No web access since using VLAN (SGE2000)
Guillaume47
Using one SGE2000 switch.
I'm unable to access the switch web interface since I assigned a PVID to the port where my computer is connected.
If I use the PVID 1 and untagging the VLAN 1, it works fine.
What can I do to access the web interface with another VLAN ?
microfeel
1. add vlan, for example with id 2.
2. add ip address in vlan 2.
3. port which connected to your computer must be vlan 2 native mode acces, all trafic trought out from this port will untaged.
use command
switchport mode access
or
encapsulation dot1q 2 native
I missed the "Management VLAN" option in the "IPv4 Interface" page. Now it's fine !
Thanks.
