Not able to ping the VLAN from another location
Mr.Kumar
I have a VLAN created on the core switch first and assigned some ports on the Access switches, the ports or not functioning so then i started troubleshooting the issue then i found VLAN is not showing in the access switches so i matched the VTP version of the core with the access switch then it started showing it on Access switches, but the problem is i'm not able to ping the VLAN IP from different location and when i connect something to the port where the VLAN is configured i'm not getting the network. Please help me. Thanks
interface Vlan613
ip address 10.87.185.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
end
19 Replies 19
ledzepp817
How is core switch connected to the access switches?  By Trunk ports?  If so, is VLAN 613 allowed on that Trunk Port?
Also, is the Core switch a Nexus?  If so, you need to have "no shutdown" under that Interface VLAN.
Yes the Core switch is connected to access switches through trunk and the core switch is Catalyst switch, following is the sh int trunk status
Core switch#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/13 on 802.1q trunking 999
Gi1/0/14 on 802.1q trunking 999
Gi2/0/13 on 802.1q trunking 999
Gi2/0/14 on 802.1q trunking 999
Po1 on 802.1q trunking 999
Po2 on 802.1q trunking 999
Po3 on 802.1q trunking 999
Po4 on 802.1q trunking 999
Po5 on 802.1q trunking 999
Po6 on 802.1q trunking 999
Po7 on 802.1q trunking 999
Po8 on 802.1q trunking 999
Po9 on 802.1q trunking 999
Po10 on 802.1q trunking 999
Po36 on 802.1q trunking 306
Port Vlans allowed on trunk
Gi1/0/13 1,900
Gi1/0/14 1,900
Gi2/0/13 1,900
Gi2/0/14 1,900
Po1 1-4094
Po2 1-4094
Po3 1-4094
Po4 1-4094
Po5 1-4094
Po6 1-4094
Po7 1-4094
Po8 1-4094
Po9 1-4094
Po10 1-4094
Po36 1-4094
Port Vlans allowed and active in management domain
Gi1/0/13 1,900
Gi1/0/14 1,900
Gi2/0/13 1,900
Gi2/0/14 1,900
Po1 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po2 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po3 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po4 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po5 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po6 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po7 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po8 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po9 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po10 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Po36 1,10,20,106,200-201,306,613,800,803,810,900,905,999
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/13 1,900
Gi1/0/14 1,900
Gi2/0/13 1,900
Gi2/0/14 1,900
Po3 1,20,106,306,900
Po4 1,20,106,306
Po5 1,20,106,306
Po6 1,20,106,306,900
Po8 1,20,106,306,900
and status of the port where the access switch is connected to the core
Core switch#sh run int g1/0/22
Building configuration...
Current configuration : 338 bytes
interface GigabitEthernet1/0/22
description ***Access switch ***
switchport trunk native vlan 999
switchport mode trunk
switchport nonegotiate
carrier-delay msec 0
storm-control broadcast level 10.00
storm-control multicast level 10.00
channel-group 2 mode on
spanning-tree portfast
spanning-tree link-type point-to-point
end
What is the next step to fix the issue?
