NAT vlan routing issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-28-2011 11:16 AM - edited 03-06-2019 04:18 PM
Hey everyone,
I'm having issues getting clients on interface vlan 10 (GigabitEthernet 0/0/1) properly routing over vlan 1 (GigabitEthernet 0/0/0). Can anyone see any obvious errors in my configuration?
version 15.1
service password-encryption
hostname b-gw
boot-start-marker
boot system flash c1900-universalk9-mz.SPA.151-4.M.bin
boot-end-marker
aaa new-model
aaa session-id common
clock timezone GMT -7 0
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1 192.168.10.20
ip dhcp pool PRIMARY
network 192.168.10.0 255.255.255.0
dns-server 192.168.0.77
default-router 192.168.10.1
ip dhcp pool WIRELESS
network 192.168.12.0 255.255.255.0
default-router 192.168.12.1
dns-server 8.8.8.8
password encryption aes
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.10 255.255.252.0
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/0
switchport mode trunk
no ip address
interface GigabitEthernet0/0/1
switchport access vlan 10
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface Vlan1
ip address 192.168.11.1 255.255.255.0
ip nat outside
interface Vlan10
ip address 192.168.12.1 255.255.255.0
ip nat inside
router eigrp 10
network 192.168.0.0 0.0.3.255
network 192.168.11.0
ip default-gateway 192.168.0.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list NAT interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip access-list extended NAT
permit ip 192.168.12.0 0.0.0.255 any
access-list 23 permit 192.168.0.0 0.0.255.255
snmp-server community public RO
control-plane
banner login
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 0037035216502232
transport input ssh
line vty 5 15
access-class 23 in
transport input ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp peer 91.189.94.4
end
Thanks!
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2011 11:37 AM
the actual command should be:
ip nat inside source list NAT interface vlan 1 overload
please test and let me know.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2011 11:38 AM
Can you remove the below line and try
and make u r port gig0/0/0 as part of vlan 1 currently its in trunk mode.
switchport
switchport mode access
in addition to the above post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2011 12:23 PM
Thanks guys,
I've removed the default gateway, set the nat overload to interface vlan 1 and set ge0/0/0 to vlan 1. Still no luck!
Hosts on the 192.168.12.0 network are able to ping all internal interfaces on this router (192.168.[10/11/12].0), as well as the external interface 192.168.0.10.
Here's the current full config:
version 15.1
hostname b-gw
boot-start-marker
boot-end-marker
aaa new-model
no ipv6 cef
ip source-route
ip cef
dns-server 8.8.8.8
ip name-server 192.168.0.77
no ip address
shutdown
ip flow ingress
ip flow egress
duplex auto
speed auto
no mop enabled
ip flow ingress
ip flow egress
duplex auto
speed auto
no ip address
no ip address
interface Vlan1
ip nat outside
interface Vlan10
ip nat inside
router eigrp 10
ip http server
ip nat inside source list NAT interface Vlan1 overload
access-list 23 permit 10.10.10.0 0.0.0.63
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
transport input ssh
line vty 5 15
access-class 23 in
transport input ssh
ntp update-calendar
end
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2011 12:39 PM
Under u r interface gig0/0/1 can u enter switchport command and try it.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2011 12:41 PM
No luck there, am I missing something?:
b-gw#config t
Enter configuration commands, one per line. End with CNTL/Z.
b-gw(config)#interface gigabitEthernet 0/0/1
b-gw(config-if)#switchport
% Incomplete command.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2011 05:13 PM
I believe the issue may be in your default route unless I am missunderstaing the question. Do you only want to use PAT/NAT when talking to the 192.168.11.0/24 netowrk?
As your config stands, when a host on the 192.168.12.0/24 network wants to reach any other host except one on located on 192.168.11.0/24 it will be directed to 192.168.0.1 and never use NAT/PAT. If the destination is on the 192168.11.0/24 network, Port Address Translation is used and the 192.168.12.XXX host will be translated to 192.168.11.1 and then connect to that destination.
If you wanted all of your traffic on VLAN10 to route over(out) VLAN1 then your default route should look something like this.
ip route 0.0.0.0 0.0.0.0 192.168.11.XXX
