Not Detecting HWIC-2T in cisco 1921 router
suhas_syndrome
I Have installed HWIC-2T card in my cisco 1921 router but it is not able to detected in router. please find the ver of router
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 17:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
AP_PATANCHERU_ASRS uptime is 1 minute
System restarted at 13:03:50 UTC Mon Oct 15 2012
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
Suhas.
9 Replies 9
Sandeep Choudhary
Paste the full output of these commands:
sh ver
show diag
Hi Sandeep,
I am sending you show tech..
sh tech
AP_PATANCHERU_ASRS#sh tech-support
------------------ show version ------------------
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL162224AR
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID   SN
*0     CISCO1921/K9          FGL162224AR
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          None          None           None
------------------ show running-config ------------------
Building configuration...
Current configuration : 1126 bytes
! No configuration change since last restart
version 15.1
hostname AP_PATANCHERU_ASRS
boot-start-marker
boot-end-marker
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1921/K9 sn FGL162224AR
username cisco privilege 15 password 0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password
login local
transport input all
scheduler allocate 20000 1000
end
------------------ show redundancy history ------------------
------------------ show redundancy states ------------------
------------------ show redundancy switchover history ------------------
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
10908/12000  MRIB IPv6 Init Process
10960/12000  MRIB IPv4 Init Process
4100/6000   EEM Shell Director
4632/6000   SPAN Subsystem
58644/60000  EEM Auto Registration Proc
4860/6000   Auto Upgrade Startup Process
4992/6000   SASL MAIN
4948/6000   LICENSE AGENT DEFAULT
18252/24000  Init
4740/6000   RADIUS INITCONFIG
Interrupt level stacks:
Level    Called Unused/Size  Name
  1        1673   8100/9000  Network Interrupt
  3           0   9000/9000  Mgmt Interrupt
  4         245   8548/9000  Console UART
  7       19044   8548/9000  NMI Interrupt Handler
------------------ show interfaces ------------------
Embedded-Service-Engine0/0 is administratively down, line protocol is down
  Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
GigabitEthernet0/0 is down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is a44c.114f.48e0 (bia a44c.114f.48e0)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Auto Duplex, Auto Speed, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
     0 watchdog, 0 multicast, 0 pause input
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is administratively down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is a44c.114f.48e1 (bia a44c.114f.48e1)
------------------ show interfaces history ------------------
------------------ show controllers ------------------
Embedded engine is not enabled
Interface GigabitEthernet0/0
= Hardware =
Hardware is PLATFORM SGMII INTERFACE
HWIDB: 284DFA3C, INSTANCE: 284E0780, FASTSEND: 21150320, MCI_INDEX: 0
Route Cache Flag: 11
= Media
Media Change Count: 0
PORT IPD Registers:
BP_PAGE_CNT: 0x0000000000000001, BP_CNTS_PRX: 0x0000000000000000
GMX Registers:
RXX_INT_REG: 0x0000000000000000, RXX_INT_EN : 0x0000000000000000
PRTX_CFG   : 0x000000000000300E, RXX_FRM_CTL: 0x0000000000000077
RXX_FRM_CHK: 0x00000000000003BA, RXX_FRM_MIN: 0x0000000000000000
RXX_FRM_MAX: 0x0000000000000000, RXX_JABBER : 0x0000000000002580
RXX_DECISIO: 0x0000000000000018, RXX_FRM_CTL: 0x0000000000000077
RXX_FRM_CHK: 0x00000000000003BA, RXX_JABBER : 0x0000000000002580
RXX_DECISIO: 0x0000000000000018, RXX_UDD_SKI: 0x0000000000000000
RXX_STATS_C: 0x0000000000000000, RXX_IFG    : 0x0000000000000008
RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x0000000000000000
RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x0000000000000000
RXX_STAT_DR: 0x0000000000000000, RXX_STATS_B: 0x0000000000000000
SMACX      : 0x0000A44C114F48E0
TXX_SGMII_C: 0x0000000000000001, TXX_CTL    : 0x0000000000000003
RX_PRTS    : 0x0000000000000004, RX_BP_DROP : 0x0000000000000002
RX_BP_ON   : 0x0000000000000040, RX_BP_OFF  : 0x0000000000000010
TXX_PAU_PKT: 0x0000000000000060, TXX_MIN_PKT: 0x000000000000003B
TXX_PAU_PKI: 0x0000000000000010, TXX_SOFTPAU: 0x0000000000000000
TXX_PAU_TGO: 0x0000000000000000, TXX_PAU_ZRO: 0x0000000000000001
INF_MODE   : 0x0000000000000032, TX_PRTS    : 0x0000000000000004
TX_IFG     : 0x0000000000000048, TX_JAM     : 0x00000000000000EE
TX_COL_ATMP: 0x0000000000000010, TX_PAU_DMAC: 0x00000180C2000001
TX_PAU_TYPE: 0x0000000000008808, TX_OVR_BP  : 0x0000000000000303
TX_BP      : 0x0000000000000000, TX_CORRUPT : 0x000000000000000F
RX_PRT_INFO: 0x0000000000000000, GMX_STAT_BP: 0x0000000000000000
TX_INT_REG : 0x0000000000000000, TX_INT_EN  : 0x0000000000000000
ADR_CAM0   : 0x00000000000000A4
ADR_CAM1   : 0x000000000000004C
ADR_CAM2   : 0x0000000000000011
ADR_CAM3   : 0x000000000000004F
ADR_CAM4   : 0x0000000000000048
ADR_CAM5   : 0x00000000000000E0
ADR_CTL    : 0x000000000000000D, CAM_EN     : 0x00000000000000FF
TXX_STAT0  : 0x0000000000000000, TXX_STAT1  : 0x0000000000000000
TXX_STAT2  : 0x0000000000000000, TXX_STAT3  : 0x0000000000000000
TXX_STAT4  : 0x0000000000000000, TXX_STAT5  : 0x0000000000000000
TXX_STAT6  : 0x0000000000000000, TXX_STAT7  : 0x0000000000000000
TXX_STAT8  : 0x0000000000000000, TXX_STAT9  : 0x0000000000000000
PCS Registers:
MRX_CTL_REG: 0x0000000000001140, MRX_STS_REG: 0x0000000000000168
RXX_STA_REG: 0x00000000000008C7, RXX_SYN_REG: 0x0000000000000003
TXX_STA_REG: 0x0000000000000064, SGMX_AN_ADV: 0x0000000000001801
SGMX_AN_ADV: 0x0000000000004801, MISC_CTL   : 0x0000000000000000
ANX_ADV_REG: 0x0000000000000060, ANX_LP_ABIL: 0x0000000000004000
ANX_RESULTS: 0x0000000000000015, ANX_EXT_ST : 0x000000000000C000
LNX_TMR_CNT: 0x00000000000002FD, TX_RXX_PLRT: 0x0000000000000000
INT_REG    : 0x0000000000000000, INT_EN_REG : 0x0000000000000000
LOG_ANL_REG: 0x0000000000000000, ANX_ADV_REG: 0x0000000000000060
ANX_LP_ABIL: 0x0000000000004000, ANX_RSL_REG: 0x0000000000000015
ANX_EXT_ST : 0x000000000000C000, LNX_TMR_CNT: 0x00000000000002FD
MISCX_CTL: 0x0000000000001801
==============PIP Statistics================
PIP_RX_NO_ERR = 0, PIP_PARTIAL_ERR = 0
PIP_JABBER_ERR = 0, PIP_OVER_FCS_ERR = 0
PIP_OVER_ERR = 0, PIP_ALIGN_ERR = 0
PIP_UNDER_FCS_ERR = 0, PIP_GMX_FCS_ERR = 0
PIP_UNDER_ERR = 0, PIP_EXTEND_ERR = 0
PIP_LENGTH_ERR = 0, PIP_DAT_ERR = 0
PIP_SKIP_ERR = 0, PIP_NIBBLE_ERR = 0
PIP_UNKNOWN_ERR_14 = 0, PIP_UNKNOWN_ERR_15 = 0
PIP_PIP_FCS = 0, PIP_PIP_SKIP_ERR = 0
PIP_PIP_L2_MAL_HDR = 0
pip_rx_no_particle = 0, pip_undef_err = 0
pip_rx_no_buf_start = 0
PHY REGISTERS:
Display for CRC check for page:6
PACKET_GENERATION reg_addr: 16: 0x0010
CRC COUNTERS reg_addr: 17: 0x0000
page number:0
Copper Contrl @ reg_addr: 0: 0x1140
Copper Status @ reg_addr: 1: 0x7949
PHY Idf1 @ reg_addr: 2: 0x0141
PHY Idf2 @ reg_addr: 3: 0x0C97
Autoneg Adv @ reg_addr: 4: 0x0DE1
Autoneg Lnk Ptr abty @ reg_addr: 5: 0x0000
Autoneg Exp @ reg_addr: 6: 0x0004
Autoneg Nx Pg Tx @ reg_addr: 7: 0x2801
Autoneg Lk Prt Nx Pg @ reg_addr: 8: 0x0000
1000B-T Ctr @ reg_addr: 9: 0x0E00
1000B-T St @ reg_addr: 10: 0x4000
Copper Ext St @ reg_addr: 15: 0x3000
Copper Specific Ctl1 @ reg_addr: 16: 0x6060
Copper Specific St1 @ reg_addr: 17: 0x8000
Copper Interrupt En @ reg_addr: 18: 0x0000
Copper Specific St2 @ reg_addr: 19: 0x0040
Copper Rcv Er Ctr @ reg_addr: 21: 0x0000
Copper Specific Ctl2 @  reg_addr: 26: 0x8040
page number:1
Fiber Contrl @ reg_addr: 0: 0x1140
Fiber Status @ reg_addr: 1: 0x7949
Autoneg Adv @ reg_addr: 4: 0x0060
Autoneg Nx Pg Tx @ reg_addr: 7: 0x2001
Fiber Ext St @ reg_addr: 15: 0x3000
Fiber Specific Ctl1 @ reg_addr: 16: 0x0000
Fiber Specific St1 @ reg_addr: 17: 0x0010
Fiber Interrupt En @ reg_addr: 18: 0x0000
Fiber Specific St2 @ reg_addr: 19: 0x0000
Fiber Rcv Er Ctr @ reg_addr: 21: 0x0000
Fiber Specific Ctl2 @  reg_addr: 26: 0x8085
page number:2
MAC Contrl @ reg_addr: 0: 0x1040
MAC Specific Ctl1 @ reg_addr: 16: 0x0288
MAC Specific St1 @ reg_addr: 17: 0x0440
MAC Interrupt En @ reg_addr: 18: 0x0000
MAC Specific St2 @ reg_addr: 19: 0x0000
MAC Specific Ctl2 @  reg_addr: 26: 0x0005
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 0, TX_TAIL: 0
TX_MIN_SIZE: 32, TX_MAX_SIZE: 512, TX_CURRENT_SIZE: 128
RX STARVES: 0
Software MAC Address Filter (hash:length/addr/mask/hits)
  0x000:  0  ffff.ffff.ffff  0000.0000.0000         0
  0x0C0:  0  0180.c200.0002  0000.0000.0000         0
  0x0C0:  1  0100.0ccc.cccc  0000.0000.0000         0
  0x0C5:  0  0180.c200.0007  0000.0000.0000         0
  0x0F1:  0  a44c.114f.48e0  0000.0000.0000         0
  Software filtered frames: 0
  Unicast overflow mode: 0
  Multicast overflow mode: 1
  Promiscuous mode: 0
  Total Number of CAM entries: 1
Port Stopped: Y
Internal Loopback Set: N
Interface GigabitEthernet0/1
= Hardware =
HWIDB: 30B51130, INSTANCE: 30B51E80, FASTSEND: 21150320, MCI_INDEX: 0
= Media
PORT IPD Registers:
GMX Registers:
SMACX      : 0x0000A44C114F48E1
ADR_CAM5   : 0x00000000000000E1
PCS Registers:
RXX_STA_REG: 0x0000000000001CC7, RXX_SYN_REG: 0x0000000000000003
PHY REGISTERS:
page number:0
Copper Contrl @ reg_addr: 0: 0x1940
Copper Specific St1 @ reg_addr: 17: 0x8040
page number:1
Fiber Contrl @ reg_addr: 0: 0x1940
page number:2
MAC Contrl @ reg_addr: 0: 0x1840
RX STARVES: 0
  0x0F0:  0  a44c.114f.48e1  0000.0000.0000         0
  Promiscuous mode: 0
Port Stopped: Y
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*  0 con 0                idle                 00:00:24
  Interface    User               Mode         Idle     Peer Address
------------------ show file systems ------------------
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   archive:
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     rw   null:
             -             -   network     rw   tftp:
        262136        254606     nvram     rw   nvram:
             -             -    opaque     wo   syslog:
             -             -    opaque     rw   xmodem:
             -             -    opaque     rw   ymodem:
             -             -   network     rw   rcp:
             -             -   network     rw   http:
             -             -   network     rw   ftp:
             -             -   network     rw   scp:
             -             -    opaque     ro   tar:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
*    256610304     196268032  usbflash     rw   usbflash0: flash:
------------------ show file descriptors ------------------
File Descriptors:
   FD  Position  Open  PID  Path
  No open file descriptors
------------------ dir nvram: ------------------
Directory of nvram:/
  253  -rw-        1329                      startup-config
  254  ----           5                      private-config
  255  -rw-        1329                      underlying-config
    1  -rw-        2945                      cwmp_inventory
    4  ----           0                      rf_cold_starts
    5  ----          74                      persistent-data
    6  -rw-         559                      IOS-Self-Sig#1.cer
262136 bytes total (254606 bytes free)
------------------ show usbflash0: all ------------------
-#- --length-- -----date/time------ path
1     55088360 May 31 2012 17:42:00 +00:00 c1900-universalk9-mz.SPA.151-4.M4.bin
2         2903 May 31 2012 17:55:48 +00:00 cpconfig-19xx.cfg
3      3000320 May 31 2012 17:56:16 +00:00 cpexpress.tar
4         1038 May 31 2012 17:56:40 +00:00 home.shtml
5       122880 May 31 2012 17:57:06 +00:00 home.tar
6      1697952 May 31 2012 17:57:44 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 May 31 2012 17:58:20 +00:00 sslclient-win-1.1.4.176.pkg
196268032 bytes available (60342272 bytes used)
******** USB Flash Card Geometry/Format Info ********
USB CARD GEOMETRY
   Manufacturer Name      NA
   Model Number
   Serial Number
   Firmware Revision
   Number of Heads        0
   Number of Cylinders    0
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          0
USB PARTITION 1 INFO
   Start Sector           32
   Number of Sectors      501727
   Size in Bytes          256884224
   File System Type       FAT16
   Number of FAT Sectors  245
   Sectors Per Cluster    8
   Number of Clusters     62649
   Number of Data Sectors 501192
   Base FAT Sector        8
   Base Root Sector       498
   Base Data Sector       530
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   27E75D40   366518976    35512588   331006388    95510048   247510400
      I/O    DC00000    37748736    14393992    23354744    23354744    23350012
------------------ show process memory ------------------
Processor Pool Total:  366518976 Used:   35511840 Free:  331007136
      I/O Pool Total:   37748736 Used:   14393952 Free:   23354784
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  102700180   66101768   34168156        585         54 *Init*
   0   0      12368     149964      12368          0          0 *Sched*
   0   0     136324      11896      24188          0          0 *Dead*
   0   0          0          0     394940          0          0 *MallocLite*
   1   0     195768          0     203060          0          0 Chunk Manager
   2   0        240        240       4232          0          0 Load Meter
   3   0    2876044    2453100     448100          0          0 Exec
   4   0          0          0       7232          0          0 RO Notify Timers
   5   0       3380        280      10332          0          0 Check heaps
   6   0          0          0       7232         49          0 Pool Manager
   7   0          0          0       7232          0          0 DiscardQ Backgro