Run these commands please:
Core switch
sh int status
sh span vlan 613
sh ip int brief
Access switch
sh int status
sh span vlan 613
Following are the results
Core Switch
USRICSWCO001#sh int status
Port Name Status Vlan Duplex Speed Type
Gi1/0/1 ***USRICRTVP001*** connected 10 full 1000 10/100/1000BaseTX
Gi1/0/2 *** USRICRTGW001 G connected trunk full 1000 10/100/1000BaseTX
Gi1/0/3 ***KVMUSRIC001*** connected 905 a-full a-1000 10/100/1000BaseTX
Gi1/0/4 *** USRICUPS001 ** connected 905 a-full a-100 10/100/1000BaseTX
Gi1/0/5 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/6 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/7 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/8 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/9 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/10 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/11 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/12 notconnect 900 auto auto 10/100/1000BaseTX
Gi1/0/13 **ESX1-1 INFUSRIC connected trunk full 1000 10/100/1000BaseTX
Gi1/0/14 **ESX2-1 INFUSRIC connected trunk full 1000 10/100/1000BaseTX
Gi1/0/15 **ESX1-3 INFUSRIC connected 200 full 1000 10/100/1000BaseTX
Gi1/0/16 **ESX2-3 INFUSRIC connected 200 full 1000 10/100/1000BaseTX
Gi1/0/17 **ESX1i INFUSRIC connected 905 a-full a-1000 10/100/1000BaseTX
Gi1/0/18 **NETBi NetApp e0m connected 900 a-full a-1000 10/100/1000BaseTX
Gi1/0/19 *** NETAB e0a *** connected 200 full 1000 10/100/1000BaseTX
Gi1/0/20 *** NETAA e0a *** connected 200 full 1000 10/100/1000BaseTX
Gi1/0/21 ***USRICSWAC001*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/0/22 ***USRICSWAC002 ** connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/0/23 ***USRICSWAC003*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/0/24 ***USRICSWAC004*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/1/1 ***USRICSWAC007*** connected trunk full 1000 1000BaseSX SFP
Gi1/1/2 ***USRICSWAC008 ** connected trunk full 1000 1000BaseSX SFP
Gi1/1/3 ***USRICSWAC09*** connected trunk full 1000 1000BaseSX SFP
Gi1/1/4 notconnect 1 auto auto unknown
Gi2/0/1 disabled 10 full 1000 10/100/1000BaseTX
Gi2/0/2 *** USRICRTGW001 G connected trunk full 1000 10/100/1000BaseTX
Gi2/0/3 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/4 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/5 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/6 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/7 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/8 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/9 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/10 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/11 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/12 notconnect 900 auto auto 10/100/1000BaseTX
Gi2/0/13 **ESX1-2 INFUSRIC connected trunk full 1000 10/100/1000BaseTX
Gi2/0/14 **ESX2-2 INFUSRIC connected trunk full 1000 10/100/1000BaseTX
Gi2/0/15 **ESX1-4 INFUSRIC connected 200 full 1000 10/100/1000BaseTX
Gi2/0/16 **ESX2-4 INFUSRIC connected 200 full 1000 10/100/1000BaseTX
Gi2/0/17 **ESX1i INFUSRIC connected 905 a-full a-1000 10/100/1000BaseTX
Gi2/0/18 connected 900 a-full a-1000 10/100/1000BaseTX
Gi2/0/19 *** NETAB e0b *** connected 200 full 1000 10/100/1000BaseTX
Gi2/0/20 *** NETAA e0b *** connected 200 full 1000 10/100/1000BaseTX
Gi2/0/21 ***USRICSWAC001 1/ connected trunk a-full a-1000 10/100/1000BaseTX
Gi2/0/22 ***USRICSWAC001 1/ connected trunk a-full a-1000 10/100/1000BaseTX
Gi2/0/23 *** USRICSWAC005 g connected trunk a-full a-1000 10/100/1000BaseTX
Gi2/0/24 ***USRICSWAC006 1/ connected trunk a-full a-1000 10/100/1000BaseTX
Gi2/1/1 ***USRICSWAC007 1/ connected trunk full 1000 1000BaseSX SFP
Gi2/1/2 ***USRICSWAC008 1/ connected trunk full 1000 1000BaseSX SFP
Gi2/1/3 disabled trunk auto auto unknown
Gi2/1/4 ***USRICSWAC010 1/ connected trunk full 1000 1000BaseSX SFP
Gi3/0/1 notconnect 900 full 1000 10/100/1000BaseTX
Gi3/0/2 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/3 notconnect 905 auto auto 10/100/1000BaseTX
Gi3/0/4 notconnect 905 auto auto 10/100/1000BaseTX
