Non-standard wildcard masks for ACLs
John Blakley
Okay....I've been avoiding this post like the plague, but I still don't think that I have a real good grasp on this so here it goes:
Let's say that I want to allow 192.168.16.52 and 192.168.19.56 networks access to telnet. There are network 192.168.3.0 - 15.0 in between. Aside from allowing the 2 subnets specifically, I want to create a mask that allows the 2 only.
192.168.16.52
192.168.19.56
16 = 3rd octet = 00010000
19 = 3rd octet = 00010011
52 = 00110100
56 = 00111000
So, my acl would look like:
access-list permit tcp 192.168.16.0 0.0.15.?
I've found extreme examples from INE that state to AND the 2 addresses and then XOR for the mask:
So:
192.168.16.0 0.0.15.12? Does that look correct?
Any examples would help...
Thanks!
John
HTH, John *** Please rate all useful posts ***
Hi John,
The wildcard rule is : 0 - network bit exact match and 1 - any bit (0/1)
So in your case : - the first 2 octets must match
192.168.16.52  = 192. 168 + 0001 0000 . 0011 0100
192.168.19.56  = 192. 168 + 0001 0011 . 0011 1000
                          wild card last 2 otets 0000 0011 . 0000 1100 = 0.0.3.12
                          network 192.168.16.48
result 192.168.16.48 0.0.3.12
On network you will use the bits that match
On wildcasd the bits that match they have to be 0 ( excat match ) , and the ones that dont match can be either 0 or 1 ( 1 means any bit)
I hope it helps.
Dan
5 Replies 5
Hi John,
I hope it helps.
Dan
Thanks Dan...
In doing these like this, do you always have to and the 2 networks together before doing the mask?
Yes. The reason to add the binary version of the IP hosts together is to compare the bits value.
In your example the 1st and 2nd octet was obvious that matched. That's way we only compared the 3rd and 4th octet.
Let's take another example :
10.1.15.7
10.1.8.5
10.1.10.4
As the privious example the first to octets match so they will be as they are on the network (10.1 ) and the wildcard will be 0.0 - why ? because we want an exact match , remember if you use set a bit 0 on the wildcard the bit on the network must match, if you set the wildcard bit to 1 the network bit can be anything ( 0 or 1 ).
15 + 7 = 0000 1111  + 0000 0111
8   + 5 = 0000 1000  + 0000 0101
10 + 4 = 0000 1010  + 0000 0100
network = 0000 1000 + 0000 0100 = 8 + 4
wildcard = 0000 0111 + 0000 0011 = 7 + 3
Result 10.1.8.4 0.0.7.3
Dan
Okay, just so I verify I understand this:
192.168.20.15
192.168.21.30
192.168.23.52
192.168.x.x
20 & 15 = 00010100 . 00001111
21 & 30 = 00010101 . 00011110
23 & 52 = 00010111 .  00110100
      00010100 . 00000100
      00000011 . 00111011
192.168.20.4 0.0.3.59
Does that look right? The other question that I had is when you do this, does it really guarantee only these 3 hosts will get through? Or, does this type of mask still allow other hosts in (like too large of a summary)?
Yes, you got it right.
To be sincer with you I did not see this kind of acls in production environments, mainly because in the real life there is no restriction to use just one acl line when filtering   .
To answer you question, no, will not match only those hosts.
Dan