   8   0        240        240       7232          0          0 Timers
   9   0          0          0       4232          0          0 WATCH_AFS
  10   0          0          0       7232          0          0 License Client N
  11   0          0          0       7232          0          0 Image License br
  12   0    3245204    3245204       7232          0          0 Licensing Auto U
  13   0        240        240       7232          0          0 Environmental mo
  14   0          0          0       7232          0          0 IPC Event Notifi
  15   0          0          0       7232          0          0 IPC Dynamic Cach
  16   0          0          0       7232          0          0 IPC Session Serv
  17   0          0          0       7232          0          0 IPC Zone Manager
  18   0          0          0       7232          0          0 IPC Periodic Tim
  19   0          0          0       7232          0          0 IPC Deferred Por
  20   0          0          0       7232          0          0 IPC Process leve
  21   0       1704          0       8936          0          0 IPC Seat Manager
  22   0          0          0       7232          0          0 IPC Check Queue
  23   0          0          0       7232          0          0 IPC Seat RX Cont
  24   0          0          0       7232          0          0 IPC Seat TX Cont
  25   0          0          0       7232          0          0 IPC Keep Alive M
  26   0          0          0       7232          0          0 IPC Loadometer
  27   0          0          0      25232          0          0 Crash writer
  28   0        380          0       7612          0          0 Exception contro
  30   0          0          0       7232          0          0 ARP Input
  31   0          0          0       7232          0          0 ARP Background
  32   0        240        240       7232          0          0 ATM Idle Timer
  33   0          0          0       7232          0          0 ATM ASYNC PROC
  34   0          0          0       7232          0          0 CEF MIB API
  35   0          0          0       7232          0          0 AAA_SERVER_DEADT
  36   0          0          0      13232          0          0 Policy Manager
  37   0        240        240       7232          0          0 DDR Timers
  38   0       3140         80      10292         19         19 Entity MIB API
  39   0        240        240       7232          0          0 PrstVbl
  40   0        240        240       7232          0          0 Serial Backgroun
  41   0          0          0       4232          0          0 RMI RM Notify Wa
  42   0        240        240       7232          0          0 SMART
  43   0        240        240       7232          0          0 GraphIt
  44   0        240        240      13232          0          0 Dialer event
  45   0          0          0       7232          0          0 SERIAL A'detect
  46   0        240        240      13232          0          0 XML Proxy Client
  47   0          0          0       7232          0          0 Critical Bkgnd
  48   0     101292        640      15040         22         22 Net Background
  49   0        456        456      13232          0          0 IDB Work
  50   0        240        240      13232         18         18 Logger
  51   0      25772        240       7608          0          0 TTY Background
  52   0      65904          0      73136          0          0 IF-MGR control p
  53   0          0          0       7232          0          0 IF-MGR event pro
  54   0          0          0       4232          0          0 Inode Table Dest
  55   0          0          0       7232          0          0 cpf_msg_holdq_pr
  56   0          0          0       7232          0          0 cpf_msg_rcvq_pro
  57   0          0          0      13232          0          0 Crypto PKI-HA
  58   0        240        240       7232          0          0 TDM Management
  59   0          0          0       7232          2          2 rf task
  60   0          0          0       7232          0          0 RF High Priority
  61   0          0          0       7232          0          0 Net Input
  62   0        240        240       7232          0          0 Compute load avg
  63   0          0          0       7232          0          0 Per-minute Jobs
  64   0          0          0      10232          0          0 Per-Second Jobs
  65   0          0          0       7232          0          0 AggMgr Process
  66   0          0          0       7232          0          0 Token Daemon
  67   0          0          0       7232          0          0 Transport Port A
  68   0          0          0       7232          0          0 HC Counter Timer
  69   0        240        240       7232          0          0 SM Monitor
  70   0        240        240      13232          0          0 SM Installer
  71   0          0          0       4232          0          0 dev_device_inser
  72   0          0          0       4232          0          0 dev_device_remov
  73   0        240        240       7232          0          0 ESWPPM
  74   0        240        240       7232          0          0 Eswilp Storm Con
  75   0        240        240       7232          0          0 DXMRVL
  76   0        240        240       7232          0          0 ehwic_eswge Proc
  77   0        240        240       7232          0          0 Console redirect
  78   0          0          0       7232          0          0 RF_INTERDEV_DELA
  79   0          0          0      25232          0          0 RF_INTERDEV_SCTP
  80   0     300752       1712     310360          0          0 EEM ED ND
  81   0       4564          0      14796          0          0 EEM ED Identity
  82   0          0          0       7232          0          0 IGMP Snooping Pr
  83   0          0          0       7232          0          0 IGMP Snooping Re
  84   0        240        240       7232          0          0 Call Management
  85   0     228320       9416     200904          2          2 USB Startup
  86   0          0          0      25232          0          0 CF_INTERDEV_SCTP
  87   0        240        240      13232          0          0 Ethernet CFM
  88   0        240        240      13232          0          0 Ethernet Timer C
  89   0        240        240      13232          0          0 Ethernet Msec Ti
  90   0        240        240       7232          0          0 Dot1x Mgr Proces
  91   0          0          0       7232          0          0 MAB Framework
  92   0          0          0       7232          0          0 EAP Framework
  93   0       1104        240       8096          0          0 DTP Protocol
  94   0          0          0       7232          0          0 SFF8472
  95   0        240        240       7232          0          0 PI MATM Aging Pr
  96   0       9260        240      16252          0          0 call_home_les_oi
  97   0       3168          0      28400          0          0 SMI Director DB
  98   0          0          0       7232          0          0 SMI CDP Update H
  99   0       5756          0      30988          0          0 SMI Backup Proce
100   0          0          0       7232          0          0 IPv6 ping proces
101   0        240        240       7232          0          0 AAA Server
102   0          0          0       7232          0          0 AAA ACCT Proc
103   0      49384          0      56616          0          0 ACCT Periodic Pr
104   0       1168        240       8160          0          0 CDP Protocol
105   0        240        240       7232          0          0 AAA Dictionary R
106   0        240        240      13232          0          0 Ethernet LMI
107   0        240        240      10232          0          0 Ethernet OAM Pro
108   0        224          0      13456          0          0 CEF switching ba
109   0        224          0       4456          0          0 ADJ NSF process
110   0        240        240      13232          0          0 ATM OAM Input
111   0        240        240      13232          0          0 ATM OAM TIMER
112   0        240        240       7232          0          0 IPAM/ODAP Events
113   0      49384          0      62616          0          0 IPAM Manager
114   0        240        240      13232          0          0 IPAM Events
115   0       1096          0      14328          0          0 IP ARP Adjacency
116   0      49384          0      56616          0          0 IP ARP Retry Age
117   0          0          0      13232          0          0 IP Input
118   0          0          0       7232          0          0 ICMP event handl
119   0        240        240       7232          0          0 PIM register asy
120   0        240        240       7232          3          3 MOP Protocols
121   0        240        240       7232          0          0 PPP SIP
122   0        240        240       7232          0          0 PPP Bind
123   0        240        240      13232          0          0 PPP IP Route
125   0          0          0      13232          0          0 SSS Manager
126   0          0          0      13232          0          0 SSS Policy Manag
127   0          0          0       7232          0          0 SSS Feature Mana
128   0          0          0       7232          0          0 SSS Feature Time
129   0        480        240      13472          0          0 Spanning Tree
130   0        240        240      13232          0          0 SSM connection m
131   0          0          0       7232          0          0 WAAS Process
132   0          0          0       7232          0          0 X.25 Encaps Mana
133   0      14204         80      20936          0          0 CEF background p
134   0        224          0      13456          0          0 fib_fib_bfd_sb e
135   0        324          0       7556          0          0 IPC UDP Input
136   0      21140       1044      20120          0          0 CEF: IPv4 proces
137   0        224          0       7456          0          0 ADJ background
138   0          0          0       7232          0          0 Socket Timers
139   0        480        240       7472          0          0 Dot1x Supplicant
140   0        480        240       7472          0          0 Dot1x Supplicant
141   0        480        240       7472          0          0 Dot1x Supplicant
142   0        716        160       7948          0          0 L2MM
143   0          0          0       7232          0          0 MRD
144   0          0          0       7232          0          0 IGMPSN
145   0        240        240       4232          0          0 L2X Switching Ev
146   0          0          0      13232          0          0 Routing Topology
147   0        560          0      13792          0          0 IP RIB Update
148   0       1620       7508      10764          0          0 IP Background
149   0          0          0      10232          0          0 IP Connected Rou
150   0          0          0       7232          0          0 IP Traceroute
151   0          0          0       7232          0          0 Call Home Timer
152   0        224          0      13508          0          0 Collection proce
153   0          0          0       7232          0          0 SNMP Timers
154   0      19496        240      26488          0          0 SCTP Main Proces
155   0          0          0      13232          0          0 TCP Timer
156   0          0          0      13232          0          0 TCP Protocols
157   0        944          0      26176          0          0 HTTP CORE
158   0          0          0       7232          0          0 AAA System Acct
159   0        240        240       7232          0          0 PPP Compress Inp
160   0        240        240       7232          0          0 PPP Compress Res
161   0        944          0      62176          0          0 COPS
162   0        240        240       7232          0          0 Dialer Forwarder
163   0        224          0      13456          0          0 ADJ resolve proc
164   0        240        240       7232          0          0 Flow Exporter Ti
165   0        224          0      13456          0          0 MFIB Master back
166   0        480        240      10472          0          0 Multicast Offloa
167   0          0          0       7232          0          0 RARP Input
168   0        240        240      10232          0          0 static
169   0          0          0      10232          0          0 IP IRDP
170   0          0          0       7232          0          0 LAPB Process
171   0          0          0       7232          0          0 PAD InCall
172   0        240        240      13232          0          0 X.25 Background
173   0          0          0       7232          0          0 MQC Flow Event B
174   0          0          0       7232          0          0 HQF Shaper Backg
175   0        240        240       7232          0          0 RUDPV1 Main Proc
176   0          0          0      13232          0          0 VPDN call manage
178   0        240        240       7232          0          0 AAA Cached Serve
179   0        240        240       7232          0          0 ENABLE AAA
180   0          0          0       7232          0          0 EM Background Pr
181   0          0          0       7232          0          0 IDMGR CORE
182   0          0          0       7232          0          0 Key chain liveke
183   0        240        240       7232          0          0 LINE AAA
184   0        240        240       7232          0          0 LOCAL AAA
185   0      66844        240       8036          0          0 TPLUS
