No switchport: command rejected, not allowed on this interface(3560X)
sean chang
I got great help from experts here, so I just keep asking for help on our new catalyst 3560X switch(12.2(58)SE1).
Purpose: Intervlan routing,
actions taken:  I created Vlan10 with 10.10.1.1/24; vlan20 with 10.20.1.1/24 on this new switch, IP routing enabled, Vlan 1 is 10.1.10.2/24  for management
Problem: on a new port ( unconfigured 😞
>interface GigabitEthernet0/24
>no switchport
I have googled a while but couldn't firgured out why this command is rejected, what should I prepare the port before I can run "no switchport"?
Any suggestions and advises are greatly appreciated.
  Please post "show version" , "show license detail" and "show run interface g0/24".
HTH,
Toshi
15 Replies 15
HTH,
Toshi
thanks, Toshi,
so now I think it's a license problem? becuase I upgraded the IOS, it's now lanbase (before it's IPbase).........
>show ver
License Level: lanbase
License Type: Default. No valid license found.
Next reload license Level: lanbase
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1420P11G
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 58:8D:09:97:6C:80
Motherboard assembly number     : 73-12554-04
Motherboard serial number       : FDO14400EPJ
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3560X-24T-S
Daughterboard assembly number   : 800-32786-01
Daughterboard serial number     : FDO14390K7N
System serial number            : FDO1420P11G
Top Assembly Part Number        : 800-31331-01
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : COMJU00ARA
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       12.2(58)SE1           C3560E-IPBASEK9-M
   You got it.
Routed Ports
A routed port is a physical port that acts like a port on a router; it  does not have to be connected to a router. A routed port is not  associated with a particular VLAN, as is an access port. A routed port  behaves like a regular router interface, except that it does not support  VLAN subinterfaces. Routed ports can be configured with a Layer 3  routing protocol. A routed port is a Layer 3 interface only and does not  support Layer 2 protocols, such as DTP and STP.
Note : Routed ports are not supported on switches running the LAN base feature set.
Many Thanks
Toshi
Hi guys,
I have the same problem. What license is needed to use the "routed ports" function on my
WS-C3560X-48?
Do you also know roughy the cost?
I expected this function to be included when I bought a Layer3 swich.
Dario
Hello Dario, you will need an ip base license at minimum I think. You should have had the option to purchase the switch with the license. If no license was requested they just ship out a basic LAN license with the switch. Please contact your reseller for a quote on a suitable license for you, I'm not entirely sure what they cost.
They should also be able to advise you on which license you need for any requirements you may have.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi Bilal,
Here below my version. What is the code of the upgrade to buy? I need to route 5 VLANS.
From the output of the command, it looks like my license is lanbase but my image is IPBASE.
Dario
Cisco IOS Software, C3560E Software (C3560E-IPBASEK9-M), Version 15.0(1)SE2, REL        EASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 22-Dec-11 00:15 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTW        ARE (fc1)
SWCORE01 uptime is 3 weeks, 4 days, 4 hours, 48 minutes
System restarted at 08:39:26 AWST Fri Apr 5 2013
System image file is "flash:c3560e-ipbasek9-mz.150-1.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Permanent
cisco WS-C3560X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
*    1 54    WS-C3560X-48       15.0(1)SE2            C3560E-IPBASEK9-M
Hello Dario, the output shows you are on a LAN base feature set even though you have software supporting ip base.
Can you do a 'show license udi' please?
You will just need the ip base licence to accomplish what you want to do.
Here the output of the command:
show license udi
Device#   PID                   SN              UDI
*0        WS-C3560X-48T-L       FDO1605K35A     WS-C3560X-48T-L:FDO1605K35A
Do you mean that I have to buy a license called "ip base" and it does not require any IOS upgrade?
Dario
Yes Dario, correct
Please see here: http://www.cisco.com/en/US/products/ps10744/prod_models_comparison.html
The IP Services feature set is available as an upgrade option at the time of ordering or through a license at a later time.
Hope this helps
Thanks Bilal for your support.
Good Job! Bill
5-Point
Toshi
CCIE
You're welcome Dario, any time 🙂
Thanks Toshi! Hope this can help others too.
Same to my problem. There is other way for this? Iwant to put ip inside my interface
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 05-Apr-18 02:22 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
CoreSwitch2 uptime is 11 minutes
System image file is "flash:c3750e-universalk9-mz.152-4.E6.bin"
Last reload reason: Reload command
export@cisco.com.
cisco WS-C3750X-48P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1808Z1YU
21 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
Base ethernet MAC Address       : 74:26:AC:C5:79:00
Motherboard assembly number     : 73-12553-11
Motherboard serial number       : FDO180902AD
Model number                    : WS-C3750X-48PF-L
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO18081KQX
System serial number            : FDO1808Z1YU
Top Assembly Part Number        : 800-31324-09
Top Assembly Revision Number    : B0
Version ID                      : V06
CLEI Code Number                : CMMPS00DRA
Hardware Board Revision Number  : 0x05
*    2 54    WS-C3750X-48P             15.2(4)E6             C3750E-UNIVERSALK9-M
Configuration register is 0x
The only solution for this, is to buy ah license or use svi for assigning ip address on the interface?
