz.122-25.s9.bin.
I also do not see the mls qos command listed globally and it is not an available command in config t mode.
Any help would be greatly appreciated.
Thank you
vmiller
Level 7
Level 7
Thats more of a layer 3 switch command. 7200 is a router.
Here is a list of the features available on your release:
AAA Broadcast Accounting
AAA DNIS Map for Authorization
AAA Server Group
AAA Server Group Deadtimer
AAA Server Group Enhancements
AAA Server Groups Based on DNIS
ACL - Named ACL Support for Noncontiguous Ports on an Access Control Entry
ACL - Reflexive Access Lists
ACL Sequence Numbering
Additional Vendor-Proprietary RADIUS Attributes
Address Resolution Protocol (ARP)
Answer Supervision Reporting
Any Transport over MPLS (AToM): ATM AAL5 over MPLS (AAL5oMPLS)
Any Transport over MPLS (AToM): Ethernet over MPLS (EoMPLS)
Any Transport over MPLS (AToM): Frame Relay over MPLS (FRoMPLS)
Any Transport over MPLS (AToM): Graceful Restart
Any Transport over MPLS (AToM): HDLC over MPLS (HDLCoMPLS)
Any Transport over MPLS (AToM): Port Mode Cell Relay Support
Any Transport over MPLS (AToM): PPP over MPLS (PPPoMPLS)
ARP Optimization
ATM AAL5 OAM Emulation over L2TPv3
ATM Cell Loss Priority (CLP) Setting
ATM Port Mode Cell Relay over L2TPv3
ATM Port Mode Packed Cell Relay over MPLS
ATM PVC Trap Enhancements for Segment and End AIS/RDI failures
ATM PVC Trap Support
ATM Routed Bridge Encapsulation (RBE)
ATM Single Cell Relay (VC Mode) over L2TPv3
ATM-DXI
AutoInstall Using DHCP for LAN Interfaces
Automatic Protection Switching (APS)
AutoRP Enhancement
BGP
BGP 4
BGP 4 Multipath Support
BGP 4 Prefix Filter and In-bound Route Maps
BGP 4 Soft Config
BGP Conditional Route Injection
BGP Configuration Using Peer Templates
BGP Convergence Optimization
BGP Cost Community
BGP Cost Community Support for EIGRP MPLS VPN PE-CE
BGP Dynamic Update Peer-Groups
BGP Hide Local-Autonomous System
BGP Hybrid CLI Support
BGP Increased Support of Numbered as-path Access Lists to 500
BGP Link Bandwidth
BGP Multipath Load Sharing for Both eBGP and iBGP in an MPLS-VPN
BGP Named Community Lists
BGP Next Hop Propagation
BGP Policy Accounting
BGP Prefix-Based Outbound Route Filtering
BGP Reduction in Transient Memory Usage
BGP Restart Neighbor Session After max-prefix Limit Reached
BGP Route-Map Continue
BGP Route-Map Policy List Support
BGP Soft Reset
BGP Support for Dual AS Configuration for Network AS Migrations
BGP Support for IP Prefix Import from Global Table into a VRF Table
BGP Support for Named Extended Community Lists
BGP Support for Sequenced Entries in Extended Community Lists
BGP Support for TTL Security Check
Bidirectional PIM
Bisync support for synchronous serial port adapters
CDP (Cisco Discovery Protocol) Version 2
CEF Support for IP Routing between IEEE 802.1Q vLANs
CEF Switching for Routed Bridge Encapsulation
CEF/dCEF - Cisco Express Forwarding
CEFv6 Switching for 6to4 Tunnels
CEFv6/dCEFv6 - Cisco Express Forwarding
CGMP - Cisco Group Management Protocol
Challenge Handshake Authentication Protocol (CHAP)
Cisco Multipath Channel+
Class Based Ethernet CoS Matching & Marking (802.1p & ISL CoS)
Class Based Weighted Fair Queuing (CBWFQ)
Class-Based Marking
Class-Based Policing
Class-Based Shaping
CLI String Search
CLNS Support for GRE Tunneling of IPv4 and IPv6
CNS
Commented IP Access List Entries
Committed Access Rate (CAR)
Configurable per ATM-VC Hold Queue size
Configuration Change Notification and Logging
Configuration Replace and Configuration Rollback
Contextual Configuration Diff Utility
Control Plane Policing (CoPP)
Control Plane Policing - Time based
COPS for RSVP
CUG Selection Facility Suppress Option
Custom Queueing (CQ)
Default Passive Interface
DHCP Client
DHCP Proxy Client
DHCP Relay Agent Support for Unnumbered Interfaces
DHCP Server
DHCP Server Options - Import and Autoconfiguration
Dial Backup
Dial-on-demand
Dialer Idle Timer Inbound Traffic Configuration
Dialer Profiles
Dialer Watch
Diffserv Compliant WRED
DLR Enhancements: PGM RFC-3208 Compliance
DNS based X.25 routing
Double Authentication
DRP Server Agent
Dynamic Bandwidth Change for ATM PVCs
Dynamic Multiple Encapsulation for Dial-in over ISDN
EGP
EIGRP Stub Routing
Embedded Event Manager (EEM) 2.0
Embedded Syslog Manager (ESM)
Enhanced ATM VC Configuration and Management
Enhanced IGRP (EIGRP)
Enhanced Local Management Interface (ELMI)
Enhanced Password Security
Extended ACL support for IGMP to support SSM in IPv4
Fast Fragmentation (Fast-Switched Fragmented IP Packets)
FHRP - Enhanced Object Tracking of IP SLAs
FHRP - HSRP - Hot Standby Router Protocol V2
Flow-Based WRED
Frame Relay
Frame Relay ELMI Address Registration
Frame Relay Encapsulation
Frame Relay End-to-End Keepalive
Frame Relay Fragmentation (FRF.12)
Frame Relay Fragmentation with Hardware Compression
Frame Relay FRF.1.2 Annex A Support.
