no mop enabled command on ASR 1002-X
gbenoit83
I am configuring an ASR 1002-X router and wanted to enter the no enable mop command. I see there is not a command. Does the ASR 1002-X not have this feature? Is it already disabled by default on the latest IOS? Does it have to be enabled inorder to issue the no enable mop command?
Reza Sharifi
The command only exist under interface and not globally.
I tried the no mop enable command per interface with no success. That command is not available on the ASR. Is there another command that disables it?
did you find a solution for this?
