Non-Cisco switch between Cisco switches and VTP protocol
eeebbunee
Hello Professional,
I know VTP is Cisco exclusive protocol, but not sure how it works.
For example, If my network infrastructure as like this:
  <<C3750X - Core switch>> -- <<PFSense Firewall>> -- <<Unifi Switch>> -- <<Cisco 2960X>>
Can Cisco 2960X switch got update (VTP) from C3750X?
or Cisco 2960X won't get any update?
balaji.bandi
VTP no that will not be going to work, it required L2 connectivity.
BB
if your FW can do Bridge between two link then I think you can bypass the FW.
otherwise since VTP is L2 protool it will not pass.
Thank you for the response,
If I can add in detail, actually, PFsense firewall is configured as a bridge mode.
so,
  <<C3750X - 코어 스위치>> -- <<PFSense 방화벽>> -- <<Cisco 2960X>> : VTP update Works
  <<C3750X - 코어 스위치>> -- <<PFSense 방화벽>> -- <<Unifi 스위치>> -- <<Cisco 2960X>> : Not Works
In this case, considering that *Unifi switch (L2) can't recognize VTP update.* makes sense?
Otherwise, is there any other reason that I keep failing VTP update?
 - VTP configure is same with other L2 switches (VTP version, VTP Password..)
 - MD5 digest does not match ever since I change the connection to be firewall - unifi switch - C2960 switch.
Thank you Sir.
I think because Unifi can not deal with multicast L2 address of VTP frame.
can check see if Unifi see cisco SW as neighbor via CDP, because as I know both VTP and CDP use same Multicast L2 address.