Frame Relay FRF.9 Payload Compression
Frame Relay PVC Interface Priority Queueing
Frame Relay Queuing and Fragmentation at the Interface
Frame Relay Router ForeSight
Frame Relay Switching
Frame Relay Switching Diagnostics and Troubleshooting
Frame Relay Switching Enhancements: Shaping and Policing
Frame Relay Traffic Shaping (FRTS)
FTP Support for Downloading Software Images
Generic Routing Encapsulation (GRE)
Generic Traffic Shaping (GTS)
Half bridge/half router for CPP and PPP
HSRP support for ICMP Redirects
HSRP support for MPLS VPNs
HTTP Security
IEEE 802.1Q VLAN Support
IGMP State Limit
IGMP Version 1
IGMP Version 2
IGMP Version 3
IGMP Version 3 - Explicit Tracking of Hosts, Groups, and Channels
Image Verification
Integrated routing and bridging (IRB)
Interface Index Persistence
Interface Range Specification
Internet Protocol Control Protocol (IPCP) address negotiation
Inverse Multiplexing over ATM (IMA)
IP DSCP marking for Frame-Relay PVC
IP Enhanced IGRP Route Authentication
IP Event Dampening
IP Multilayer Switching (IP MLS)
IP Named Access Control List
IP over CLNS tunnel
IP Precedence Accounting
IP Precedence for GRE Tunnels
IP Routing
IP SLAs - Distribution of Statistics
IP SLAs - DLSW+ Operation
IP SLAs - DNS Operation
IP SLAs - FTP Operation
IP SLAs - History Statistics
IP SLAs - HTTP Operation
IP SLAs - ICMP Path Echo Operation
IP SLAs - Multi Operation Scheduler
IP SLAs - One Way Measurement
IP SLAs - Reaction Threshold
IP SLAs - Scheduler
IP SLAs - SNA LU2 Echo
IP SLAs - SNMP Support
IP SLAs - TCP Connect Operation
IP SLAs - UDP Echo Operation
IP SLAs - UDP Jitter Operation
IP Summary Address for RIPv2
IP to ATM CoS, per-VC WFQ and CBWFQ
IP-to-ATM CoS
IPv6 (Internet Protocol Version 6)
IPv6 Bidirectional PIM
IPv6 Data Link: VLANs using Cisco Inter-Switch Link (ISL)
IPv6 Data Link: VLANs using IEEE 802.1Q Encapsulation
IPv6 MTU Path Discovery
IPv6 Multicast: Address Family Support for Multiprotocol BGP
IPv6 Multicast: Bootstrap Router (BSR)
IPv6 Multicast: Explicit Tracking of Receivers
IPv6 Multicast: MLD Access Group
IPv6 Multicast: Multicast Listener Discovery (MLD) Protocol, Versions 1 and 2
IPv6 Multicast: PIM Accept Register
IPv6 Multicast: PIM Embedded RP Support
IPv6 Multicast: PIM Source-Specific Multicast (PIM-SSM)
IPv6 Multicast: PIM Sparse Mode (PIM-SM)
IPv6 Multicast: Routable Address Hello Option
IPv6 Multicast: RPF Flooding of Bootstrap Router (BSR) Packets
IPv6 Multicast: Scope Boundaries
IPv6 Neighbor Discovery
IPv6 Routing: IS-IS Multitopology Support for IPv6
IPv6 Routing: IS-IS Support for IPv6
IPv6 Routing: Multiprotocol BGP Extensions for IPv6
IPv6 Routing: Multiprotocol BGP Link-local Address Peering
IPv6 Routing: OSPF for IPv6 (OSPFv3)
IPv6 Routing: RIP for IPv6 (RIPng)
IPv6 Routing: Route Redistribution
IPv6 Routing: Static Routing
IPv6 Services: AAAA DNS Lookups over an IPv4 Transport
IPv6 Services: Cisco Discovery Protocol (CDP) - IPv6 Address Family Support for Neighbor Information
IPv6 Services: DNS Lookups over an IPv6 Transport
IPv6 Services: Extended Access Control Lists
IPv6 Services: Standard Access Control Lists
IPv6 Stateless Auto-configuration
IPv6 Switching: CEF/dCEF Support
IPv6 Switching: CEFv6 Switched Automatic IPv4-compatible Tunnels
IPv6 Switching: CEFv6 Switched Configured IPv6 over IPv4 Tunnels
IPv6 Switching: CEFv6 Switched ISATAP Tunnels
IPv6 Tunneling: Automatic 6to4 Tunnels