Gi3/0/5 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/6 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/7 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/8 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/9 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/10 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/11 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/12 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/13 notconnect 106 auto auto 10/100/1000BaseTX
Gi3/0/14 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/15 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/16 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/17 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/18 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/19 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/20 notconnect 900 auto auto 10/100/1000BaseTX
Gi3/0/21 ***USRICSWAC005*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi3/0/22 ***USRICSWAC006 ** connected trunk a-full a-1000 10/100/1000BaseTX
Gi3/0/23 ***USRICSWAC003*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi3/0/24 ***USRICSWAC004 ** connected trunk a-full a-1000 10/100/1000BaseTX
Gi3/1/1 disabled 1 auto auto unknown
Gi3/1/2 disabled 1 auto auto unknown
Gi3/1/3 ***USRICSWAC009*** connected trunk full 1000 1000BaseSX SFP
Gi3/1/4 ***USRICSWAC010*** connected trunk full 1000 1000BaseSX SFP
Po1 ***USRICSWAC001*** connected trunk a-full a-1000
Po2 ***USRICSWAC002*** connected trunk a-full a-1000
Po3 ***USRICSWAC002*** connected trunk a-full a-1000
Po4 ***USRICSWAC002*** connected trunk a-full a-1000
Po5 ***USRICSWAC002*** connected trunk a-full a-1000
Po6 ***USRICSWAC006*** connected trunk a-full a-1000
Po7 ***USRICSWAC007*** connected trunk a-full a-1000
Po8 ***USRICSWAC008*** connected trunk a-full a-1000
Po9 ***USRICSWAC009*** connected trunk a-full a-1000
Po10 ***USRICSWAC010*** connected trunk a-full a-1000
Po19 *** NETA1 *** connected 200 full 1000
Po20 *** NETA2 *** connected 200 full 1000
Po36 *** USRICRTGW001 connected trunk a-full a-1000
USRICSWCO001#
USRICSWCO001#
USRICSWCO001#sh span vlan 613
VLAN0613
Spanning tree enabled protocol rstp
Root ID Priority 4709
Address cc98.9160.ea80
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 4709 (priority 4096 sys-id-ext 613)
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Po1 Desg FWD 3 128.2027 P2p
Po2 Desg FWD 3 128.2028 P2p
Po3 Desg FWD 3 128.2029 P2p
Po4 Desg FWD 3 128.2030 P2p
Po5 Desg FWD 3 128.2031 P2p
Po6 Desg FWD 3 128.2032 P2p
Po7 Desg FWD 3 128.2033 P2p
Po8 Desg FWD 3 128.2034 P2p
Po9 Desg FWD 3 128.2035 P2p
Po10 Desg FWD 3 128.2036 P2p
Po36 Desg FWD 3 128.2062 P2p
USRICSWCO001#sh ip int brief
Vlan1 unassigned YES manual administratively down down
Vlan10 10.87.176.4 YES manual up up
Vlan20 10.87.176.33 YES manual up up
Vlan106 10.87.178.1 YES manual up up
Vlan200 10.87.176.161 YES manual up up
Vlan201 10.87.176.193 YES manual up up
Vlan306 10.87.180.1 YES manual up up
Vlan613 10.87.185.1 YES manual up up
Vlan800 10.87.182.1 YES manual up up
Vlan803 10.87.183.1 YES manual up up
Vlan810 10.87.184.1 YES manual up up
Vlan900 10.87.176.65 YES manual up up
Vlan905 10.87.176.129 YES manual up up
GigabitEthernet0/0 unassigned YES unset down down
GigabitEthernet1/0/1 unassigned YES unset up up
GigabitEthernet1/0/2 unassigned YES unset up up
GigabitEthernet1/0/3 unassigned YES unset up up
GigabitEthernet1/0/4 unassigned YES unset up up
GigabitEthernet1/0/5 unassigned YES unset down down
GigabitEthernet1/0/6 unassigned YES unset down down
GigabitEthernet1/0/7 unassigned YES unset down down
GigabitEthernet1/0/8 unassigned YES unset down down
GigabitEthernet1/0/9 unassigned YES unset down down
GigabitEthernet1/0/10 unassigned YES unset down down
GigabitEthernet1/0/11 unassigned YES unset down down
GigabitEthernet1/0/12 unassigned YES unset down down
GigabitEthernet1/0/13 unassigned YES unset up up
GigabitEthernet1/0/14 unassigned YES unset up up
GigabitEthernet1/0/15 unassigned YES unset up up
GigabitEthernet1/0/16 unassigned YES unset up up
GigabitEthernet1/0/17 unassigned YES unset up up
GigabitEthernet1/0/18 unassigned YES unset up up
GigabitEthernet1/0/19 unassigned YES unset up up
GigabitEthernet1/0/20 unassigned YES unset up up
