not able to ping from desktop but able to ping from switch
dipak3254176
hello,
i am trying to ping 172.16.0.250 address from my desktop located in vlan 10.
i can able to ping 172.16.0.250 from my L3 switch but not able to ping from my desktop belong to vlan 10.
we have assing 172.16.0.254 ip to one interface fa 0/48.
dekstop can able to ping 172.16.0.254  this ip.
nkarthikeyan
Level 7
Level 7
It can be a access restriction of your device or it can also be the local desktop problem... i.e. local firewall installed in ur desktop.... try disabling the firewall/IPS installed in your desktop.... pls post the configuration of the switch where the desktops connected.... also pls check on the ip address,snm and dgw assigned to the desktop is the correct one.
i guess my earlier post is little bit confusing, sorry for confustion and tanks for your reply.
here is the required data.
CTC_L3#show run
Building configuration...
Current configuration : 4357 bytes
version 12.2
no service pad
hostname CTC_L3
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
crypto pki trustpoint TP-self-signed-2873386624
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2873386624
revocation-check none
rsakeypair TP-self-signed-2873386624
crypto pki certificate chain TP-self-signed-2873386624
  quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 8
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 10
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
no switchport
ip address 172.16.0.254 255.255.248.0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
no ip address
ip directed-broadcast 1
interface Vlan8
ip address 172.16.8.1 255.255.254.0
interface Vlan9
ip address 192.168.9.1 255.255.255.0
interface Vlan10
ip address 172.16.10.1 255.255.254.0
ip default-gateway 172.16.0.250
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.250
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
pc1 belong to vlan 8 ip 172.16.8.2 (vlan 8 ip 172.16.8.1)
pc2 belong to vlan 10 ip 172.16.10.2 (vlan 10 ip 172.16.10.1)
ping from pc1 to pc2 --ok
ping from l3 to FW (172.16.0.250) and pc3 (172.16.0.11)-- ok
ping from pc1 to fw and pc3 not working.
ping from pc2 to fw and pc3 not working.
port fa0/48 having ip address 172.16.0.254 belong to vlan 1
pc3 ip address is 172.16.0.11
fw ip address is 172.16.0.250
please let me know in case any other info needed.
Thanks for your valuable responce.
here since we dont have sufficient budget for this year we have buy only 3 number of switches for this year network upgradation plan.
my network currentlly running on 172.16.0.0/255.255.248.0 address.
for senperating a nework in small broadcast domain i have created a vlan 8 and vlan 10.
after removing routing from interface fa0/48 and connecting plane switch on fa0/47 port will help me to connect from my newlly created vlan (vlan 8 and vlan 10) to connect the rest of nework (172.16.0.0/255.255.248.0)??
since i am not in office now i'm unable to do this at this moment.
expecting your reply. thanks again for your kind help.
Thanks for reply,
as per above post, i have created vlan same as my existing network (172.16.0.0/255.255.248.0) named vlan 1.
host belong to vlan 1 can able to ping my other host available in my existing networkk connected to plane switch.
but the host from vlan 8 and vlan 10 are not able to ping host available in my plane network. they can only able to ping the host of vlan 1 available in my l3 switch.
at the end of the day i need default route pointing to my firewall 172.16.0.250 for connecting to branches and internet.
the question is how do i advertised to have the intervlan routing???
i have already enable intervlan routing using ip routing command in layer 3 switch.
the excisting configuration is as below.
Press RETURN to get started.
Switch>
Switch>
Switch>en
Switch#show run
Current configuration : 4115 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip routing
  quit
no switchport
no ip address
interface Vlan1
interface Vlan8
interface Vlan10
ip classless
ip route 192.168.11.0 255.255.255.0 172.16.0.250
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
thanks
