Command to see if a port was ever up and passed traffic
mbrunton77
I am looking to find a command or counter to tell me if a cisco switch port on a 4510 was ever up and passed traffic.  I want to shutdown all unused switchports on our access switches.  But before I do that I need to make sure device is just not off or the person is away on vacation.  If I do sh int interface, is there a counter I can reference.
Daniel Thomas
The
"sh interface counters"
should show you if any traffic has passed through a port since the last reboot or since the counters were las cleared on that interface. (Which you can check with "sh interface")
In a previous employment we had to clear the counters across the switch fabric and then check them 3 months later, any ports that had shown no increase were closed.
Daniel Thomas
The
Hi ,
show interface x/x  >>>>> Last input and outpuit counters
Dan
Use "show interface link "  , that tells youi when it was last used.  Only valid on the 4500 series switches... Don't know why they never ported that useful command to their other products...
Hi Glen,
I didn't knew about this command. Though the output is corelated with the uptime of the switch and gets the same result of "show interface x/x | i Last in"
switch#s ver | i upt
switch uptime is 24 minutes
switch#show interfaces Gi1/1 | i Last
  Last input never, output never, output hang never
switch#show int link | i 1/1
Gi1/1                     24 minutes 57 secs      00:53:54  Tue Sep 27 2011
switch#
On the show interface you see that Last input is never, because it takes the starting point the time when it got up.
Dan