186   0      27764      26272       8724          3          3 NIST rng proc
187   0       1004        240       7996          0          0 LDAP process
188   0        240        240       7232          0          0 CSDB Timer proce
189   0          0          0       7232          0          0 crypto engine pr
190   0       3948       1648      15532          1          1 Crypto CA
191   0          0          0      13232          0          0 Crypto PKI-CRL
192   0          0          0      13232          0          0 encrypt proc
193   0          0       3908       7232          0          0 crypto sw pk pro
194   0          0          0      10232          0          0 Licensing MIB pr
195   0        240        240       7232          0          0 Control-plane ho
196   0      10052          0      17284          0          0 PM Callback
197   0          0          0       7232          0          0 URPF stats
198   0        240        240       7232          0          0 AAA SEND STOP EV
199   0          0          0      13232          0          0 Test AAA Client
200   0       4564          0      14796          0          0 EEM ED Routing
201   0     273628          0     283860         11          4 EEM ED Syslog
202   0       6616          0      16848          0          0 EEM ED Track
203   0       6388          0      16620          0          0 EEM ED Resource
204   0        240        240       7232          0          0 RMON Recycle Pro
205   0        240        240       7232          0          0 RMON Deferred Se
206   0          0          0       7232          0          0 Syslog Traps
208   0     517256      12392     490776          2          2 VLAN Manager
210   0     223548          0     230780          0          0 EEM Server
211   0      78676      29520      74508          0          0 Call Home proces
212   0      11508       1744      16996          0          0 EEM Policy Direc
213   0        240          0       4472          0          0 Async write proc
214   0       4564          0      14796          0          0 EEM ED CLI
215   0       4564          0      14796          0          0 EEM ED Counter
216   0       4564          0      14796          0          0 EEM ED Interface
217   0       4564          0      14796          0          0 EEM ED IOSWD
218   0       4564          0      14796          0          0 EEM ED None
219   0       4564          0      14796          0          0 EEM ED OIR
220   0       4748         80      14900          0          0 EEM ED RF
221   0       4564          0      14796          0          0 EEM ED SNMP
222   0       4564          0      14796          0          0 EEM ED SNMP Obje
223   0       4564          0      14796          0          0 EEM ED SNMP Noti
224   0       4564          0      14796          0          0 EEM ED Timer
225   0       4564          0      14796          0          0 EEM ED Test
226   0       4564          0      14796          0          0 EEM ED Config
227   0       4564          0      14796          0          0 EEM ED Env
228   0       4564          0      14796          0          0 EM ED GOLD
229   0       9616          0      19848          0          0 EEM ED Nf
230   0       4080       4080      13232         17         17 Syslog
231   0       4564          0      14796          0          0 EEM ED RPC
232   0        240          0      25472          0          0 tHUB
233   0       1720        240      14712          0          0 MRIB Process
234   0        240          0       4472          0          0 Async write proc
235   0        240          0       4472          0          0 Async write proc
236   0        240          0       4472          0          0 Async write proc
237   0          0          0       4232          0          0 DFS flush period
239   0      20780        688      45876          0          0 LICENSE AGENT
                                 39406580 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 13%/0%; one minute: 1%; five minutes: 0%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0           8          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2           4          21        190  0.00%  0.00%  0.00%   0 Load Meter
   3         480         152       3157  0.00%  0.47%  0.14%   0 Exec
   4           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   5          28          10       2800  0.00%  0.01%  0.00%   0 Check heaps
   6           0           1          0  0.00%  0.00%  0.00%   0 Pool Manager
   7           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
   9           0          20          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  10           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  11           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  12          40           3      13333  0.00%  0.03%  0.00%   0 Licensing Auto U
  13          76          98        775  0.55%  0.08%  0.01%   0 Environmental mo
  14           0          23          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  15           0           2          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  17           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  18           0         108          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  19           0         108          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  20           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  22           0           7          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  24           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  25           0          12          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  26           4          23        173  0.00%  0.00%  0.00%   0 IPC Loadometer
  27           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  28           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  30           0           1          0  0.00%  0.00%  0.00%   0 ARP Input
  31           0         117          0  0.00%  0.00%  0.00%   0 ARP Background
  32           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  33           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  34           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  35           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  36           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  37           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  38           0           3          0  0.00%  0.00%  0.00%   0 Entity MIB API
  39           0           2          0  0.00%  0.00%  0.00%   0 PrstVbl
  40           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  41           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  42           0           2          0  0.00%  0.00%  0.00%   0 SMART
  43           0          99          0  0.00%  0.00%  0.00%   0 GraphIt
  44           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  45           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  46           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  47           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  48           0          49          0  0.00%  0.00%  0.00%   0 Net Background
  49           0           2          0  0.00%  0.00%  0.00%   0 IDB Work
  50           0           5          0  0.00%  0.00%  0.00%   0 Logger
  51           0          94          0  0.00%  0.00%  0.00%   0 TTY Background
  52           0           2          0  0.00%  0.00%  0.00%   0 IF-MGR control p
  53           0           4          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  54           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  55           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  56           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  57           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
  58           0           2          0  0.00%  0.00%  0.00%   0 TDM Management
  59           0           2          0  0.00%  0.00%  0.00%   0 rf task
  60           0           1          0  0.00%  0.00%  0.00%   0 RF High Priority
  61           0           1          0  0.00%  0.00%  0.00%   0 Net Input
  62           0          22          0  0.00%  0.00%  0.00%   0 Compute load avg
  63           4           2       2000  0.00%  0.00%  0.00%   0 Per-minute Jobs
  64           4         112         35  0.00%  0.01%  0.00%   0 Per-Second Jobs
  65           0           1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  66           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  67           0           1          0  0.00%  0.00%  0.00%   0 Transport Port A
  68           0          23          0  0.00%  0.00%  0.00%   0 HC Counter Timer
  69           0           2          0  0.00%  0.00%  0.00%   0 SM Monitor
  70           0           2          0  0.00%  0.00%  0.00%   0 SM Installer
  71           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  72           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  73           0           2          0  0.00%  0.00%  0.00%   0 ESWPPM
  74           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  75           0           2          0  0.00%  0.00%  0.00%   0 DXMRVL
  76           0           2          0  0.00%  0.00%  0.00%   0 ehwic_eswge Proc
  77           0          94          0  0.00%  0.00%  0.00%   0 Console redirect
  78           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
  79           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
  80           0           6          0  0.00%  0.00%  0.00%   0 EEM ED ND
  81           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Identity
  82           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  83           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  84           0           5          0  0.00%  0.00%  0.00%   0 Call Management
  85          68          20       3400  0.00%  0.00%  0.00%   0 USB Startup
  86           0           1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
  87           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  88           0         600          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
  89           0       12177          0  0.15%  0.13%  0.05%   0 Ethernet Msec Ti
  90           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  91           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
  92           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
  93           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  94           0           1          0  0.00%  0.00%  0.00%   0 SFF8472
  95           0          98          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  96           4           2       2000  0.00%  0.00%  0.00%   0 call_home_les_oi
  97           0           1          0  0.00%  0.00%  0.00%   0 SMI Director DB
  98           0           1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
  99           4           1       4000  0.00%  0.00%  0.00%   0 SMI Backup Proce
100           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
101           0           2          0  0.00%  0.00%  0.00%   0 AAA Server
102           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
103           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
104           4          16        250  0.00%  0.00%  0.00%   0 CDP Protocol
105           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
106           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
107           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
108           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
109           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
110           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
111           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
112           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
113           0        3242          0  0.00%  0.02%  0.00%   0 IPAM Manager
114           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
115           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Adjacency
116           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
117           0           2          0  0.00%  0.00%  0.00%   0 IP Input
118           0           1          0  0.00%  0.00%  0.00%   0 ICMP event handl
119           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
120           0           3          0  0.00%  0.00%  0.00%   0 MOP Protocols
121           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
122           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
123           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
125           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
126           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
127           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
128           0         471          0  0.00%  0.00%  0.00%   0 SSS Feature Time
129           0           2          0  0.00%  0.00%  0.00%   0 Spanning Tree
130           0           2          0  0.00%  0.00%  0.00%   0 SSM connection m
131           0           1          0  0.00%  0.00%  0.00%   0 WAAS Process
132           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
133           0           5          0  0.00%  0.00%  0.00%   0 CEF background p
134           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
135           0           1          0  0.00%  0.00%  0.00%   0 IPC UDP Input
