10-14-2009 07:30 AM - edited 03-06-2019 08:07 AM
Hello all,
I am having an issue while trying to create a VLAN/SVI interface on my 6500 Metro Ethernet Aggregator.
I am receiving an error message that I cannot create an SVI without having the vlan added on the L2 vlan database, but the issue is that the vlan is already created there:
1. I created the vlan on the database:
CAT_6k_MT#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CAT_6k_MT(config)#vlan 1241
CAT_6k_MT(config-vlan)#name test
CAT_6k_MT(config-vlan)#exit
% Applying VLAN changes may take few minutes. Please wait...
2. Trying to add the SVI interface for that vlan
CAT_6k_MT(config)#int vlan 1241
CAT_6k_MT(config-if)#no shut
Oct 14 10:11:04.241 CST: %PM-4-SVI_ADD_CORRESPONDING_L2_VLAN: Vlan 1241 must be added to L2 database in order to be used, do <vlan 1241> from config mode.
Oct 14 10:11:04.257 CST: %LINK-3-UPDOWN: Interface Vlan1241, changed state to down
Then I checked the vlan 1241 is created on the database:
CAT_6k_MT#sh vlan id 1241
VLAN Name Status Ports
1241 VLAN1241 active Po11, Po61
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1241 enet 101241 1500 - - - - - 0 0
Remote SPAN VLAN
Disabled
Primary Secondary Type Ports
CAT_6k_MT#sh run int vlan 1241
Building configuration...
Current configuration : 41 bytes
interface Vlan1241
no ip address
end
But when I look at the interface vlan is always down/down:
CAT_6k_MT(config-if)#do sh int vlan 1241
Vlan1241 is down, line protocol is down
Hardware is EtherSVI, address is 0016.9c7b.d7c0 (bia 0016.9c7b.d7c0)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input never, output never, output hang never
Queueing strategy: fifo
Any ideas reagrding this?
Thanks for your help!
Alex
10-14-2009 12:52 PM
This a production environment. it is running VTP server mode.
I also tried to delete the vlan and recreated but it does not work either.
Here is the VTP status output:
CAT_6k_MT>en
Password:
CAT_6k_MT#sh vtp sta
CAT_6k_MT#sh vtp status
VTP Version : 3 (capable)
VTP version running : 3
VTP Domain Name : TELUM
VTP Pruning Mode : Enabled
VTP Traps Generation : Enabled
Device ID : 0016.9c7b.d7c0
Feature VLAN:
VTP Operating Mode : Primary Server
Number of existing VLANs : 682
Number of existing extended VLANs : 189
Configuration Revision : 528
Primary ID : 0016.9c7b.d7c0
Primary Description : CAT_6k_MT
MD5 digest : 0xBA 0x6F 0x2C 0xFA 0xE8 0xAD 0x76 0xCD
0x5C 0x47 0x05 0xD8 0x5D 0xD8 0x0C 0xFA
Feature MST:
Configuration Revision : 1
MD5 digest : 0x7A 0x16 0x11 0x7F 0x4B 0x1F 0x36 0x1E
0x9A 0x0D 0x19 0x80 0xC4 0x02 0xBB 0x7F
Regards!
Alex
10-16-2009 09:10 AM
I am guessing you also had a TAC case open on this. Can you post a resolution? I am curious to see what the issue was.
James
10-20-2009 08:19 AM
Here is the response from TAC, we will try this later this week, I'll let you know the result.
We really have 2 choices here. And we have to be careful because we
might lose the vlan database. It has been locked since April.
We should try to force a supervisor failover and then see if we can add
a new vlan:
Redundancy force-switchover
Then try to see if the interface vlan639 comes up after configuring it
again
Conf t
Vlan 639
Interface vlan 639
Ip address 4.4.4.4 255.255.255.0
Interface fas6/15
Switchport access vlan 639
End
Check with the command
Show ip interface brief | incl 639
If the above does not work, we need to have someone on-site in case the
cat6k erases its vlan configuration and loses its configuration
completely.
You need to have a vlan configuration from a show running output of
another switch in the VTP domain. If it has the vlans in its output,
then we can use this to recover the switch.
Also, if the vlans are erased, we need to make sure this switch does not
push that information out to the network. The correct way to do this is
to use the interface range command and shut down all of the ports. Then
reboot the switch and if it comes up with all of the vlans, to then "no
shut" the ports and allow it to communicate with the rest of the
switches in the VTP domain.
If you don't shut down all of the ports, the switch may propagate its
erased vlan configuration across the network to the other VTP switches
and erase the configuration on the entire network.