GigabitEthernet1/0/21 unassigned YES unset up up
GigabitEthernet1/0/22 unassigned YES unset up up
GigabitEthernet1/0/23 unassigned YES unset up up
GigabitEthernet1/0/24 unassigned YES unset up up
GigabitEthernet1/1/1 unassigned YES unset up up
GigabitEthernet1/1/2 unassigned YES unset up up
GigabitEthernet1/1/3 unassigned YES unset up up
GigabitEthernet1/1/4 unassigned YES unset down down
Te1/1/1 unassigned YES unset down down
Te1/1/2 unassigned YES unset down down
Te1/1/3 unassigned YES unset down down
Te1/1/4 unassigned YES unset down down
GigabitEthernet2/0/1 unassigned YES unset administratively down down
GigabitEthernet2/0/2 unassigned YES unset up up
GigabitEthernet2/0/3 unassigned YES unset down down
GigabitEthernet2/0/4 unassigned YES unset down down
GigabitEthernet2/0/5 unassigned YES unset down down
GigabitEthernet2/0/6 unassigned YES unset down down
GigabitEthernet2/0/7 unassigned YES unset down down
GigabitEthernet2/0/8 unassigned YES unset down down
GigabitEthernet2/0/9 unassigned YES unset down down
GigabitEthernet2/0/10 unassigned YES unset down down
GigabitEthernet2/0/11 unassigned YES unset down down
GigabitEthernet2/0/12 unassigned YES unset down down
GigabitEthernet2/0/13 unassigned YES unset up up
GigabitEthernet2/0/14 unassigned YES unset up up
GigabitEthernet2/0/15 unassigned YES unset up up
GigabitEthernet2/0/16 unassigned YES unset up up
GigabitEthernet2/0/17 unassigned YES unset up up
GigabitEthernet2/0/18 unassigned YES unset up up
GigabitEthernet2/0/19 unassigned YES unset up up
GigabitEthernet2/0/20 unassigned YES unset up up
GigabitEthernet2/0/21 unassigned YES unset up up
GigabitEthernet2/0/22 unassigned YES unset up up
GigabitEthernet2/0/23 unassigned YES unset up up
GigabitEthernet2/0/24 unassigned YES unset up up
GigabitEthernet2/1/1 unassigned YES unset up up
GigabitEthernet2/1/2 unassigned YES unset up up
GigabitEthernet2/1/3 unassigned YES unset administratively down down
GigabitEthernet2/1/4 unassigned YES unset up up
Te2/1/1 unassigned YES unset down down
Te2/1/2 unassigned YES unset down down
Te2/1/3 unassigned YES unset down down
Te2/1/4 unassigned YES unset down down
GigabitEthernet3/0/1 unassigned YES unset down down
GigabitEthernet3/0/2 unassigned YES unset down down
GigabitEthernet3/0/3 unassigned YES unset down down
GigabitEthernet3/0/4 unassigned YES unset down down
GigabitEthernet3/0/5 unassigned YES unset down down
GigabitEthernet3/0/6 unassigned YES unset down down
GigabitEthernet3/0/7 unassigned YES unset down down
GigabitEthernet3/0/8 unassigned YES unset down down
GigabitEthernet3/0/9 unassigned YES unset down down
GigabitEthernet3/0/10 unassigned YES unset down down
GigabitEthernet3/0/11 unassigned YES unset down down
GigabitEthernet3/0/12 unassigned YES unset down down
GigabitEthernet3/0/13 unassigned YES unset down down
GigabitEthernet3/0/14 unassigned YES unset down down
GigabitEthernet3/0/15 unassigned YES unset down down
GigabitEthernet3/0/16 unassigned YES unset down down
GigabitEthernet3/0/17 unassigned YES unset down down
GigabitEthernet3/0/18 unassigned YES unset down down
GigabitEthernet3/0/19 unassigned YES unset down down
GigabitEthernet3/0/20 unassigned YES unset down down
GigabitEthernet3/0/21 unassigned YES unset up up
GigabitEthernet3/0/22 unassigned YES unset up up
GigabitEthernet3/0/23 unassigned YES unset up up
GigabitEthernet3/0/24 unassigned YES unset up up
GigabitEthernet3/1/1 unassigned YES unset administratively down down
GigabitEthernet3/1/2 unassigned YES unset administratively down down
GigabitEthernet3/1/3 unassigned YES unset up up
GigabitEthernet3/1/4 unassigned YES unset up up
Te3/1/1 unassigned YES unset down down
Te3/1/2 unassigned YES unset down down
Te3/1/3 unassigned YES unset down down
Te3/1/4 unassigned YES unset down down
Port-channel1 unassigned YES unset up up
Port-channel2 unassigned YES unset up up
Port-channel3 unassigned YES unset up up
Port-channel4 unassigned YES unset up up
Port-channel5 unassigned YES unset up up
Port-channel6 unassigned YES unset up up
Port-channel7 unassigned YES unset up up
Port-channel8 unassigned YES unset up up
Port-channel9 unassigned YES unset up up
