not able to upgrade ios
satish2604
         Hi, I cannot upgrade my cisco ios to cz7200-adventerprisek9-mz.152-4.S1.image and not able to find out where the cisco ios is stored on my gns3.I have tried commands like "sh file systems" and "dir all-filesystems" but doesn't give me the image moreover whenever I try to see the contents of flash it gives me
newyork#sh flash Open device slot0 failed (No such device) newyork#sh flash: Open device slot0 failed (No such device)
newyork#sh bootflash: Open device bootflash failed (Bad device info block)
Also,
I cant get bootldr command to work
newyork(config)#boot bootldr slot0:c7200-adventerprisek9-mz.152-4.S1.image File slot0:c7200-adventerprisek9-mz.152-4.S1.image not found (No such device) 2)
Please see the output of
newyork#dir all-filesystems
Directory of archive:/
No files in directory
No space information available
Directory of system:/
    2  -r--           0                    <no date>  default-running-config
  718  dr-x           0                    <no date>  fpm
    3  drwx           0                    <no date>  its
  105  dr-x           0                    <no date>  memory
    1  -rw-        2462                    <no date>  running-config
  104  dr-x           0                    <no date>  vfiles
Directory of tmpsys:/
    6  drw-           0                    <no date>  eem_lib_system
    5  drw-           0                    <no date>  eem_lib_user
    4  drw-           0                    <no date>  eem_policy
    8  drw-           0                    <no date>  eem_pub
   16  -rw-           0                    <no date>  eem_rpc_0
   17  -rw-           0                    <no date>  eem_rpc_1
   26  -rw-           0                    <no date>  eem_rpc_10
   27  -rw-           0                    <no date>  eem_rpc_11
   28  -rw-           0                    <no date>  eem_rpc_12
   29  -rw-           0                    <no date>  eem_rpc_13
   30  -rw-           0                    <no date>  eem_rpc_14
   31  -rw-           0                    <no date>  eem_rpc_15
   18  -rw-           0                    <no date>  eem_rpc_2
   19  -rw-           0                    <no date>  eem_rpc_3
   20  -rw-           0                    <no date>  eem_rpc_4
   21  -rw-           0                    <no date>  eem_rpc_5
   22  -rw-           0                    <no date>  eem_rpc_6
   23  -rw-           0                    <no date>  eem_rpc_7
   24  -rw-           0                    <no date>  eem_rpc_8
   25  -rw-           0                    <no date>  eem_rpc_9
    7  drw-           0                    <no date>  eem_temp
    1  dr-x           0                    <no date>  lib
Directory of nvram:/
  122  -rw-        2635                    <no date>  startup-config
  123  ----           0                    <no date>  private-config
  124  -rw-        2635                    <no date>  underlying-config
    1  ----          49                    <no date>  persistent-data
I tried  using slot 1 in place of slot 0: and bootflash: but still gives me "bad device info" or "no such device". I guess my device boots up from the TFTP server, Please let me know how can iget the router to boot from  flash again with ios "c7200-adventerprisek9-mz.152-4.S1.image " as it doesn not have any contents.Please help
yusuf habibi
Hi,  you try to upgrade the IOS into GNS3 ?
Habibi
Regards, Habibi
