Problem to access http to other host on a vlan
khhhhhhhh957
My problem is this
I can ping hosts from another vlan but I can't access their web interface. Do you have any idea of ​​the problem ?
Thank you very much and good day !
8 Replies 8
mattjones03
Just looking at the router configuration provided;
It would seem that your PBR is setting the next hop for http and https traffic to 217.23.30.105.
I would suggest that you place a deny statement into the "DATA" ACL, specifying the source and destination networks that you do not want the PBR to take action on.
ip access-list extended DATA
deny tcp <source network> <wildcard> <destination network> <wildcard> eq www 443
permit tcp 192.168.0.0 0.0.0.255 any eq www 443
Thank you for your answer, but it still doesn't work. Since the network 192.168.0.0, I can ping the network 192.168.20.0 but I can not access a http address of the network 192.168.20.0.
Thank you and good day
Just to confirm, did you add both the 192.168.0.0/24 and 192.168.20.0/24 into the DATA ACL?
This is my ACL :
   permit tcp 192.168.20.0 0.0.0.255 any eq www 443
ip access-list extended VOIP
Your ACL is incorrect.
It should be;
deny tcp 192.168.0.0 0.0.0.255 <host> eq www
deny tcp 192.168.20.0 0.0.0.255 <host> eq www
* Replace <host> with the IP address of the host in which HTTP isn't working.
Thank you for your help, but sorry, but it still does not work.
Here is my ACL :
deny tcp 192.168.0.0 0.0.0.255 host 192.168.20.13 eq www 443
deny tcp 192.168.20.0 0.0.0.255 host 192.168.20.13 eq www 443
HI, I have found the solution with this :
permit tcp 192.168.0.0 0.0.0.255 host 192.168.20.13 eq www 443
ip access-list extended LAN
permit tcp 192.168.0.0 0.0.0.255 192.168.20.0 0.0.0.255 eq www 443
route-map PBR permit 0
match ip address LAN
set ip next-hop 192.168.20.1
route-map PBR permit 10
match ip address DATA
set ip next-hop 217.11.40.105
route-map PBR permit 20
match ip address VOIP
set ip next-hop 192.168.1.1
What do you think of my solution ?
Perfect,
Glad you managed to resolve that.