Port-channel10 unassigned YES unset up up
Port-channel19 unassigned YES unset up up
Port-channel20 unassigned YES unset up up
Port-channel36 unassigned YES unset up up
Access Switch:
USRICSWAC002#sh int status
Gi1/0/1 ***Access Point*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/0/2 ***Access Point*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/0/3 ***Access Point*** connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/0/4 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/5 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/6 *** user *** connected 106 a-full a-100 10/100/1000BaseTX
Gi1/0/7 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/8 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/9 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/10 *** user *** connected 106 a-full a-100 10/100/1000BaseTX
Gi1/0/11 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/12 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/13 *** user *** notconnect 613 auto auto 10/100/1000BaseTX
Gi1/0/14 *** user *** notconnect 613 auto auto 10/100/1000BaseTX
Gi1/0/15 *** user *** notconnect 613 auto auto 10/100/1000BaseTX
Gi1/0/16 *** user *** notconnect 613 auto auto 10/100/1000BaseTX
Gi1/0/17 *** user *** notconnect 613 auto auto 10/100/1000BaseTX
Gi1/0/18 *** user *** notconnect 613 auto auto 10/100/1000BaseTX
Gi1/0/19 *** user *** notconnect 613 auto auto 10/100/1000BaseTX
Gi1/0/20 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/21 ***Access Point*** notconnect trunk auto auto 10/100/1000BaseTX
Gi1/0/22 ***Access Point*** notconnect trunk auto auto 10/100/1000BaseTX
Gi1/0/23 ***Access Point*** notconnect trunk auto auto 10/100/1000BaseTX
Gi1/0/24 ***Access Point*** notconnect trunk auto auto 10/100/1000BaseTX
Gi1/0/25 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/26 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/27 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/28 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/29 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/30 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/31 *** user *** connected 106 a-full a-100 10/100/1000BaseTX
Gi1/0/32 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/33 *** user *** connected 106 a-full a-100 10/100/1000BaseTX
Gi1/0/34 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/35 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/36 *** user *** connected 106 a-full a-100 10/100/1000BaseTX
Gi1/0/37 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/38 *** user *** connected 106 a-full a-100 10/100/1000BaseTX
Gi1/0/39 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/40 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/41 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/42 *** user *** connected 106 a-full a-1000 10/100/1000BaseTX
Gi1/0/43 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/44 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/45 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/46 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/47 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/48 *** user *** notconnect 106 auto auto 10/100/1000BaseTX
Gi1/0/49 *** USRICSWCO001 connected trunk a-full a-1000 10/100/1000BaseTX SFP
Gi1/0/50 *** USRICSWCO001 notconnect trunk auto auto Not Present
Gi1/0/51 *** USRICSWCO001 connected trunk a-full a-1000 10/100/1000BaseTX SFP
Gi1/0/52 *** USRICSWCO001 notconnect trunk auto auto Not Present
Po1 ***USRICSWC001*** connected trunk a-full a-1000
Fa0 disabled routed auto auto 10/100BaseTX
USRICSWAC002#sh span vlan 613
VLAN0613
Cost 3
Port 456 (Port-channel1)
Bridge ID Priority 33381 (priority 32768 sys-id-ext 613)
Address cc98.9106.0e80
Aging Time 300 sec
Gi1/0/1 Desg FWD 4 128.1 P2p
Gi1/0/2 Desg FWD 4 128.2 P2p
Gi1/0/3 Desg FWD 4 128.3 P2p
Po1 Root FWD 3 128.456 P2p
Please let me know what to do next? Thanks
Looking at the interface status on the access switch I see that all the ports that are assigned to vlan 613 are showing status as not connected. If there are no connected ports in vlan 613 then certainly there will be problems trying to access anything to or from that vlan.
