6509 running in VSS upgrade issue - GOLD EEM TCL policy
Hello Guys,
I've upgraded a 6509 switches wich are running in  VSS, from IOS 12.2 (33)SHI1 to 12.2 (33)SHI5. After that I'm facing the folowing log messages periodically.
001867: Feb 15 2011 09:21:52.097 GMT-2: %HA_EM-6-LOG: Mandatory.go_unusedportlpbk.tcl: GOLD EEM TCL policy for TestUnusedPortLoopback
001868: Feb 15 09:21:51.641 GMT-2: %CONST_DIAG-SW1_SPSTBY-3-HM_PORT_TEST_FAIL: Switch 1 Module 6 TestUnusedPortLoopback Port(s)[24] failed. System operation continues.
I know that this is a diagnostic result from TestUnusedPortLoopback feature. But this interface is disabled (shutdown). I didn't found any bug refered to this situation.
I'll be so thankful if anybody can help me to find an answer.
Yogesh Ramdoss
Paulo,
First, I am not aware of any software defects.
As test name suggests, GOLD will test unused ports at regular interval.
Are you seeing this error reported only for 1/6/24, or some other ports also ?
If it is only for 1/6/24, then is it the first unused port in that module ?
Please let me know the results, if module re-seat has been done earlier.
- Yogesh
5 Replies 5
Yogesh Ramdoss
Paulo,
- Yogesh
Hello Yogesh,
That's right! The error report refered only to 1/6/24 interface. And shuting/no shuting stoped the messages.
Thanks a lot for your help.
I am also facing the same logs, is there any reason why GOLD test is failing for unused port ?
%CONST_DIAG-SP-3-HM_PORT_TEST_FAIL: Module 8 TestUnusedPortLoopback Port(s)[2] failed. System operation continues.
Akhtar
Hello Akhtar,
Is this seen in VSS setup or Standalone Cat6500 switch ?
Did you notice this error immediately after Sup failover ? or under steady-state operation condition ?
Please let me know the IOS version the cat6500 switch is running.
Yogesh
Hi Yogesh,
Its standalone setup and there has been no Sup failover. The IOS running is 12.2.33(SXH2a).
Akhtar