136           4         126         31  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
137           0           2          0  0.00%  0.00%  0.00%   0 ADJ background
138           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
139           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
140           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
141           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
142           0           2          0  0.00%  0.00%  0.00%   0 L2MM
143           0           1          0  0.00%  0.00%  0.00%   0 MRD
144           0           1          0  0.00%  0.00%  0.00%   0 IGMPSN
145           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
146           0           2          0  0.00%  0.00%  0.00%   0 Routing Topology
147           0           2          0  0.00%  0.00%  0.00%   0 IP RIB Update
148           0           5          0  0.00%  0.00%  0.00%   0 IP Background
149           0           6          0  0.00%  0.00%  0.00%   0 IP Connected Rou
150           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
151           0           3          0  0.00%  0.00%  0.00%   0 Call Home Timer
152           0           3          0  0.00%  0.00%  0.00%   0 Collection proce
153           0           1          0  0.00%  0.00%  0.00%   0 SNMP Timers
154           0           2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
155           0           1          0  0.00%  0.00%  0.00%   0 TCP Timer
156           0           1          0  0.00%  0.00%  0.00%   0 TCP Protocols
157           0           1          0  0.00%  0.00%  0.00%   0 HTTP CORE
158           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
159           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
160           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
161           0           1          0  0.00%  0.00%  0.00%   0 COPS
162           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
163           0           2          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
164           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
165           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
166           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
167           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
168           0           2          0  0.00%  0.00%  0.00%   0 static
169           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
170           0           1          0  0.00%  0.00%  0.00%   0 LAPB Process
171           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
172           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
173           0           1          0  0.00%  0.00%  0.00%   0 MQC Flow Event B
174           0           2          0  0.00%  0.00%  0.00%   0 HQF Shaper Backg
175           0         115          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
176           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
178           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
179           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
180           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
181           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
182           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
183           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
184           0           2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
185           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
186         688           2     344000  0.00%  0.02%  0.02%   0 NIST rng proc
187           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
188           0           2          0  0.00%  0.00%  0.00%   0 CSDB Timer proce
189           0           2          0  0.00%  0.00%  0.00%   0 crypto engine pr
190           0           4          0  0.00%  0.00%  0.00%   0 Crypto CA
191           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
192           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
193           0           3          0  0.00%  0.00%  0.00%   0 crypto sw pk pro
194           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
195           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
196           0           1          0  0.00%  0.00%  0.00%   0 PM Callback
198           0           2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
199           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
200           4           2       2000  0.00%  0.00%  0.00%   0 EEM ED Routing
201           0          10          0  0.00%  0.00%  0.00%   0 EEM ED Syslog
202           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Track
203           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Resource
204           0          13          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
205           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
206           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
208          12           3       4000  0.00%  0.00%  0.00%   0 VLAN Manager
210           0          46          0  0.00%  0.00%  0.00%   0 EEM Server
211           4           2       2000  0.00%  0.00%  0.00%   0 Call Home proces
212           0           2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
213           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
214           0           2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
215           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
216           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
217           0           3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
218           0           3          0  0.00%  0.00%  0.00%   0 EEM ED None
219           0           3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
220           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RF
221           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
222           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
223           0           2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
224           0           7          0  0.00%  0.00%  0.00%   0 EEM ED Timer
225           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Test
226           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Config
227           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Env
228           0           3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
229           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Nf
230           0           3          0  0.00%  0.00%  0.00%   0 Syslog
231           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
232           0           1          0  0.00%  0.00%  0.00%   0 tHUB
233           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
234           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
235           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
236           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
237           0           3          0  0.00%  0.00%  0.00%   0 DFS flush period
239           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
------------------ show process cpu history ------------------
AP_PATANCHERU_ASRS   01:06:16 PM Monday Oct 15 2012 UTC
                           11111
                      1111133333               66666     11111
  100
   90
   80
   70
   60
   50
   40
   30
   20
   10                      *****               *****
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
  100
   90
   80
   70
   60
   50
   40
   30
   20
   10 *
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
  100
   90
   80
   70
   60
   50
   40
   30
   20
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show diag ------------------
Slot 0:
C1921 Mother board 2GE, integrated VPN and 2W Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:02:21 ago
EEPROM contents at hardware discovery:
PCB Serial Number        : FOC16183XDK
Hardware Revision        : 1.0
Part Number              : 73-12850-05
Top Assy. Part Number    : 800-33408-03
Board Revision           : A0
Deviation Number         : 123694
Fab Version              : 02
Product (FRU) Number     : CISCO1921/K9
Version Identifier       : V04
CLEI Code                : COMKK00DRD
Processor type           : C8
Chassis Serial Number    : FGL162224AR
Chassis MAC Address      : a44c.114f.48e0
MAC Address block size   : 32
Manufacturing Test Data  : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
   0x00: 04 FF C1 8B 46 4F 43 31 36 31 38 33 58 44 4B 40
   0x10: 06 AC 41 01 00 82 49 32 32 05 C0 46 03 20 00 82
   0x20: 80 03 42 41 30 88 00 01 E3 2E 02 02 CB 8C 43 49
   0x30: 53 43 4F 31 39 32 31 2F 4B 39 89 56 30 34 20 D9
   0x40: 04 40 C1 CB C2 C6 8A 43 4F 4D 4B 4B 30 30 44 52
   0x50: 44 09 C8 C2 8B 46 47 4C 31 36 32 32 32 34 41 52
   0x60: C3 06 A4 4C 11 4F 48 E0 43 00 20 C4 08 00 00 00
   0x70: 00 00 00 00 00 F3 00 51 40 00 8B 41 00 3C 42 00
   0x80: 00 F8 00 24 03 E8 1B 11 07 D0 1E A2 09 C4 1F A9
   0x90: 0B B8 20 0F 0F A0 20 D3 13 88 21 6A 1B 58 21 A9
   0xA0: 1F 40 21 B8 27 10 21 3E 41 00 50 42 00 00 F8 00
   0xB0: 18 02 71 1D B0 04 E2 20 08 07 53 21 02 0E A6 22
   0xC0: 60 1D 4C 22 C4 27 10 22 C4 FF FF FF FF FF FF FF
   0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
Serial 2A/S (12in1)
WIC module not supported/disabled in this slot
Hardware revision 1.0          Board revision C0
Serial number     19018128   Part number    800-03182-01
FRU Part Number     WIC-2A/S=
Test history      0x0          RMA number     00-00-00
Connector type    PCI
EEPROM format version 1
   0x20: 01 13 01 00 01 22 31 90 50 0C 6E 01 00 00 00 00
   0x30: 60 00 00 00 00 06 11 00 FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
------------------ show platform ------------------
CIU Interrupt info:
CIU Int  Handler    Count   Context     Level  Name
0        0x2115018C 0       0x0         IP2    Pow Interrupt
18       0x21128720 0       0x2         IP3    fpga interrupt
30       0x21128768 0       0xE         IP2    USB 0 Over Current i
31       0x21128768 0       0xF         IP2    USB 1 Over Current i
32       0x210EAC1C 0       0x0         IP2    MBOX0 interrupt
33       0x210EAC1C 0       0x0         IP2    MBOX1 interrupt
34       0x2110F414 1       0x1         IP4    Aux Port interrupt
35       0x2110F414 1301    0x0         IP4    Console interrupt
40       0x2112B0F8 0       0x0         IP2    MSI 0 interrupt
41       0x2112B0F8 0       0x1         IP2    MSI 1 interrupt
42       0x2112B2FC 0       0x2         IP2    IO-Controller Networ
43       0x2112B51C 1       0x3         IP2    IO-Controller Mgmt/E
46       0x21128EB4 1       0x0         IP2    NPEI RML interrupt
52       0x2112E424 0       0x280F056C  IP3    CIU Timer 0 ISR
53       0x2112E424 0       0x307B3EE4  IP2    CIU Timer 1 ISR
54       0x2112E424 2       0x280F05E0  IP2    CIU Timer 2 ISR
56       0x2117D3E8 1       0x0         IP2    USB 0 interrupt
IP2 Int En: 0x01604F03 C0000001
IP3 Int En: 0x00100000 00040000
IP4 Int En: 0x0000000C 00000000
Interrupt Counters:
Int Level Counter: L1 (netio) 1679, L2 0, L3 (mgmt) 0, L4 (console) 1302, L5 0, L6 0, l7 (4ms timer) 38546
CIU IP level int counter: IP2 1715, IP3 0, IP4 1302
Debug counters/Info:
ciu_int2_count 1715, ciu_int3_count 0, ciu_int4_count 1302
unknown_ip4_int_cnt 0, unreg_int_cnt 0, wdog_int_cnt 0
unreg_int_sum1 0x0, unreg_int_sum2 0x0
spur_timer_int 0, unreg_msi_int_cnt 0
rml_int 1, npei_int 0, usb1_int 1711
npei_pcie0_err 0, npei_pcie1_err 0, npei_pcie_timeout 0
fpa_err 0, pip_err 0, ipd_err 0, mio_err 0
l2c_err 0, l2c_int_sum 0x00000000, lmc_err 0
l2d_faddr 0x00000000, l2t_fddr 0x00000000, lmc_faddr 0x00000000
usb 0/1 over current 0/0
pcie0_cfg030 0x0000583F, pcie1_cfg030 0x00000000
pcie0_cfg065 0x00000000, pcie1_cfg065 0x00000000
pcie0_cfg068 0x00000000, pcie1_cfg068 0x00000000
pcie0_cfg071 0x00000000, pcie1_cfg071 0x00000000
pcie0_cfg072 0x00000000, pcie1_cfg072 0x00000000
pcie0_cfg073 0x00000000, pcie1_cfg073 0x00000000
pcie0_cfg074 0x00000000, pcie1_cfg074 0x00000000
pcie0_cfg076 0x00000000, pcie1_cfg076 0x00000000
pcie0_dbg_info 0x00000000, pcie1_dbg_info 0x00000000
fpa_int_sum 0x00000000, pip_err_reg 0x00000000, ipd_int_sum 0x00000000
MSI Interrupt info:
MSI 128, name: wic_mbrd_hdlc_intr, hdlr 0x2139F7F4, cnt 0, ctx 0x0, slot 0, IO_Controller, NETIO, number 0
MSI 129, name: wic_mbrd_hdlc_intr, hdlr 0x2139F7F4, cnt 0, ctx 0x1, slot 0, IO_Controller, NETIO, number 1
MSI 130, name: wic_mbrd_hdlc_intr, hdlr 0x2139F7F4, cnt 0, ctx 0x2, slot 0, IO_Controller, NETIO, number 2
MSI 131, name: wic_mbrd_hdlc_intr, hdlr 0x2139F7F4, cnt 0, ctx 0x3, slot 0, IO_Controller, NETIO, number 3
MSI 155, name: i2c intr handler, hdlr 0x215497D0, cnt 0, ctx 0x0, slot 0, IO_Controller, NETIO, number 27
MSI 156, name: wic_mbrd_scc_netio_, hdlr 0x2139FDE0, cnt 0, ctx 0x0, slot 0, IO_Controller, NETIO, number 28
MSI 192, name: wic_mbrd_hdlc_error, hdlr 0x2139F824, cnt 1, ctx 0x0, slot 0, IO_Controller, ERR, number 0
MSI 193, name: wic_mbrd_hdlc_error, hdlr 0x2139F824, cnt 1, ctx 0x1, slot 0, IO_Controller, ERR, number 1
MSI 194, name: wic_mbrd_hdlc_error, hdlr 0x2139F824, cnt 1, ctx 0x2, slot 0, IO_Controller, ERR, number 2
MSI 195, name: wic_mbrd_hdlc_error, hdlr 0x2139F824, cnt 1, ctx 0x3, slot 0, IO_Controller, ERR, number 3
MSI 212, name: Hsib Error Monitor , hdlr 0x2154F44C, cnt 0, ctx 0x0, slot 0, IO_Controller, ERR, number 20
MSI 220, name: wic_mbrd_scc_mgmt_i, hdlr 0x2139FE5C, cnt 0, ctx 0x0, slot 0, IO_Controller, MGMT, number 28