IPv6 Tunneling: Automatic IPv4-compatible Tunnels
IPv6 Tunneling: IPv6 over IPv4 GRE Tunnels
IPv6 Tunneling: ISATAP Tunnel Support
IPv6 Tunneling: Manually Configured IPv6 over IPv4 Tunnels
IPv6: Anycast Address
IPv6: ICMPv6
IPv6: ICMPv6 Redirect
IPv6: Neighbor Discovery Duplicate Address Detection
IS-IS Caching of Redistributed Routes
IS-IS HMAC-MD5 Authentication
IS-IS Incremental Shortest Path First (i-SPF) Support
IS-IS Limit on Number of Redistributed Routes
IS-IS Mechanism to Exclude Connected IP Prefix from LSP Advertisements
IS-IS Multiarea Support
IS-IS Support for IP Route Tags
IS-IS Support for Priority-Driven IP Prefix RIB Installation
ISDN
ISIS
ISO CLNS
Layer 2 Local Switching - ATM to Ethernet
Layer 2 Local Switching - ATM to Frame Relay (FR) with Interworking
Link Fragmentation and Interleaving (LFI) for Frame Relay and ATM Virtual Circuits
Loadsharing IP packets over more than six parallel paths
Lock and Key
Low Latency Queueing (LLQ)
Low Latency Queueing (LLQ) for Frame Relay
Memory Threshold Notifications
Message Banners for AAA Authentication
MGCP - Media Gateway Control Protocol
MLPPP - Multilink PPP
Modular QoS CLI (MQC)
MPLS (Multiprotocol Label Switching)
MPLS Class of Service (CoS) Enhancements
MPLS Diff-Serv-Aware Traffic Engineering (DS-TE)
MPLS Egress NetFlow Accounting
MPLS EM - MPLS TE MIB Trap Notifications
MPLS Label Switch Controller (LSC) and Enhancements
MPLS LDP - Label Distribution Protocol (LDP)
MPLS LDP - MIB Notifications
MPLS Traceroute
MPLS Traffic Engineering (TE)
MPLS Traffic Engineering (TE) - Automatic bandwidth adjustment for TE tunnels
MPLS Traffic Engineering (TE) - Configurable Path Calculation Metric for Tunnels
MPLS Traffic Engineering (TE) - Interarea Tunnels
MPLS Traffic Engineering (TE) - IP Explicit Address Exclusion
MPLS Traffic Engineering (TE) - OSPF Support
MPLS Traffic Engineering (TE) - Scalability Enhancements
MPLS Traffic Engineering Forwarding Adjacency
MPLS VPN - Inter-Autonomous System Support
MPLS VPN - OSPF PE-CE Support
MPLS VPN - VRF Selection based on Source IP Address
MPLS VPN Carrier Supporting Carrier
MPLS VPN Carrier Supporting Carrier - IPv4 BGP Label Distribution
MPLS VPN ID
MPLS VPN Inter-AS - IPv4 BGP Label Distribution
MSDP compliance with IETF RFC 3618
Multi-protocol BGP (MP-BGP) - MPLS VPN
Multicast BGP (MBGP)
Multicast Fast Switching Performance Improvement
Multicast Routing Monitor (MRM)
Multicast Source Discovery Protocol (MSDP)
Multicast-VPN: Multicast Support for MPLS VPN
Named Method Lists for AAA Authorization and Accounting
NBAR - Network-based Application Recognition
NetFlow
NetFlow Aggregation
NetFlow Export of BGP Nexthop Information
Netflow Input Filters and Multi-Sampling rates
Network Services Engine (NSE)
Network Time Protocol (NTP)
Next Hop Resolution Protocol (NHRP)
NSF Awareness - EIGRP
On Demand Routing (ODR)
OSPF
OSPF Area Transit Capability
OSPF Flooding Reduction
OSPF Forwarding Address Suppression in Translated Type-5 LSAs
OSPF Inbound Filtering using Route Maps with a Distribute List
OSPF Incremental Shortest Path First (i-SPF) Support
OSPF Limit on Number of Redistributed Routes
OSPF Link State Database Overload Protection
OSPF Link-local Signaling (LLS) Per Interface Basis
OSPF MIB Support of RFC 1850 and Latest Extensions
OSPF Not-So-Stubby Areas (NSSA)
OSPF On Demand Circuit (RFC 1793)