Rick
Rick
What you said is true, but when i connect something to the ports which are on VLAN 613 i'm not able to access the network, so i believe there is some routing issue but not sure what it is. please suggest
You are probably correct that there may be something like a routing issue. But it is impossible to troubleshoot that possible issue when there is a condition that guarantees that it will not work. so connect at least one device and then we can do some troubleshooting. Can you verify for us what is the default gateway for the devices connected to vlan 613 on the access switch?
When you have at least one active device connected on the access switch in vlan 613 would you post the output of these commands on the core switch
show ip route
show arp vlan 613 (or show arp | include 613 if the core switch does not allow specification of vlan in the command)
Rick
Rick
Boy, from a networking perspective, everything sure looks ok.
Now, if this was a 3850 and NO routing was working, I would make sure that the "ip routing" command was configured on the switch.  That hit me once where the routing table was populated but wasn't routing at all because it was missing this command.
Now, other things to check:
- DHCP server giving out correct addresses?
- Subnet mask matching on host machines?
- DNS resolution working?
- Local firewalls?
- Can you plug into an access port 613 on the core switch and ping gateway?  get access to network?
Yes it's a 3850, following is the result for "sh ip route"
USRICSWCO001#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 10.87.176.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.87.176.1
10.0.0.0/8 is variably subnetted, 24 subnets, 7 masks
C 10.87.176.0/28 is directly connected, Vlan10
L 10.87.176.4/32 is directly connected, Vlan10
C 10.87.176.32/27 is directly connected, Vlan20
L 10.87.176.33/32 is directly connected, Vlan20
C 10.87.176.64/26 is directly connected, Vlan900
L 10.87.176.65/32 is directly connected, Vlan900
C 10.87.176.128/27 is directly connected, Vlan905
L 10.87.176.129/32 is directly connected, Vlan905
C 10.87.176.160/27 is directly connected, Vlan200
L 10.87.176.161/32 is directly connected, Vlan200
C 10.87.176.192/29 is directly connected, Vlan201
L 10.87.176.193/32 is directly connected, Vlan201
C 10.87.178.0/23 is directly connected, Vlan106
L 10.87.178.1/32 is directly connected, Vlan106
C 10.87.180.0/23 is directly connected, Vlan306
L 10.87.180.1/32 is directly connected, Vlan306
C 10.87.182.0/24 is directly connected, Vlan800
L 10.87.182.1/32 is directly connected, Vlan800
C 10.87.183.0/26 is directly connected, Vlan803
L 10.87.183.1/32 is directly connected, Vlan803
C 10.87.184.0/24 is directly connected, Vlan810
L 10.87.184.1/32 is directly connected, Vlan810
C 10.87.185.0/24 is directly connected, Vlan613
L 10.87.185.1/32 is directly connected, Vlan613
I can ping the gateway from access switch also but no clue why it is not working and for other VLANs i can ping from different locations but for only this VLAN i'm not able to ping from another location
Pinging gateway from access switch
USRICSWAC002#ping 10.87.185.1
Sending 5, 100-byte ICMP Echos to 10.87.185.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/6/14 ms
It is interesting that you can ping from the access switch. Would you post the output of show ip interface brief from the access switch? Also the output of show ip route from the access switch.
Can you verify whether devices connected to vlan 613 are receiving address assignment from DHCP?
