No traffic on SPAN port
slicerpro
I have configuration for our client's IDS as follows:
show monitor session all
Session 1
Type : Local Session
Source Ports :
Both : Gi1/0/21
Destination Ports : Gi1/0/10
Encapsulation : Native
Ingress : Disabled
Session 2
Source Ports :
Both : Gi1/0/21
Destination Ports : Gi1/0/5
Ingress : Disabled
The first session was configured years ago, the second one is the new one. We are trying to migrate to new IDS systems and so we configured the second session. Problem is the second one shows 0 traffic. Upon further investigation, I found out that the first one has been broke for a while as well ...no one knows how long. I have scratched my to no avail.
Here are the port configurations:
show run int Gi1/0/21
Building configuration...
Current configuration : 220 bytes
interface GigabitEthernet1/0/21
description FW01-Gi0/1
switchport trunk allowed vlan 1400-1403,1405-1413,4024
switchport mode trunk
spanning-tree guard loop
end
show run int Gi1/0/10
Current configuration : 95 bytes
interface GigabitEthernet1/0/10
description IDS01-monitor
switchport mode access
end
show run int Gi1/0/5
interface GigabitEthernet1/0/5
description IDS02-monitor
end
I would also like to point out that the interface counters on the destination ports all show 0s ..so no point checking the IDS machine if nothing is being sent that way. There is traffic on the source interface though.
WE are running a  WS-C3750E-48TD-S on 15.0(1)SE. Any insight will be highly appreciated. Let me know if you need more information.
6 Replies 6
Dennis Mink
what does the config look like in relation to the SPAN session
Have you got SPAN working any where at all?
Test it first with a test access port and run wireshark  on the the destination port.
Please remember to rate useful posts, by clicking on the stars below.
Thanks Dennis for your reply. I'm not clear on how you want me to test with test access port. Do you mean configure a different dst port for testing?
correct, a completely different pair of source and destination ports. at least establish if span works at all.
gotcha.. I will report back.
The port you are trying to span is a trunk.
Can you re-test using below
no monitor session 2
monitor session 2 source interface gigabitethernet1/0/21
monitor session 2 destination interface gigabitethernet1/0/5 encapsulation replicate
Alex
Regards, Alex. Please rate useful posts.
I changed the configuration so that the source is the vlans instead of the physical port and now its working
