DHCP manual binding clarification
Pradeep H A
Hello experts,
need a clarification regarding this DHCP manual binding example on Cisco 1802 router. My question is will this manual binding configuration work? or will we have a problem because the manual binding is overlapping with the excluded range?
no ip dhcp use vrf connected
ip dhcp excluded-address 10.222.167.0 10.222.167.99
ip dhcp excluded-address 10.222.167.201 10.222.167.255
ip dhcp pool Holzwickede-1
   network 10.222.167.0 255.255.255.0
   domain-name xxxxxxx.com
   dns-server 10.1.10.21 10.224.123.4
   default-router 10.222.167.1
ip dhcp pool Holzwickede-Reserved-1
   host 10.222.167.250 255.255.255.0
   hardware-address xxxx.xxxx.xxxx
Quick answers appreciated because I have to implement this on our clients router today. Thanks a lot in advance.
If you want to allocate an IP from a scope it must not be excluded so you have to modify your excludded addresses like you've done.
Alain
cadet alain
if the manual binding is for an excluded address it won't work.A manual binding is  just a special allocation but it is still an allocation and you can't allocate what you exclude from the scope.
Alain
Hi Alain,
Thanks for the quick update, so do you suggest me to configure the excluded range like this?
ip dhcp excluded-address 10.222.167.201 10.222.167.249
ip dhcp excluded-address 10.222.167.251 10.222.167.255
or is there a better way to avoid the excluded range conflicting with manual binding?
Alain
Pradeep H A
Thanks a lot Alain,
saved me from trouble
