Not capturing Span traffic on 3750 - need suggestions
akeyr
I have configured Span port on our 3750 switch port. I have a voice recording system set up on port 47, the ip pbx is attached to port 48. I am not seeing any of the port 48 traffic on port 47 as I expected. Does anyone have any suggestions ?
I added this to the config:
monitor session 1 source interface Gi1/0/48
monitor session 1 destination interface Gi1/0/47
I have attached the switch config, as well as the show mon and show int for 47 and 48
Dale Miller
Looking over  the outputs provided it looks like SPAN is working as expected. The outputs rate on G1/0/47 matches that of the input/ouput rate on G1/0/48. Have you connected a sniffer to verify traffic is sent out the span destination port?
Session 1
Type                   : Local Session
Source Ports           :
    Both               : Gi1/0/48
Destination Ports      : Gi1/0/47
    Encapsulation      : Native
          Ingress      : Disabled
c3750.stack.aston#sh int gi1/0/48
GigabitEthernet1/0/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0025.83c3.ebb0 (bia 0025.83c3.ebb0)
  Description: MDF-C-77
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  Media-type configured as  connector
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 123
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 381000 bits/sec, 62 packets/sec
  5 minute output rate 82000 bits/sec, 56 packets/sec
     637339307 packets input, 479054571952 bytes, 0 no buffer
     Received 32955 broadcasts (77 multicasts)
     7 runts, 0 giants, 0 throttles
     7 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 77 multicast, 0 pause input
     557646042 packets output, 98566018230 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
c3750.stack.aston#sh int gi1/0/47
GigabitEthernet1/0/47 is up, line protocol is down (monitoring)
  Hardware is Gigabit Ethernet, address is 0025.83c3.ebaf (bia 0025.83c3.ebaf)
  Description: MDF-C-76
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  Last input never, output 5d00h, output hang never
  5 minute output rate 455000 bits/sec, 112 packets/sec <=====
     303560474 packets input, 43603238458 bytes, 0 no buffer
     Received 105102 broadcasts (1094 multicasts)
     0 watchdog, 1094 multicast, 0 pause input
     485664511 packets output, 422878049970 bytes, 0 underruns
Eugene Lau
G'day,
As Dale see's the SPAN as working, ensure your monitoring device is in a promiscious mode when monitoring - meaning that the NIC driver will be allowed to see all traffic.
You could test the SPAN by using a PC with WIRESHARK + WinPCAP (promiscious mode driver). They are both installed when you install WIRESHARK.
If you plug in a PC with wireshark and you see all the voice traffic -> then focus on your monitoring device.
Eugene