MSI 221, name: tdm_exception_handl, hdlr 0x218D1738, cnt 0, ctx 0x104A0000, slot 0, IO_Controller, ERR, number 29
MSI 222, name: GPIO interrupt hand, hdlr 0x21540C78, cnt 0, ctx 0x10500200, slot 0, IO_Controller, ERR, number 30
MSI Enable Reg 0:  0x00000000 00000000
MSI Enable Reg 1:  0x00000000 00000000
MSI Enable Reg 2:  0x00000000 1800000F
MSI Enable Reg 3:  0x00000000 7010000F
NPEI_INT_ENB2:     0x201FFFFE 14280007
Platform DMA brief information:
DMA Channel 1:  is free.
DMA Channel 2:  is free.
DMA Channel 3:  is free.
CISCO1921/K9 Network IO Interrupt Throttling:
throttle count=0, timer count=0
throttle counts= 0 0 0 0 0
active=0, configured=1
netint usec=20000, netint mask usec=1000
real netint usec=4000, real netint mask usec=200
CPU Registers:
  Processor Revision ID    : 0xD0708
  Configuration            : 0x8000C48B
  Status                   : 0x50009FE1
  Cause                    : 0x0
  Count                    : 0xB90E5006
  Compare                  : 0xB91E0EF8
  WatchLo  (0)  : 0x0
  WatchLo  (1)  : 0xB6F477DFFFBB3EB8
  WatchHo  (0)  : 0x80000000
  WatchHo  (1)  : 0x80000000
  CacheErr (D)  : 0xD30
  TagLo    (I)  : 0xCD51A2A7DDC9DB02
  TagLo    (D)  : 0x0
  DataLo   (I)  : 0xEFB5F7F9BFFFBFE7
  DataLo   (D)  : 0x201FFFFE14280007
  TagHi    (D)  : 0x0
  DataHi   (I)  : 0x3
  DataHi   (D)  : 0xD1
  CVM Control   : 0xB00003F0
  CVM Mem Ctrl  : 0x46102
  CVM Count     : 0x1ACA328C87
  MultiCore Dbg : 0x0
  CIU PP RST    : 0xE
  CIU MBOX CLRX0 : 0x0
  CIU MBOX SETX0 : 0x0
  CIU MBOX CLRX1 : 0x0
  CIU MBOX SETX1 : 0x0
  BOOT_CFG_REG 0 : 0x200B13F1EC0
  BOOT_TIM_REG 0 : 0x1000080C0869044
  BOOT_CFG_REG 1 : 0x0
  BOOT_TIM_REG 1 : 0xFFFFFFFFFFFFFFF
  BOOT_CFG_REG 2 : 0xB00F1010
  BOOT_TIM_REG 2 : 0x13FFE8208A28186
  BOOT_CFG_REG 3 : 0xB00F1020
  BOOT_TIM_REG 3 : 0x13FFE8208A28186
  BOOT_CFG_REG 4 : 0xB00F1030
  BOOT_TIM_REG 4 : 0x13FFE8208A28186
  BOOT_CFG_REG 5 : 0xB00F1040
  BOOT_TIM_REG 5 : 0x13FFE8208A28186
  BOOT_CFG_REG 6 : 0xB00F1050
  BOOT_TIM_REG 6 : 0xBFFC4000722000
  BOOT_CFG_REG 7 : 0xB00F1060
  BOOT_TIM_REG 7 : 0xBFFC4000722000
On-board SPD data :
Size of dimm                 = 512 Megabytes
Memory Type                  = 0x8
Row Addresses                = 0xD
Column Address               = 0xA
Module Rows                  = 0x60
Data Width                   = 0x40
Voltage Interface            = 0x5
Cycle Time                   = 0x30
Access Time                  = 0x45
Configuration Type           = 0x0
Refresh Rate/Type            = 0x82
Primary Width                = 0x10
Error Width                  = 0x0
Burst Lengths                = 0xC
Number of Banks              = 0x8
Cas Latency                  = 0x30
DIMM Mechanical              = 0x1
DIMM Type                    = 0x2
Module Attributes            = 0x0
General Attributes           = 0x3
Min Cycle Time, CAS of 2     = 0x3D
Access Clock Cycle, CAS of 2 = 0x45
Min Cycle Time, CAS of 1     = 0x0
Access Clock Cycle, CAS of 2 = 0x0
Row Precharge                = 0x3C
Row Active to Row Active     = 0x28
RAS CAS Delay                = 0x3C
Ras Pulse Width              = 0x2D
Rank Density                 = 0x80
COM Setup Time               = 0x20
COM Hold Time                = 0x27
Data Setup Time              = 0x10
Data Hold Time               = 0x17
Write Recovery Time          = 0x3C
Write to Read Cmd Delay      = 0x1E
Read to Precharge Delay      = 0x1E
Probe Characteristics        = 0x0
Byte Ext to tRC and tRFC     = 0x6
Min Act to Act Refresh       = 0x3C
Min Refresh to Act Refresh   = 0x7F
Max Device Cycle Time        = 0x80
Device DQS-DQ Skew for DQS   = 0x18
Read Data Hold Skew Factor   = 0x22
PLL Relock Time              = 0x0
Vendor Id                    = 0000000000000000
Module Part Number           =
Module Revision Code         = 0000
SPD contents (hex):
  0x00: 80 08 08 0D 0A 60 40 00 05 30 45 00 82 10 00 00
  0x10: 0C 08 30 01 02 00 03 3D 45 00 00 3C 28 3C 2D 80
  0x20: 20 27 10 17 3C 1E 1E 00 06 3C 7F 80 18 22 00 00
  0x30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 DF
  0x40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM0 SPD data :
Memory Slot Empty
FPA Buffer pools information:
FPA INT SUM: 0x0000000000000000, ENB: 0x000000000FFFFFFF
FPA CTL STATUS: 0x0000000000004000
FPA QUE(n) AVAILABLE:
QUE(0): 0x00000000000001E8, QUE(1): 0x0000000000000FF8
QUE(2): 0x000000000000001D, QUE(3): 0x0000000000000400
QUE(4): 0x0000000000000000, QUE(5): 0x0000000000000000
QUE(6): 0x0000000000000000, QUE(7): 0x0000000000000000
FPA WART CTL: 0x0000000000000000, STATUS: 0x0000000000000000
FPA QUE(n) PAGE INDEX:
QUE(0): 0x000000000000000E, QUE(1): 0x000000000000007F
QUE(2): 0x0000000000000000, QUE(3): 0x000000000000001F
FPA QUE EXE: 0x0000000000000000, ACT: 0x0000000000000000
Cavium IPD Registers:
IPD_1ST_MBUF_SKP:0x0000000000000000, IPD_NOT_1ST_MBUF:0x0000000000000000
IPD_PKT_MBUF_SZE:0x00000000000000C0, IPD_CTL_STATUS  :0x0000000000000209
IPD_WQE_FPA_QUE :0x0000000000000001, IPD_SUB_BP_CNT  :0x0000000002000000
IPD_BP_PRT_REDE :0x0000000000000003, IPD_RED_PT_EN2  :0x0000000000000000
IPD_RED_QUE(0)_PARAM :0x0001FF0100000000
IPD_RED_QUE(1)_PARAM :0x0001FF0100000000
IPD_RED_QUE(2)_PARAM :0x0001FF0100000000
IPD_RED_QUE(3)_PARAM :0x0001FF0100000000
IPD_RED_QUE(4)_PARAM :0x0001FF0100000000
IPD_RED_QUE(5)_PARAM :0x0001FF0100000000
IPD_RED_QUE(6)_PARAM :0x0001FF0100000000
IPD_RED_QUE(7)_PARAM :0x0001FF0100000000
IPD_QOS(0)_RED_MARKS :0x0000010000000000
IPD_QOS(1)_RED_MARKS :0x0000010000000000
IPD_QOS(2)_RED_MARKS :0x0000010000000000
IPD_QOS(3)_RED_MARKS :0x0000010000000000
IPD_QOS(4)_RED_MARKS :0x0000010000000000
IPD_QOS(5)_RED_MARKS :0x0000010000000000
IPD_QOS(6)_RED_MARKS :0x0000010000000000
IPD_QOS(7)_RED_MARKS :0x0000010000000000
Cavium PKO Registers:
PKO_MEM_COUNT(0):0x0000000000000000, PKO_MEM_COUNT(1):0x0000000000000000
PKO_MEM_DEBUG(0):0x0000000000000000, PKO_MEM_DEBUG(1):0x0000000000000000
PKO_MEM_DEBUG(10):0x0000000000000000, PKO_MEM_DEBUG(11): 0x0000000000000000
PKO_MEM_DEBUG12: 0x0000000000000000, PKO_MEM_DEBUG13: 0x0000000000000000
PKO_MEM_DEBUG14: 0x0000000000000000, PKO_MEM_DEBUG2: 0x0000000000000000
PKO_MEM_DEBUG3: 0x0000000000000000, PKO_MEM_DEBUG4: 0x0000000000000000
PKO_MEM_DEBUG5: 0x0000000000000000, PKO_MEM_DEBUG6: 0x0000000001000000
PKO_MEM_DEBUG7: 0xF80FE01BA3900000, PKO_MEM_DEBUG8: 0x000000000000003F
PKO_MEM_DEBUG9: 0x0000000000000000, PKO_MEM_PORT_PTRS: 0x1FE0000000000000
PKO_MEM_PORT_QOS: 0x1FE0000000000000, PKO_MEM_PORT_RATE0: 0x0000000000000000
PKO_MEM_PORT_RATE1: 0x0000000000000000, PKO_MEM_QUEUE_PTRS: 0xFFE01BA390000000
PKO_MEM_QUEUE_QOS: 0x1FE0000000000000, PKO_REG_BIST_RESULT: 0x0000000000000000
PKO_REG_CMD_BUF: 0x00000000 0x0020007F, PKO_REG_CRC_ENABLE: 0x0000000000000000
PKO_REG_DEBUG0: 0x0000000000000000, PKO_REG_DEBUG1: 0x0000000000000000
PKO_REG_DEBUG2: 0x0000000000000000, PKO_REG_DEBUG3: 0x0000000000000000
PKO_REG_ENGINE_INFLIGHT: 0x0000004400004444, PKO_REG_ENGINE_THRESH: 0x0000000000000000
PKO_REG_ERROR: 0x0000000000000000, PKO_REG_FLAGS: 0x0000000000000007
PKO_REG_GMX_PORT_MODE: 0x0000000000000002, PKO_REG_INT_MASK: 0x0000000000000000
PKO_REG_QUEUE_MODE: 0x0000000000000000, PKO_REG_QUEUE_PTRS1: 0x0000000000000000
PKO_REG_READ_IDX: 0x0000000000000000
Watchodg information :
L1 watchdog is ON
  Address = 0x8001070000000500; Value = 0x3A593A3A692
    Mode = 2
    Length = 14953 (1999 millisec)
L2 watchdog is ON - watchdog 0 is used
  wdog_timer_limit address 0x10500494, value 0x1312D00
UART Information:
AUX (Uart 0)  Port Registers:
SR: 0x6  IER: 0xD   IIR: 0xC1  LCR: 0x7
MCR: 0x3  LSR: 0x60  MSR: 0x0   FCR: 0xC1
TFL: 0x0  RFL: 0x0
Parity Error = 0, Framing Error = 0, Receive Error = 0
Outcount = 0, TotalOut = 39, Incount = 0, Total In = 0
Overrun = 0, Overflow = 0
Brk Character: Received 0, Brk Processed 0
Console (Uart 1) Port Registers:
SR: 0x2  IER: 0xF   IIR: 0xC1  LCR: 0x7
MCR: 0x3  LSR: 0x0   MSR: 0x10  FCR: 0xC1
TFL: 0x3E RFL: 0x0
Outcount = 165, TotalOut = 87161, Incount = 1, Total In = 62
TLB entries :
Entries used: 30
SN  Size  paddr                                   vaddr                 perm
0   16MB  0x00000000_00000000:0x00000000_01FFFFFF 0x20000000:0x21FFFFFF 3,O,V
1   16MB  0x00000000_02000000:0x00000000_03FFFFFF 0x22000000:0x23FFFFFF 3,O,V
2   4MB   0x00000000_04000000:0x00000000_047FFFFF 0x24000000:0x247FFFFF 3,O,V
3   1MB   0x00000000_04800000:0x00000000_049FFFFF 0x24800000:0x249FFFFF 3,O,V
4   1MB   0x00000000_04A00000:0x00000000_04BFFFFF 0x24A00000:0x24BFFFFF 3,O,V
5   256KB 0x00000000_04C00000:0x00000000_04C7FFFF 0x24C00000:0x24C7FFFF 3,O,V
6   256KB 0x00000000_04C80000:0x00000000_04CFFFFF 0x24C80000:0x24CFFFFF 3,O,V
7   256KB 0x00000000_04D00000:0x00000000_04D7FFFF 0x24D00000:0x24D7FFFF 3,O,V
8   64KB  0x00000000_04D80000:0x00000000_04D9FFFF 0x24D80000:0x24D9FFFF 3,O,V
9   64KB  0x00000000_04DA0000:0x00000000_04DBFFFF 0x24DA0000:0x24DBFFFF 3,O,V
10  16KB  0x00000000_04DC0000:0x00000000_04DC7FFF 0x24DC0000:0x24DC7FFF 3,O,V
11  4KB   0x00000000_04DC8000:0x00000000_04DC9FFF 0x24DC8000:0x24DC9FFF 3,O,V
12  4KB   0x00000000_04DCA000:0x00000000_04DCBFFF 0x24DCA000:0x24DCBFFF 3,O,V
13  4KB   0x00000000_04DCC000:0x00000000_04DCDFFF 0x24DCC000:0x24DCDFFF 3,W,V
14  4KB   0x00000000_04DCE000:0x00000000_04DCFFFF 0x24DCE000:0x24DCFFFF 3,W,V
15  16KB  0x00000000_04DD0000:0x00000000_04DD7FFF 0x24DD0000:0x24DD7FFF 3,W,V
16  16KB  0x00000000_04DD8000:0x00000000_04DDFFFF 0x24DD8000:0x24DDFFFF 3,W,V
17  64KB  0x00000000_04DE0000:0x00000000_04DFFFFF 0x24DE0000:0x24DFFFFF 3,W,V
18  1MB   0x00000000_04E00000:0x00000000_04FFFFFF 0x24E00000:0x24FFFFFF 3,W,V
19  4MB   0x00000000_05000000:0x00000000_057FFFFF 0x25000000:0x257FFFFF 3,W,V
20  4MB   0x00000000_05800000:0x00000000_05FFFFFF 0x25800000:0x25FFFFFF 3,W,V
21  16MB  0x00000000_06000000:0x00000000_07FFFFFF 0x26000000:0x27FFFFFF 3,W,V
22  64MB  0x00000000_08000000:0x00000000_0FFFFFFF 0x28000000:0x2FFFFFFF 3,W,V
23  16MB  0x00011B00_10000000:0x00011B00_11FFFFFF 0x10000000:0x11FFFFFF 0,W,V
24  16MB  0x00011C00_18000000:0x00011C00_19FFFFFF 0x18000000:0x19FFFFFF 0,W,V
25  64MB  0x00000004_10000000:0x00000004_17FFFFFF 0x30000000:0x37FFFFFF 0,W,V
26  64MB  0x00000004_18000000:0x00000004_1FFFFFFF 0x38000000:0x3FFFFFFF 0,W,V
27  1MB   0x00000000_0DC00000:0x00000000_0DDFFFFF 0x0DC00000:0x0DDFFFFF 0,W,V
28  1MB   0x00000000_0DE00000:0x00000000_0DFFFFFF 0x0DE00000:0x0DFFFFFF 0,W,V
29  16MB  0x00000000_0E000000:0x00000000_0FFFFFFF 0x0E000000:0x0FFFFFFF 0,W,V
0 = write-thru(wt)       1 = wt, write-allocate,    2 = uncached
3 = non-coherent         4 = coherent, excl,        5 = coh excl on write
6 = coh update on write
W = ReadWrite, O = ReadOnly,         V = Valid, I = Invalid
LED STATUS:
FRONT PANEL LED CONTROL REGISTER
SYSTEM   : GREEN
ACTIVITY : OFF
POE      : OFF
GE LINK LED, SPEED LED
PORT 0   : OFF, 0 (OFF)
PORT 1   : OFF, 0 (OFF)
LED CONTROL REGISTER (Value is number of 1/8 seconds
ON Time    : 3
OFF Time   : 3
PAUSE Time : 7
USB CONSOLE LED, RJ45 CONSOLE LED
USB        : OFF
RJ45       : GREEN
Platform Revisions/Versions :
FPGA       : 1.02   [Val = 0x102]
Board Rev  : 1      [Val = 0x10A;  Type = 10]
Env Rev    : 4.5    [Val = 0x405, Bit 15 = 0]
PSEQ Rev   : 3.05   [Val = 0x305]
I/O Ctl Nm : DA 1.1 [Val = 0x44410101]
I/O Ctl Ver: 2      [Val = 0x20315447]
CPU information :
Company ID   = 0xD
Processor ID = 0x7
Revision     = 0x8
Company OPTs = 0x0
USB Con BL : 1.01   (Boot Loader)
USB Con FW : 2.02   (Application Firmware)
USB Con FWU: 2.02   (Application Firmware Upgrade)
IOS        :
ROMMON (Readonly) :
Copyright (c) 2011 by cisco Systems, Inc.
CPU GPIO Register information :
Data Register 0x8001070000000880 = 0x30B
Pin: Config Reg Addr    Data   TX  RX_Xor Int_en Int_type fil_cnt fil_sel
0  : 0x8001070000000800   1     0    0       0      0        0      0
1  : 0x8001070000000808   1     0    0       0      0        0      0
2  : 0x8001070000000810   0     0    1       1      0        0      0
3  : 0x8001070000000818   1     0    0       0      0        0      0
4  : 0x8001070000000820   0     0    0       0      0        0      0
5  : 0x8001070000000828   0     0    0       0      0        0      0
6  : 0x8001070000000830   0     0    0       0      0        0      0
7  : 0x8001070000000838   0     0    0       0      0        0      0
8  : 0x8001070000000840   1     0    0       0      0        0      0
9  : 0x8001070000000848   1     0    0       0      0        0      0
10 : 0x8001070000000850   0     0    0       0      0        0      0
11 : 0x8001070000000858   0     0    0       0      0        0      0
12 : 0x8001070000000860   0     1    0       0      0        0      0
13 : 0x8001070000000868   0     1    0       0      0        0      0
14 : 0x8001070000000870   0     0    1       1      1        0      0
15 : 0x8001070000000878   0     0    1       1      1        0      0
io-controller global register (addr 0x10500400):
  jtag_id                                (addr 0x10500400): 0x20315447
  revision_id                            (addr 0x10500404): 0x44410101
  diag_echo                              (addr 0x10500408): 0xFFFFFFFF
  software_memory_bist                   (addr 0x1050040C): 0x00000000
  five_mhz_prescale                      (addr 0x10500410): 0x00000072
  reset_sampled_inputs                   (addr 0x10500414): 0x00000000
  slew_rate_control_gpio1                (addr 0x10500420): 0x0000FFFF
  slew_rate_control_gpio0                (addr 0x10500424): 0xFFFFFFFF
  slew_rate_control_pvdm                 (addr 0x10500428): 0x000FFFFF
  slew_rate_control_slowgpio             (addr 0x1050042C): 0x0000003F
  slew_rate_control_wic0                 (addr 0x10500430): 0x003FFFFF
  slew_rate_control_wic1                 (addr 0x10500434): 0x003FFFFF
  slew_rate_control_wic2                 (addr 0x10500438): 0x003FFFFF