OSPF Packet Pacing
OSPF Sham-Link Support for MPLS VPN
OSPF Shortest Paths First Throttling
OSPF Support for Fast Hellos
OSPF Support for Forwarding Adjacencies over MPLS Traffic Engineered Tunnels
OSPF Support for Link State Advertisement (LSA) Throttling
OSPF Support for Multi-VRF on CE Routers
OSPF Support for Unlimited Software VRFs per Provider Edge (PE) Router
OSPF Update Packet-Pacing Configurable Timers
PAD Subaddressing
Parse Bookmarks
Parser Cache
Password Authentication Protocol (PAP)
PBR Support for Multiple Tracking Options
Per-User Configuration
Per-VC queuing for ATM
Performance Enhancements for IOS ACL
PIM Dense Mode State Refresh
PIM MIB Extension for IP Multicast
PIM Multicast Scalability
PIM Version 1
PIM Version 2
Policy-Based Routing (PBR)
PPP
PPP over ATM
PPP over ATM (IETF-Compliant)
PPP over ATM SVCs
PPP over Frame Relay
Priority Queueing (PQ)
PSTN Fallback
QoS Device Manager (QDM)
QoS for Virtual Private Networks
QoS Packet Marking
QoS Policy Propagation via Border Gateway Protocol (QPPB)
QSIG Protocol Support
RADIUS
RADIUS Attribute 44 (Accounting Session ID) in Access Requests
RADIUS for Multiple User Datagram Protocol Ports
Random Early Detection (RED)
Response Time Reporter (RTR)
Response Time Reporter (RTR) enhancements
RGMP - Router-Port Group Management Protocol
RIP
RMON events and alarms
Router Security Audit Manageability
RSVP - Resource Reservation Protocol
RSVP Refresh Reduction and Reliable Messaging
RSVP Support for Frame Relay
RSVP support for LLQ
RTP Header Compression
RTP Header Compression over Satellite Links
Selective Packet Discard (SPD)
Selective Virtual-Access Interface Creation
SGCP
Silent Operation Mode
Single Rate 3-Color Marker for Traffic Policing
Snapshot routing
SNMP (Simple Network Management Protocol)
SNMP Inform Request
SNMP Manager
SNMP Support for IOS vLAN Subinterfaces
SNMPv2C
SNMPv3 (SNMP Version 3)
Source Specific Multicast (SSM) - IGMPv3,IGMP v3lite, and URD
Source Specific Multicast (SSM) Mapping
Spanning Tree Protocol (STP)
Spanning Tree Protocol (STP) Extension
SRB - Source Route Bridging Enhancements
Standard IP Access List Logging
Subnetwork Bandwidth Manager (SBM)
Suppress BGP Advertisement for Inactive Routes
Switched Multimegabit Data Service (SMDS)
T.38 Fax Relay for VoIP H.323
Tacacs SENDAUTH function
Tacacs Single Connection
TCP Intercept
Time-Based Access Lists
Time-Based Access Lists Using Time Ranges(ACL)
TN3270 LU Nailing
TN3270 Server
TN3270 Server (CIP only)
TN3270 Server Connectivity Enhancements
TO BE DELETED from JFIT-jrider18
Transparent Bridging
Transparent CCS and Frame Forwarding Enhancements
Transparent Common Channel Signaling (T-CCS)
Triggered RIP
Tunnel Type of Service (TOS)
Turbo Access Control Lists
Turbo Flooding of UDP Datagrams
UDI - Unique Device Identifier
Uni-Directional Link Routing (UDLR)
Unicast Reverse Path Forwarding (uRPF)
User Maximum Links
Virtual Interface Template Service
Virtual Profile CEF Switched
Virtual Profiles
Warm Reload
WCCP Redirection on Inbound Interfaces
WCCP Version 1
WCCP Version 2
Weighted Fair Queueing (WFQ)
Weighted RED (WRED)
x Digital Subscriber Line (xDSL) Bridge Support
X.25
X.25 Calling Address Insertion and Removal Based on Input Interface
X.25 Closed User Group
X.25 Failover
X.25 over Frame Relay (Annex G)
X.25 over TCP (XOT)
X.25 Switch Local Acknowledgement
X.25 Switching between PVCs and SVCs
