Stack members come up with default port configurations after reboot
Wesker
Hi, we have stack of 3 switches, and when switch 1, which is master, reboots: whole stack is rebooted and then switch 2 & 3 come up with default port configuration, switch 1 has all configuration correct(so we have to configure ports on 2 & 3 each time after reboot).
(I did hide last two bytes of MAC addresses):
#show switch
Switch/Stack Mac Address : 4014.82aa.1180 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 4014.82aa.xxxx 15 V07 Ready
2 Standby 6c03.b5c5.xxxx 10 V07 Ready
3 Member 4014.82a9.xxxx 1 V07 Ready
#show version
Switch Ports Model SW Version SW Image Mode
* 1 65 C9300-48T 17.09.03 CAT9K_IOSXE INSTALL
2 65 C9300-48T 17.09.03 CAT9K_IOSXE INSTALL
3 65 C9300-48T 17.09.03 CAT9K_IOSXE INSTALL
I've noticed those log messages:
%HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
"Bulk Sync Succeed" seem like means that configuration from master actually synced to switch 2 & 3 but in fact it does not happen?
Tris message comes up as well:
%RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
13 Replies 13
Reza Sharifi
Can you post the output of "sh ver" from all 3 switches?
Hide the S/N
Wesker
>sh version
Cisco IOS XE Software, Version 17.09.03
Cisco IOS Software [Cupertino], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.9.3, RELEASE SOFTWARE (fc6)
Copyright (c) 1986-2023 by Cisco Systems, Inc.
Compiled Tue 14-Mar-23 18:26 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2023 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.9.2r, RELEASE SOFTWARE (P)
xxxxxx uptime is 2 days, 20 hours, 27 minutes
Uptime for this control processor is 2 days, 20 hours, 29 minutes
System returned to ROM by stack merge due to incompatiblity at 22:15:42 UTC Tue Oct 17 2023
System restarted at 01:02:21 UTC Tue Nov 7 2023
System image file is "flash:packages.conf"
Last reload reason: stack merge due to incompatiblity
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
AIR License Level: AIR DNA Advantage
Smart Licensing Status: Smart Licensing Using Policy
cisco C9300-48T (X86) processor with 1309193K/6147K bytes of memory.
Processor board ID FVH2725L3M5
1 Virtual Ethernet interface
156 Gigabit Ethernet interfaces
24 Ten Gigabit Ethernet interfaces
6 TwentyFive Gigabit Ethernet interfaces
6 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
1638400K bytes of Crash Files at crashinfo-2:.
1638400K bytes of Crash Files at crashinfo-3:.
11264000K bytes of Flash at flash:.
11264000K bytes of Flash at flash-2:.
11264000K bytes of Flash at flash-3:.
Base Ethernet MAC Address : 40:14:82:xx:xx:xx
Motherboard Assembly Number : 73-19915-04
Motherboard Serial Number : xxxx
Model Revision Number : A0
Motherboard Revision Number : B0
Model Number : C9300-48T
System Serial Number : xxx
CLEI Code Number : INM2900ARG
Switch 02
Switch uptime : 2 days, 20 hours, 29 minutes
Base Ethernet MAC Address : 6c:03:b5:xx:xx:xx
System Serial Number : xxxx
Last reload reason : NOT ACCESSABLE
Switch 03
System Serial Number : FVH2725L1JQ
Wesker
I see that switch #1 reload reason is this:
"Last reload reason: stack merge due to incompatiblity"
But I've read that this is same as just "stack merge" .
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300l-switch-stack/218083-troubleshoot-catalyst-9200-9300-reloads.html
show version should show the config register. example;
Configuration register is 0x102
but I don't see it in your output
Wesker
#show boot system
Switch 1
Current Boot Variables:
BOOT variable = flash:packages.conf;
Boot Variables on next reload:
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
Switch 2
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
Switch 3
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
The boot variables look good. What is the config-register number?
Wesker
I've noticed those two differences between no issue stack and with this issue:
WITH ISSUE:
#sh boot
Switch 1
BOOT variable = flash:packages.conf;    ////////////HERE
NO ISSUE:
#sh boot system
Switch 1
BOOT variable does not exist    ///// SO THIS STACK HAS nO PROBLEM  ATER RELOAD
and also this:
NO ISSUE STACK switch 1
#show romvar
ROMMON variables for Active Switch
ABNORMAL_RESET_COUNT=0
AUTO_SWITCH_CONSOLE_DISABLE=0
BAUD=9600
BOARDID=24661
BOOT=flash:packages.conf
BOOTLDR=
BSI=0
CONFIG_FILE=
CONSOLE_MIRRORING_DISABLE=0
DC_COPY=yes                                          /////////////////HERE
IMAGE_UPGRADE=no
NO ISSUE STACK :
show romvar switch 2
NOTE: Variables are updated on reboot.
ROMMON variables for Switch 2
ABNORMAL_RESET_COUNT=1
BAUD=9600
BOARDID=24661
BOOTLDR=
BSI=0
CONFIG_FILE=
DC_COPY=yes                    // switch #2 from stack still has this
IMAGE_UPGRADE=no
STACK WITH ISSUE
#sh romvar switch 1
BAUD=9600
BOARDID=28757
BOOT=flash:packages.conf;
BSI=0
DC_COPY=yes                                       //HAS
IMAGE_UPGRADE=no
sh romvar switch 2
BAUD=9600
BOARDID=28757
BOOTLDR=
BSI=0
CONFIG_FILE=                                          ///MISSING DC_COPY=yes
IMAGE_UPGRADE=no
Wesker
  1. sh run all | i service
no issue stack has:
service call-home
issue stack:
no service call-home
Leo Laohoo
Wait, let me get this straight ...
Switch 1 ports have config, however, Switches 2 & 3 ports have no config.  Is this correct?
If this is so, then did someone configure the ports of Switch 2 & 3 at all?
"Switch 1 ports have config, however, Switches 2 & 3 ports have no config.  Is this correct? "
Correct, I do configure all ports on 1/0/1..., 2/0/1.., 3/0/1...  and after reloading Master switch 1config stays only on 1/0/x.
( may be same happens if switches 2 or 3 are rebooted, did not try because of it is in production)
seem like 9300 can not display  conf register as it not used anymore:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
I could try :
(config)#no system ignore startupconfig   : but  there is no  "startupconfig" word in running configuration, so not sure if this will work
Alright, let's try a little experiment.  Do the following:
conf t
 interface range Gi2/0/1-48, Gi3/0/1-48
 description BOOOOOOOOO!
 SHUTDOWN
end
wr
And then reboot the entire stack.
Thank you very your responses, but next  maintenance window(seem like) in 2-3 weeks, so i will collect things and try it at once...
Wesker
I have another stack of two switches for lab purposes:
#sh romvar switch 2
those two fields are present on lab stack switch #2 and absent on problem stack switch #2:
DC_COPY=yes
LICENSE_BOOT_LEVEL=network-essentials,all:C9300_48P;
For testing purposes, I've configured
(config)#system ignore startupconfig on lab switch
and then this field appeared in:
#sh romvar switch 2
SWITCH_IGNORE_STARTUP_CFG=1
then I did reload lab stack, but configuration persisted on all elements...