  slew_rate_control_wic3                 (addr 0x1050043C): 0x003FFFFF
  wic_spi_control0                       (addr 0x10500440): 0x2455FFFF
  wic_spi_control1                       (addr 0x10500444): 0x00000000
io-controller gpio (addr 0x10500200):
  in_out_config2                         (addr 0x10500204): 0x40154415
  in_out_config1                         (addr 0x10500208): 0x44155105
  in_out_config0                         (addr 0x1050020C): 0x14504015
  polarity_ctrl1                         (addr 0x10500210): 0x0000C0C0
  polarity_ctrl0                         (addr 0x10500214): 0xC0FFFFC0
  debounce_ctrl1                         (addr 0x10500218): 0x00000000
  debounce_ctrl0                         (addr 0x1050021C): 0x00249000
  debounce_time5                         (addr 0x10500220): 0x00000000
  debounce_time4                         (addr 0x10500224): 0x00000000
  debounce_time3                         (addr 0x10500228): 0x00000000
  debounce_time2                         (addr 0x1050022C): 0x0000C351
  debounce_time1                         (addr 0x10500230): 0x0000C351
  debounce_time0                         (addr 0x10500234): 0x00000000
  reg_input_value1                       (addr 0x10500238): 0x00000000
  reg_input_value0                       (addr 0x1050023C): 0x0000803A
  reg_output_value1                      (addr 0x10500240): 0x00000202
  reg_output_value0                      (addr 0x10500244): 0x02000002
  intr_type2                             (addr 0x1050024C): 0xEFFFEFFF
  intr_type1                             (addr 0x10500250): 0xEFFFFFFF
  intr_type0                             (addr 0x10500254): 0xFFFEEFFF
  latch_unlatch_intr1                    (addr 0x10500258): 0x00000000
  latch_unlatch_intr0                    (addr 0x1050025C): 0x00000000
  err_intr_status1                       (addr 0x10500260): 0x00000000
  err_intr_status0                       (addr 0x10500264): 0x00000000
  mgmt_intr_status1                      (addr 0x10500268): 0x00000000
  mgmt_intr_status0                      (addr 0x1050026C): 0x00000000
  ntwk_intr_status1                      (addr 0x10500270): 0x00000000
  ntwk_intr_status0                      (addr 0x10500274): 0x00000000
  err_intr_enable1                       (addr 0x10500278): 0x00000000
  err_intr_enable0                       (addr 0x1050027C): 0x00000000
  mgmt_intr_enable1                      (addr 0x10500280): 0x00000000
  mgmt_intr_enable0                      (addr 0x10500284): 0x00000000
  ntwk_intr_enable1                      (addr 0x10500288): 0x00000000
  ntwk_intr_enable0                      (addr 0x1050028C): 0x00000000
  intr_test1                             (addr 0x10500290): 0x00000000
  intr_test0                             (addr 0x10500294): 0x00000000
  slow_output1                           (addr 0x105002A0): 0x00000000
  slow_output0                           (addr 0x105002A4): 0x00000000
  slow_input1                            (addr 0x105002A8): 0x00000000
  slow_input0                            (addr 0x105002AC): 0x00000008
  slow_shift_reg_config                  (addr 0x105002B0): 0x0000813E
  slow_debounce_ctrl1                    (addr 0x105002B8): 0x00000000
  slow_debounce_ctrl0                    (addr 0x105002BC): 0x00000000
  slow_debounce_time5                    (addr 0x105002C8): 0x00000000
  slow_debounce_time4                    (addr 0x105002CC): 0x00000000
  slow_debounce_time3                    (addr 0x105002D0): 0x00000000
  slow_debounce_time2                    (addr 0x105002D4): 0x00000000
  slow_debounce_time1                    (addr 0x105002D8): 0x00000000
  slow_debounce_time0                    (addr 0x105002DC): 0x00000000
  slow_func_type                         (addr 0x105002E0): 0x00000000
  slow_intr_test1                        (addr 0x105002E8): 0x00000000
  slow_intr_test0                        (addr 0x105002EC): 0x00000000
  slow_fan_tach                          (addr 0x105002F0): 0x08080808
  slow_ethernet_led_cfg                  (addr 0x105002F8): 0x00003307
  slow_ethernet_led_en                   (addr 0x105002FC): 0x00000000
  slow_intr_type3                        (addr 0x10500300): 0xFFFFFFFF
  slow_intr_type2                        (addr 0x10500304): 0xFFFFFFFF
  slow_intr_type1                        (addr 0x10500308): 0xFFFFFFFF
  slow_intr_type0                        (addr 0x1050030C): 0xFFFFFFFF
  slow_err_intr_event1                   (addr 0x10500310): 0x00000000
  slow_err_intr_event0                   (addr 0x10500314): 0x00000000
  slow_mgmt_intr_event1                  (addr 0x10500318): 0x00000000
  slow_mgmt_intr_event0                  (addr 0x1050031C): 0x00000000
  slow_ntwk_intr_event1                  (addr 0x10500320): 0x00000000
  slow_ntwk_intr_event0                  (addr 0x10500324): 0x00000000
  slow_err_intr_enable1                  (addr 0x10500328): 0x00000000
  slow_err_intr_enable0                  (addr 0x1050032C): 0x00000000
  slow_mgmt_intr_enable1                 (addr 0x10500330): 0x00000000
  slow_mgmt_intr_enable0                 (addr 0x10500334): 0x00000000
  slow_ntwk_intr_enable1                 (addr 0x10500338): 0x00000000
  slow_ntwk_intr_enable0                 (addr 0x1050033C): 0x00000000
  slow_output_polarity_ctrl1             (addr 0x10500340): 0x00000000
  slow_output_polarity_ctrl0             (addr 0x10500344): 0x00000000
  slow_input_polarity_ctrl1              (addr 0x10500348): 0x00000000
  slow_input_polarity_ctrl0              (addr 0x1050034C): 0x00000000
io-controller hdlc 0 (addr 0x10400000):
  h_status                               (addr 0x10400000): 0x00000000
  h_edtbar                               (addr 0x10400004): 0x0E94A000
  h_idtbar                               (addr 0x10400008): 0x0E94C000
  h_cer                                  (addr 0x1040000C): 0x00000000
  h_edavnr                               (addr 0x10400010): 0x00000000
  h_ebrr                                 (addr 0x10400014): 0x00000000
  h_ipqnr                                (addr 0x10400018): 0x00000000
  h_eer                                  (addr 0x1040001C): 0x00000000
  h_ier                                  (addr 0x10400020): 0x00000000
  h_ilur                                 (addr 0x10400024): 0x00000000
  ca_cr                                  (addr 0x10400028): 0x00000000
  h_ccr                                  (addr 0x1040002C): 0x00000000
  h_ctrl                                 (addr 0x10400030): 0x0000006F
  h_imfsr                                (addr 0x10400034): 0x0000FFFF
  h_ifser                                (addr 0x10400038): 0x00000000
  h_tdmcr                                (addr 0x1040003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10400100): 0x00000000
  dbg_data_lower                         (addr 0x10400104): 0x00000000
  dbg_data_upper                         (addr 0x10400108): 0x00000000
  h_frm_cnt                              (addr 0x1040010C): 0x00000000
  h_mem_pesr                             (addr 0x10400110): 0x00000000
  h_mem_pecr                             (addr 0x10400114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10400118): 0x00000007
  h_imem_buf_pear                        (addr 0x1040011C): 0x000000A7
  h_echn_am_pear                         (addr 0x10400120): 0x00000038
  h_ichn_am_pear                         (addr 0x10400124): 0x0000007C
  h_parerr_inject                        (addr 0x10400128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10400200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10400204): 0x0000007F
hdlc_ca_lh (addr 0x10400400 - 0x104005FF):
       0: 00000000 00000000 00000000 00000000  ................
      16: 00000000 00000000 00000000 00000000  ................
      32: 00000000 00000000 00000000 00000000  ................
      48: 00000000 00000000 00000000 00000000  ................
      64: 00000000 00000000 00000000 00000000  ................
      80: 00000000 00000000 00000000 00000000  ................
      96: 00000000 00000000 00000000 00000000  ................
     112: 00000000 00000000 00000000 00000000  ................
     128: 00000000 00000000 00000000 00000000  ................
     144: 00000000 00000000 00000000 00000000  ................
     160: 00000000 00000000 00000000 00000000  ................
     176: 00000000 00000000 00000000 00000000  ................
     192: 00000000 00000000 00000000 00000000  ................
     208: 00000000 00000000 00000000 00000000  ................
     224: 00000000 00000000 00000000 00000000  ................
     240: 00000000 00000000 00000000 00000000  ................
     256: 00000000 00000000 00000000 00000000  ................
     272: 00000000 00000000 00000000 00000000  ................
     288: 00000000 00000000 00000000 00000000  ................
     304: 00000000 00000000 00000000 00000000  ................
     320: 00000000 00000000 00000000 00000000  ................
     336: 00000000 00000000 00000000 00000000  ................
     352: 00000000 00000000 00000000 00000000  ................
     368: 00000000 00000000 00000000 00000000  ................
     384: 00000000 00000000 00000000 00000000  ................
     400: 00000000 00000000 00000000 00000000  ................
     416: 00000000 00000000 00000000 00000000  ................
     432: 00000000 00000000 00000000 00000000  ................
     448: 00000000 00000000 00000000 00000000  ................
     464: 00000000 00000000 00000000 00000000  ................
     480: 00000000 00000000 00000000 00000000  ................
     496: 00000000 00000000 00000000 00000000  ................
     512:
hdlc_ca_uh (addr 0x10400600 - 0x104007FF):
     512:
io-controller hdlc 1 (addr 0x10410000):
  h_status                               (addr 0x10410000): 0x00000000
  h_edtbar                               (addr 0x10410004): 0x0E94E000
  h_idtbar                               (addr 0x10410008): 0x0E950000
  h_cer                                  (addr 0x1041000C): 0x00000000
  h_edavnr                               (addr 0x10410010): 0x00000000
  h_ebrr                                 (addr 0x10410014): 0x00000000
  h_ipqnr                                (addr 0x10410018): 0x00000000
  h_eer                                  (addr 0x1041001C): 0x00000000
  h_ier                                  (addr 0x10410020): 0x00000000
  h_ilur                                 (addr 0x10410024): 0x00000000
  ca_cr                                  (addr 0x10410028): 0x00000000
  h_ccr                                  (addr 0x1041002C): 0x00000000
  h_ctrl                                 (addr 0x10410030): 0x0000006F
  h_imfsr                                (addr 0x10410034): 0x0000FFFF
  h_ifser                                (addr 0x10410038): 0x00000000
  h_tdmcr                                (addr 0x1041003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10410100): 0x00000000
  dbg_data_lower                         (addr 0x10410104): 0x00000000
  dbg_data_upper                         (addr 0x10410108): 0x00000000
  h_frm_cnt                              (addr 0x1041010C): 0x00000000
  h_mem_pesr                             (addr 0x10410110): 0x00000000
  h_mem_pecr                             (addr 0x10410114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10410118): 0x00000007
  h_imem_buf_pear                        (addr 0x1041011C): 0x0000000F
  h_echn_am_pear                         (addr 0x10410120): 0x0000007C
  h_ichn_am_pear                         (addr 0x10410124): 0x0000007C
  h_parerr_inject                        (addr 0x10410128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10410200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10410204): 0x0000007F
hdlc_ca_lh (addr 0x10410400 - 0x104105FF):
     512:
hdlc_ca_uh (addr 0x10410600 - 0x104107FF):
     512:
io-controller hdlc 2 (addr 0x10420000):
  h_status                               (addr 0x10420000): 0x00000000
  h_edtbar                               (addr 0x10420004): 0x0E952000
  h_idtbar                               (addr 0x10420008): 0x0E954000
  h_cer                                  (addr 0x1042000C): 0x00000000
  h_edavnr                               (addr 0x10420010): 0x00000000
  h_ebrr                                 (addr 0x10420014): 0x00000000
  h_ipqnr                                (addr 0x10420018): 0x00000000
  h_eer                                  (addr 0x1042001C): 0x00000000
  h_ier                                  (addr 0x10420020): 0x00000000
  h_ilur                                 (addr 0x10420024): 0x00000000
  ca_cr                                  (addr 0x10420028): 0x00000000
  h_ccr                                  (addr 0x1042002C): 0x00000000
  h_ctrl                                 (addr 0x10420030): 0x0000006F
  h_imfsr                                (addr 0x10420034): 0x0000FFFF
  h_ifser                                (addr 0x10420038): 0x00000000
  h_tdmcr                                (addr 0x1042003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10420100): 0x00000000
  dbg_data_lower                         (addr 0x10420104): 0x00000000
  dbg_data_upper                         (addr 0x10420108): 0x00000000
  h_frm_cnt                              (addr 0x1042010C): 0x00000000
  h_mem_pesr                             (addr 0x10420110): 0x00000000
  h_mem_pecr                             (addr 0x10420114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10420118): 0x00000007
  h_imem_buf_pear                        (addr 0x1042011C): 0x00000087
