No passive interface command
dbuckley77
Level 5
Level 5
I saw this command amongst some OSPF config commands.
What does it do?
no passive-interface Vlan2
Reza Sharifi
Most likely there is default passive interface for all the other interfaces in the same area of OSPF configs.  So,"no passive-interface vlan2" means that the OSPF peering is over vlan 2 with the neighboring router.
more info:
In Open Shortest Path First (OSPF), hello packets are not sent on an interface that is specified as passive. Hence, the device is not able to discover any neighbors, and none of the OSPF neighbors are able to see the device on that network. In effect, this interface appears as a stub network to the OSPF domain. This configuration is useful if you want to import routes associated with a connected network into the OSPF domain without any OSPF activity on that interface.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/xe-3s/iri-xe-3s-book/iri-default-passive-interface.html#GUID-AE734874-728B-48D8-AC8D-14C74910DB5A
Reza Sharifi
more info:
chesgreen
Frequent Visitor
Frequent Visitor
I would like to add the "no passive-interface" command to a device at a remote site in production during a "patch/upgrade" night. Usual patches are done remotely, but I am in fear of loosing connectivity to the device. Would it be safe to enter this command remotely or should i commit it onsite?