Rick
Rick
Hello Richard,
Following are the out puts of Sh ip int br and sh ip route
USRICSWAC002#sh ip int br
Vlan1 unassigned YES NVRAM administratively down down
Vlan20 10.87.176.37 YES NVRAM up up
FastEthernet0 unassigned YES NVRAM administratively down down
GigabitEthernet1/0/5 unassigned YES unset up up
GigabitEthernet1/0/6 unassigned YES unset up up
GigabitEthernet1/0/9 unassigned YES unset up up
GigabitEthernet1/0/10 unassigned YES unset up up
GigabitEthernet1/0/11 unassigned YES unset up up
GigabitEthernet1/0/12 unassigned YES unset up up
GigabitEthernet1/0/13 unassigned YES unset down down
GigabitEthernet1/0/14 unassigned YES unset down down
GigabitEthernet1/0/15 unassigned YES unset down down
GigabitEthernet1/0/16 unassigned YES unset down down
GigabitEthernet1/0/17 unassigned YES unset down down
GigabitEthernet1/0/18 unassigned YES unset down down
GigabitEthernet1/0/19 unassigned YES unset down down
GigabitEthernet1/0/20 unassigned YES unset down down
GigabitEthernet1/0/21 unassigned YES unset down down
GigabitEthernet1/0/22 unassigned YES unset down down
GigabitEthernet1/0/23 unassigned YES unset down down
GigabitEthernet1/0/24 unassigned YES unset down down
GigabitEthernet1/0/25 unassigned YES unset down down
GigabitEthernet1/0/26 unassigned YES unset down down
GigabitEthernet1/0/27 unassigned YES unset down down
GigabitEthernet1/0/28 unassigned YES unset down down
GigabitEthernet1/0/29 unassigned YES unset down down
GigabitEthernet1/0/30 unassigned YES unset down down
GigabitEthernet1/0/31 unassigned YES unset up up
GigabitEthernet1/0/32 unassigned YES unset down down
GigabitEthernet1/0/33 unassigned YES unset up up
GigabitEthernet1/0/34 unassigned YES unset down down
GigabitEthernet1/0/35 unassigned YES unset up up
GigabitEthernet1/0/36 unassigned YES unset up up
GigabitEthernet1/0/37 unassigned YES unset up up
GigabitEthernet1/0/38 unassigned YES unset up up
GigabitEthernet1/0/39 unassigned YES unset up up
GigabitEthernet1/0/40 unassigned YES unset up up
GigabitEthernet1/0/41 unassigned YES unset down down
GigabitEthernet1/0/42 unassigned YES unset up up
GigabitEthernet1/0/43 unassigned YES unset down down
GigabitEthernet1/0/44 unassigned YES unset down down
GigabitEthernet1/0/45 unassigned YES unset down down
GigabitEthernet1/0/46 unassigned YES unset down down
GigabitEthernet1/0/47 unassigned YES unset down down
GigabitEthernet1/0/48 unassigned YES unset down down
GigabitEthernet1/0/49 unassigned YES unset up up
GigabitEthernet1/0/50 unassigned YES unset down down
GigabitEthernet1/0/51 unassigned YES unset up up
GigabitEthernet1/0/52 unassigned YES unset down down
USRICSWAC002#sh ip route
Default gateway is 10.87.176.33
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
and we are assigning the IPs statically to each device. Thanks
Thanks for the additional information. This indicates that the source address of the ping would have been 10.87.176.37 (the only IP address on the access switch). And the access switch would have forwarded the ping request to its default gateway of 10.87.176.33. And the ping was successful. So you have demonstrated that ping to vlan 613 from a remote subnet was successful. That pretty much says that it is not a routing problem you are dealing with. It is more likely to be an issue with the vlan or with DHCP set up for the vlan (assuming that the vlan is using DHCP).
Is this vlan using DHCP? Where is the DHCP server? How is the server configured for vlan 613?
Can you post the output of ifconfig from a host connected in vlan 613?
Rick
Rick
Hello Richard,
The VLAN is not using DHCP and we are assigning the to the device statically
IP : 10.87.185.2
Mask: 255.255.255.0
GW: 10.87.185.1
DNS: 10.87.94.142
Thank you for clarifying that you are using manual configuration and not DHCP for devices connected on vlan 613. Can you post the output on the core switch to the show arp vlan 613 (or show arp | include 613)
Rick
Rick