  h_echn_am_pear                         (addr 0x10420120): 0x00000004
  h_ichn_am_pear                         (addr 0x10420124): 0x0000007C
  h_parerr_inject                        (addr 0x10420128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10420200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10420204): 0x0000007F
hdlc_ca_lh (addr 0x10420400 - 0x104205FF):
     512:
hdlc_ca_uh (addr 0x10420600 - 0x104207FF):
     512:
io-controller hdlc 3 (addr 0x10430000):
  h_status                               (addr 0x10430000): 0x00000000
  h_edtbar                               (addr 0x10430004): 0x0E956000
  h_idtbar                               (addr 0x10430008): 0x0E958000
  h_cer                                  (addr 0x1043000C): 0x00000000
  h_edavnr                               (addr 0x10430010): 0x00000000
  h_ebrr                                 (addr 0x10430014): 0x00000000
  h_ipqnr                                (addr 0x10430018): 0x00000000
  h_eer                                  (addr 0x1043001C): 0x00000000
  h_ier                                  (addr 0x10430020): 0x00000000
  h_ilur                                 (addr 0x10430024): 0x00000000
  ca_cr                                  (addr 0x10430028): 0x00000000
  h_ccr                                  (addr 0x1043002C): 0x00000000
  h_ctrl                                 (addr 0x10430030): 0x0000006F
  h_imfsr                                (addr 0x10430034): 0x0000FFFF
  h_ifser                                (addr 0x10430038): 0x00000000
  h_tdmcr                                (addr 0x1043003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10430100): 0x00000000
  dbg_data_lower                         (addr 0x10430104): 0x00000000
  dbg_data_upper                         (addr 0x10430108): 0x00000000
  h_frm_cnt                              (addr 0x1043010C): 0x00000000
  h_mem_pesr                             (addr 0x10430110): 0x00000000
  h_mem_pecr                             (addr 0x10430114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10430118): 0x00000007
  h_imem_buf_pear                        (addr 0x1043011C): 0x0000000F
  h_echn_am_pear                         (addr 0x10430120): 0x00000004
  h_ichn_am_pear                         (addr 0x10430124): 0x0000007C
  h_parerr_inject                        (addr 0x10430128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10430200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10430204): 0x0000007F
hdlc_ca_lh (addr 0x10430400 - 0x104305FF):
     512:
hdlc_ca_uh (addr 0x10430600 - 0x104307FF):
     512:
Device Node 0 io-controller hsib (addr 0x107F0000):
  dn_ctrl                                (addr 0x107F0000): 0x00000027
  dn_initiator_thlv                      (addr 0x107F0004): 0x00080808
  dn_target_thlv                         (addr 0x107F0008): 0x00080808
  dn_status                              (addr 0x107F000C): 0x00000002
  dn_initiator_error                     (addr 0x107F0010): 0x00000000
  dn_target_error                        (addr 0x107F0014): 0x00000000
  dn_initiator_error_mask                (addr 0x107F0018): 0x00000000
  dn_target_error_mask                   (addr 0x107F001C): 0x00000000
  dn_node_id                             (addr 0x107F0020): 0x00000000
  dn_target_online                       (addr 0x107F0024): 0x000000E7
  dn_first_error_hsib_hdr                (addr 0x107F0028): 0x00000000
  dn_first_error_address                 (addr 0x107F002C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x107F0030): 0x00000000
  dn_first_error_address                 (addr 0x107F0034): 0x00000000
  dn_aux_ctrl                            (addr 0x107F0050): 0x00000329
  dn_timeout_ctrl                        (addr 0x107F0054): 0x00000000
  dn_timer                               (addr 0x107F0058): 0x00027AFC
  hsib_no_lut_priority                   (addr 0x107F005C): 0x00000000
LUT Entry 0  LUT (addr 0x107F0060):
  lut_ctrl                               (addr 0x107F0060): 0x80100040
  base_limit                             (addr 0x107F0064): 0x103F1000
LUT Entry 1  LUT (addr 0x107F0068):
  lut_ctrl                               (addr 0x107F0068): 0x80100080
  base_limit                             (addr 0x107F006C): 0x104F1040
LUT Entry 2  LUT (addr 0x107F0070):
  lut_ctrl                               (addr 0x107F0070): 0x80120020
  base_limit                             (addr 0x107F0074): 0x10551050
LUT Entry 3  LUT (addr 0x107F0078):
  lut_ctrl                               (addr 0x107F0078): 0x80100040
  base_limit                             (addr 0x107F007C): 0x107E107E
Device Node 1 io-controller hsib (addr 0x107F1000):
  dn_ctrl                                (addr 0x107F1000): 0x0000001B
  dn_initiator_thlv                      (addr 0x107F1004): 0x00080404
  dn_target_thlv                         (addr 0x107F1008): 0x0004020E
  dn_status                              (addr 0x107F100C): 0x00000000
  dn_initiator_error                     (addr 0x107F1010): 0x00000000
  dn_target_error                        (addr 0x107F1014): 0x00000000
  dn_initiator_error_mask                (addr 0x107F1018): 0x00000000
  dn_target_error_mask                   (addr 0x107F101C): 0x00000000
  dn_node_id                             (addr 0x107F1020): 0x00000001
  dn_target_online                       (addr 0x107F1024): 0x000000E7
  dn_first_error_hsib_hdr                (addr 0x107F1028): 0x00000000
  dn_first_error_address                 (addr 0x107F102C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x107F1030): 0x00000000
  dn_first_error_address                 (addr 0x107F1034): 0x00000000
  dn_aux_ctrl                            (addr 0x107F1050): 0x0000032B
  dn_timeout_ctrl                        (addr 0x107F1054): 0x00000000
  dn_timer                               (addr 0x107F1058): 0x0004FD14
  hsib_no_lut_priority                   (addr 0x107F105C): 0x00000000
LUT Entry 0  LUT (addr 0x107F1060):
  lut_ctrl                               (addr 0x107F1060): 0x00000000
  base_limit                             (addr 0x107F1064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x107F1068):
  lut_ctrl                               (addr 0x107F1068): 0x00000000
  base_limit                             (addr 0x107F106C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x107F1070):
  lut_ctrl                               (addr 0x107F1070): 0x00000000
  base_limit                             (addr 0x107F1074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x107F1078):
  lut_ctrl                               (addr 0x107F1078): 0x00000000
  base_limit                             (addr 0x107F107C): 0x0000FFFF
Device Node 2 io-controller hsib (addr 0x107F2000):
  dn_ctrl                                (addr 0x107F2000): 0x0000001B
  dn_initiator_thlv                      (addr 0x107F2004): 0x00080404
  dn_target_thlv                         (addr 0x107F2008): 0x0004020E
  dn_status                              (addr 0x107F200C): 0x00000000
  dn_initiator_error                     (addr 0x107F2010): 0x00000000
  dn_target_error                        (addr 0x107F2014): 0x00000000
  dn_initiator_error_mask                (addr 0x107F2018): 0x00000000
  dn_target_error_mask                   (addr 0x107F201C): 0x00000000
  dn_node_id                             (addr 0x107F2020): 0x00000002
  dn_target_online                       (addr 0x107F2024): 0x000000E7
  dn_first_error_hsib_hdr                (addr 0x107F2028): 0x00000000
  dn_first_error_address                 (addr 0x107F202C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x107F2030): 0x00000000
  dn_first_error_address                 (addr 0x107F2034): 0x00000000
  dn_aux_ctrl                            (addr 0x107F2050): 0x0000032B
  dn_timeout_ctrl                        (addr 0x107F2054): 0x00000000
  dn_timer                               (addr 0x107F2058): 0x0007EEC9
  hsib_no_lut_priority                   (addr 0x107F205C): 0x00000000
LUT Entry 0  LUT (addr 0x107F2060):
  lut_ctrl                               (addr 0x107F2060): 0x00000000
  base_limit                             (addr 0x107F2064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x107F2068):
  lut_ctrl                               (addr 0x107F2068): 0x00000000
  base_limit                             (addr 0x107F206C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x107F2070):
  lut_ctrl                               (addr 0x107F2070): 0x00000000
  base_limit                             (addr 0x107F2074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x107F2078):
  lut_ctrl                               (addr 0x107F2078): 0x00000000
  base_limit                             (addr 0x107F207C): 0x0000FFFF
Device Node 5 io-controller hsib (addr 0x107F5000):
  dn_ctrl                                (addr 0x107F5000): 0x0000001B
  dn_initiator_thlv                      (addr 0x107F5004): 0x00040404
  dn_target_thlv                         (addr 0x107F5008): 0x00040404
  dn_status                              (addr 0x107F500C): 0x00000000
  dn_initiator_error                     (addr 0x107F5010): 0x00000000
  dn_target_error                        (addr 0x107F5014): 0x00000000
  dn_initiator_error_mask                (addr 0x107F5018): 0x00000000
  dn_target_error_mask                   (addr 0x107F501C): 0x00000000
  dn_node_id                             (addr 0x107F5020): 0x00000005
  dn_target_online                       (addr 0x107F5024): 0x000000E7
  dn_first_error_hsib_hdr                (addr 0x107F5028): 0x00000000
  dn_first_error_address                 (addr 0x107F502C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x107F5030): 0x00000000
  dn_first_error_address                 (addr 0x107F5034): 0x00000000
  dn_aux_ctrl                            (addr 0x107F5050): 0x0000013B
  dn_timeout_ctrl                        (addr 0x107F5054): 0x00000000
  dn_timer                               (addr 0x107F5058): 0x000A70BA
  hsib_no_lut_priority                   (addr 0x107F505C): 0x00000130
LUT Entry 0  LUT (addr 0x107F5060):
  lut_ctrl                               (addr 0x107F5060): 0x00000000
  base_limit                             (addr 0x107F5064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x107F5068):
  lut_ctrl                               (addr 0x107F5068): 0x00000000
  base_limit                             (addr 0x107F506C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x107F5070):
  lut_ctrl                               (addr 0x107F5070): 0x00000000
  base_limit                             (addr 0x107F5074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x107F5078):
  lut_ctrl                               (addr 0x107F5078): 0x00000000
  base_limit                             (addr 0x107F507C): 0x0000FFFF
io-controller hwic0 (addr 0x107E0000):
    scratch_reg                          (addr 0x107E0100): 0xA0A1A2A3
    err_reg0                             (addr 0x107E0104): 0x00000000
    err_reg1                             (addr 0x107E0108): 0x00000000
    extnd_reg_err_info                   (addr 0x107E010C): 0x00000000
    cfg_reg                              (addr 0x107E0110): 0x00072701
    oir_reg                              (addr 0x107E0114): 0x00000000
    ram_err_injection_reg                (addr 0x107E0118): 0x00000000
    egr_cache_debug_reg                  (addr 0x107E011C): 0x00000107
    err_int_en_reg0                      (addr 0x107E0120): 0x00000000
    err_int_en_reg1                      (addr 0x107E0124): 0x00000000
io-controller hwic1 (addr 0x107E4000):
    scratch_reg                          (addr 0x107E4100): 0xA0A1A2A3
    err_reg0                             (addr 0x107E4104): 0x00000000
    err_reg1                             (addr 0x107E4108): 0x00000000
    extnd_reg_err_info                   (addr 0x107E410C): 0x00000000
    cfg_reg                              (addr 0x107E4110): 0x00072701
    oir_reg                              (addr 0x107E4114): 0x00000000
    ram_err_injection_reg                (addr 0x107E4118): 0x00000000
    egr_cache_debug_reg                  (addr 0x107E411C): 0x00000107
    err_int_en_reg0                      (addr 0x107E4120): 0x00000000
    err_int_en_reg1                      (addr 0x107E4124): 0x00000000
io-controller interrupts (addr 0x10500000):
  cpu1_network_intr_enable               (addr 0x10500000): 0x1C020FFF
  cpu1_mgmt_intr_enable                  (addr 0x10500008): 0x00000000
  cpu1_error_intr_enable                 (addr 0x1050000C): 0x7C3F0FFF
  cpu2_network_intr_enable               (addr 0x10500010): 0x00000000
  cpu2_mgmt_intr_enable                  (addr 0x10500018): 0x00000000
  cpu2_error_intr_enable                 (addr 0x1050001C): 0x00000000
  redirect_ntwk_intr_en                  (addr 0x10500020): 0x00000000
  redirect_mgmt_intr_en                  (addr 0x10500028): 0x00000000
  redirect_err_intr_en                   (addr 0x1050002C): 0x00000000
  network interrupt status               (addr 0x10500030): 0x00000000
  mgmt interrupt status                  (addr 0x10500038): 0x00000000
  error interrupt status                 (addr 0x1050003C): 0x00000000
  msi_intr_relax_order                   (addr 0x10500040): 0x00000000
  hsib_error_intr_enable                 (addr 0x10500048): 0x0000FC03
  hsib_error_intr_status                 (addr 0x1050004C): 0x00000000
  hisb_en_error_pcie0low                 (addr 0x10500050): 0x001FFFFE
  hisb_en_error_pcie0high                (addr 0x10500054): 0x00FFFFFF
  hisb_en_error_pcie1low                 (addr 0x10500058): 0x00000000
  hisb_en_error_pcie1high                (addr 0x1050005C): 0x00000000
  hisb_en_error_pcie2low                 (addr 0x10500060): 0x00000000
  hisb_en_error_pcie2high                (addr 0x10500064): 0x00000000
  hisb_en_error_pcie3low                 (addr 0x10500068): 0x00000000
  hisb_en_error_pcie3high                (addr 0x1050006C): 0x00000000
  hisb_en_error_pcie4low                 (addr 0x10500070): 0x00000000
  hisb_en_error_pcie4high                (addr 0x10500074): 0x00000000
  hsib_en_error_glb_reg_low              (addr 0x10500078): 0x001FFFFE
  hsib_en_error_glb_reg_high             (addr 0x1050007C): 0x00FFFFFF
  hsib_en_error_hwic_low                 (addr 0x10500080): 0x001FFFFE
  hsib_en_error_hwic_high                (addr 0x10500084): 0x00FFFFFF
  hsib_en_error_wan_low                  (addr 0x10500088): 0x001FFFFE
  hsib_en_error_wan_high                 (addr 0x1050008C): 0x00FFFFFF
  hsib_error_event_pcie0low              (addr 0x10500090): 0x00000000
  hsib_error_event_pcie0high             (addr 0x10500094): 0x00000000
  hsib_error_event_pcie1low              (addr 0x10500098): 0x00000000
  hsib_error_event_pcie1high             (addr 0x1050009C): 0x00000000
  hsib_error_event_pcie2low              (addr 0x105000A0): 0x00000000
  hsib_error_event_pcie2high             (addr 0x105000A4): 0x00000000
  hsib_error_event_pcie3low              (addr 0x105000A8): 0x00000000
  hsib_error_event_pcie3high             (addr 0x105000AC): 0x00000000
  hsib_error_event_pcie4low              (addr 0x105000B0): 0x00000000
  hsib_error_event_pcie4high             (addr 0x105000B4): 0x00000000
  hsib_error_event_glb_reg_low           (addr 0x105000B8): 0x00000000
  hsib_error_event_glb_reg_high          (addr 0x105000BC): 0x00000000
  hsib_error_event_hwic_low              (addr 0x105000C0): 0x00000000
  hsib_error_event_hwic_high             (addr 0x105000C4): 0x00000000
  hsib_error_event_wan_low               (addr 0x105000C8): 0x00000000
  hsib_error_event_wan_high              (addr 0x105000CC): 0x00000000
  i2c_master_intr_en                     (addr 0x105000D0): 0x00000000
  i2c_master_intr_status                 (addr 0x105000D4): 0x00000000
  pcie_err_intr_en                       (addr 0x105000D8): 0x00000000
  pcie_err_event                         (addr 0x105000DC): 0x00000000
  interrupt_delay_gpio 0                 (addr 0x105000E0): 0x00000000
  interrupt_dleay_gpio 1                 (addr 0x105000E4): 0x00000000
  interrupt_delay_gpio 2                 (addr 0x105000E8): 0x00000000
  interrupt_delay_gpio 3                 (addr 0x105000EC): 0x00000000
  interrupt_delay_hdlc 0                 (addr 0x105000F0): 0x00000000
  interrupt_delay_hdlc 1                 (addr 0x105000F4): 0x00000000
  interrupt_delay_hdlc 2                 (addr 0x105000F8): 0x00000000
  interrupt_delay_hdlc 3                 (addr 0x105000FC): 0x00000000
  interrupt_delay_hdlc 4                 (addr 0x10500100): 0x00000000
  interrupt_delay_hdlc 5                 (addr 0x10500104): 0x00000000
  interrupt_delay_hdlc 6                 (addr 0x10500108): 0x00000000
  interrupt_delay_hdlc 7                 (addr 0x1050010C): 0x00000000
  interrupt_delay_hwic 0                 (addr 0x10500110): 0x00000000
  interrupt_delay_hwic 1                 (addr 0x10500114): 0x00000000
  interrupt_delay_hwic 2                 (addr 0x10500118): 0x00000000
  interrupt_delay_hwic 3                 (addr 0x1050011C): 0x00000000
  interrupt_delay_scc                    (addr 0x10500120): 0x00000000
  interrupt_delay_packet_pump            (addr 0x10500124): 0x00000000
  cpu1_cap_ntwk_pcie_msi0                (addr 0x10500140): 0x015B5400
  cpu1_cap_ntwk_pcie_msi1                (addr 0x10500144): 0x0000BCB0
  cpu1_cap_ntwk_pcie_msi2                (addr 0x10500148): 0x00000080
  cpu1_cap_ntwk_pcie_msi3                (addr 0x1050014C): 0xE3FDF000
  cpu1_cap_ntwk_pcie_msi4                (addr 0x10500150): 0x00000000
  cpu1_cap_mgmt_pcie_msi0                (addr 0x10500154): 0x010A6800
  cpu1_cap_mgmt_pcie_msi1                (addr 0x10500158): 0x00000000
  cpu1_cap_mgmt_pcie_msi2                (addr 0x1050015C): 0x00000000
  cpu1_cap_mgmt_pcie_msi3                (addr 0x10500160): 0xFFFFFFFF
  cpu1_cap_mgmt_pcie_msi4                (addr 0x10500164): 0x00000000
  cpu1_cap_error_pcie_msi0               (addr 0x10500168): 0x015B7C00
  cpu1_cap_error_pcie_msi1               (addr 0x1050016C): 0x0000BCB0
  cpu1_cap_error_pcie_msi2               (addr 0x10500170): 0x000000C0
  cpu1_cap_error_pcie_msi3               (addr 0x10500174): 0x00000000
  cpu1_cap_error_pcie_msi4               (addr 0x10500178): 0x00000000
  cpu2_cap_ntwk_pcie_msi0                (addr 0x1050017C): 0x010A9000
  cpu2_cap_ntwk_pcie_msi1                (addr 0x10500180): 0x00000000
  cpu2_cap_ntwk_pcie_msi2                (addr 0x10500184): 0x00000000
  cpu2_cap_ntwk_pcie_msi3                (addr 0x10500188): 0xFFFFFFFF
  cpu2_cap_ntwk_pcie_msi4                (addr 0x1050018C): 0x00000000
  cpu2_cap_mgmt_pcie_msi0                (addr 0x10500190): 0x010AA400
  cpu2_cap_mgmt_pcie_msi1                (addr 0x10500194): 0x00000000
  cpu2_cap_mgmt_pcie_msi2                (addr 0x10500198): 0x00000000
  cpu2_cap_mgmt_pcie_msi3                (addr 0x1050019C): 0xFFFFFFFF
  cpu2_cap_mgmt_pcie_msi4                (addr 0x105001A0): 0x00000000
  cpu2_cap_error_pcie_msi0               (addr 0x105001A4): 0x010AB800
  cpu2_cap_error_pcie_msi1               (addr 0x105001A8): 0x00000000
  cpu2_cap_error_pcie_msi2               (addr 0x105001AC): 0x00000000
  cpu2_cap_error_pcie_msi3               (addr 0x105001B0): 0xFFFFFFFF
  cpu2_cap_error_pcie_msi4               (addr 0x105001B4): 0x00000000
io-controller reset controller (addr 0x10500480):
  dn_reset                               (addr 0x10500480): 0x00000000
  function_block_reset                   (addr 0x10500484): 0x00000000
  host_cpu_reset                         (addr 0x10500488): 0x00000000
  ioctrl_warm_reset                      (addr 0x1050048C): 0x00000000
  host_system_reset                      (addr 0x10500490): 0x00000000
WatchDog 0
  wdog_timer_limit                       (addr 0x10500494): 0x01312D00
  wdog_timer_service                     (addr 0x10500498): 0x00000004
  wdog_timer_enable                      (addr 0x1050049C): 0x00000002
  wdog_timer_trigger_level               (addr 0x105004A0): 0x00000000
WatchDog 1
  wdog_timer_limit                       (addr 0x105004A4): 0x00FFFFFF
  wdog_timer_service                     (addr 0x105004A8): 0x00000000
  wdog_timer_enable                      (addr 0x105004AC): 0x00000000
  wdog_timer_trigger_level               (addr 0x105004B0): 0x00000000
  reset_status                           (addr 0x105004B4): 0x00000100
io-controller scc (addr 0x10490000):
  STI_errintr_status                     (addr 0x10490004): 0x00000000
  STI_errintr_enable                     (addr 0x10490008): 0x7FFFFFFF
  SCC_ctrl_regs                          (addr 0x10491004):     0x0000
  mgmt_intr_status                       (addr 0x10491010):     0x0010
  netio_intr_status                      (addr 0x10491012):     0x0000
  timer_0_7_status                       (addr 0x10491014):     0x0000
  timer_16_19_status                     (addr 0x10491016):     0x0000
  mgmt_intr_enable                       (addr 0x10491020):     0x0002
  netio_intr_enable                      (addr 0x10491022):     0x0000
  timer_0_7_enable                       (addr 0x10491024):     0x0000
  timer_16_19_enable                     (addr 0x10491026):     0x0000
  timer_0_1_program                      (addr 0x10491030):     0x0000
  timer_2_3_program                      (addr 0x10491032):     0x0000
  timer_4_5_program                      (addr 0x10491034):     0x0000
  timer_6_7_program                      (addr 0x10491036):     0x0000
  timer_16_program                       (addr 0x10491040):     0x0000
  timer_17_program                       (addr 0x10491042):     0x0000
  timer_18_program                       (addr 0x10491044):     0x0000
  timer_19_program                       (addr 0x10491046):     0x0000
  scc_regs[0].ch_mode_cfg                (addr 0x10491100): 0x10019030
  scc_regs[0].ch_flag_cfg                (addr 0x10491104):     0x0000
  scc_regs[0].ch_flwctrl_cfg             (addr 0x10491108):     0x0000
  scc_regs[0].ch_intr_status             (addr 0x1049110A):     0x0000
  scc_regs[0].ch_intr_enable             (addr 0x1049110C):     0x0000
  scc_regs[0].ch_cmd_stat                (addr 0x1049110E):     0x0028
  scc_regs[1].ch_mode_cfg                (addr 0x10491110): 0x10019030
  scc_regs[1].ch_flag_cfg                (addr 0x10491114):     0x0000
  scc_regs[1].ch_flwctrl_cfg             (addr 0x10491118):     0x0000
  scc_regs[1].ch_intr_status             (addr 0x1049111A):     0x0000
  scc_regs[1].ch_intr_enable             (addr 0x1049111C):     0x0000
  scc_regs[1].ch_cmd_stat                (addr 0x1049111E):     0x0028
  scc_regs[2].ch_mode_cfg                (addr 0x10491120): 0x10019030
  scc_regs[2].ch_flag_cfg                (addr 0x10491124):     0x0000
  scc_regs[2].ch_flwctrl_cfg             (addr 0x10491128):     0x0000
  scc_regs[2].ch_intr_status             (addr 0x1049112A):     0x0000
  scc_regs[2].ch_intr_enable             (addr 0x1049112C):     0x0000
  scc_regs[2].ch_cmd_stat                (addr 0x1049112E):     0x0028
  scc_regs[3].ch_mode_cfg                (addr 0x10491130): 0x10019030
  scc_regs[3].ch_flag_cfg                (addr 0x10491134):     0x0000
  scc_regs[3].ch_flwctrl_cfg             (addr 0x10491138):     0x0000
  scc_regs[3].ch_intr_status             (addr 0x1049113A):     0x0000
  scc_regs[3].ch_intr_enable             (addr 0x1049113C):     0x0000
  scc_regs[3].ch_cmd_stat                (addr 0x1049113E):     0x0028
  rx_dma_regs[0].ring_start_ptr          (addr 0x10492000): 0x00000000
  rx_dma_regs[0].ring_mask_index         (addr 0x10492004): 0x00000000
  rx_dma_regs[0].dma_internal_desc_stat  (addr 0x10492008): 0x00000000
  rx_dma_regs[0].dma_internal_buff_addr  (addr 0x1049200C): 0x00000000
  rx_dma_regs[0].dma_internal_context    (addr 0x10492010): 0x00000000
  rx_dma_regs[0].dma_internal_fifo_data  (addr 0x10492014): 0x00000000
  rx_dma_regs[1].ring_start_ptr          (addr 0x10492020): 0x00000000
  rx_dma_regs[1].ring_mask_index         (addr 0x10492024): 0x00000000
  rx_dma_regs[1].dma_internal_desc_stat  (addr 0x10492028): 0x00000000
  rx_dma_regs[1].dma_internal_buff_addr  (addr 0x1049202C): 0x00000000
  rx_dma_regs[1].dma_internal_context    (addr 0x10492030): 0x00000000
  rx_dma_regs[1].dma_internal_fifo_data  (addr 0x10492034): 0x00000000
  rx_dma_regs[2].ring_start_ptr          (addr 0x10492040): 0x00000000
  rx_dma_regs[2].ring_mask_index         (addr 0x10492044): 0x00000000
  rx_dma_regs[2].dma_internal_desc_stat  (addr 0x10492048): 0x00000000
  rx_dma_regs[2].dma_internal_buff_addr  (addr 0x1049204C): 0x00000000
  rx_dma_regs[2].dma_internal_context    (addr 0x10492050): 0x00000000
  rx_dma_regs[2].dma_internal_fifo_data  (addr 0x10492054): 0x00000000
  rx_dma_regs[3].ring_start_ptr          (addr 0x10492060): 0x00000000
  rx_dma_regs[3].ring_mask_index         (addr 0x10492064): 0x00000000
  rx_dma_regs[3].dma_internal_desc_stat  (addr 0x10492068): 0x00000000
  rx_dma_regs[3].dma_internal_buff_addr  (addr 0x1049206C): 0x00000000
  rx_dma_regs[3].dma_internal_context    (addr 0x10492070): 0x00000000
  rx_dma_regs[3].dma_internal_fifo_data  (addr 0x10492074): 0x00000000
  tx_dma_regs[0].ring_start_ptr          (addr 0x10492200): 0x00000000
  tx_dma_regs[0].ring_mask_index         (addr 0x10492204): 0x00000000
  tx_dma_regs[0].dma_internal_desc_stat  (addr 0x10492208): 0x00000000
  tx_dma_regs[0].dma_internal_buff_addr  (addr 0x1049220C): 0x00000000
  tx_dma_regs[0].dma_internal_context    (addr 0x10492210): 0x00000000
  tx_dma_regs[0].dma_internal_fifo_data  (addr 0x10492214): 0x00000000
  tx_dma_regs[1].ring_start_ptr          (addr 0x10492220): 0x00000000
  tx_dma_regs[1].ring_mask_index         (addr 0x10492224): 0x00000000
  tx_dma_regs[1].dma_internal_desc_stat  (addr 0x10492228): 0x00000000
  tx_dma_regs[1].dma_internal_buff_addr  (addr 0x1049222C): 0x00000000
  tx_dma_regs[1].dma_internal_context    (addr 0x10492230): 0x00000000
  tx_dma_regs[1].dma_internal_fifo_data  (addr 0x10492234): 0x00000000
  tx_dma_regs[2].ring_start_ptr          (addr 0x10492240): 0x00000000
  tx_dma_regs[2].ring_mask_index         (addr 0x10492244): 0x00000000
  tx_dma_regs[2].dma_internal_desc_stat  (addr 0x10492248): 0x00000000
  tx_dma_regs[2].dma_internal_buff_addr  (addr 0x1049224C): 0x00000000
  tx_dma_regs[2].dma_internal_context    (addr 0x10492250): 0x00000000
  tx_dma_regs[2].dma_internal_fifo_data  (addr 0x10492254): 0x00000000
  tx_dma_regs[3].ring_start_ptr          (addr 0x10492260): 0x00000000
  tx_dma_regs[3].ring_mask_index         (addr 0x10492264): 0x00000000
  tx_dma_regs[3].dma_internal_desc_stat  (addr 0x10492268): 0x00000000
  tx_dma_regs[3].dma_internal_buff_addr  (addr 0x1049226C): 0x00000000
  tx_dma_regs[3].dma_internal_context    (addr 0x10492270): 0x00000000
  tx_dma_regs[3].dma_internal_fifo_data  (addr 0x10492274): 0x00000000
  txbsc_regs[0].context_cfg_pad_char     (addr 0x10492400): 0x00000000
  txbsc_regs[1].context_cfg_pad_char     (addr 0x10492410): 0x00000000
  txbsc_regs[2].context_cfg_pad_char     (addr 0x10492420): 0x00000000
  txbsc_regs[3].context_cfg_pad_char     (addr 0x10492430): 0x00000000
  txppp_regs[0].accm_map                 (addr 0x10492600): 0x00000000
  txppp_regs[0].special_char             (addr 0x10492604): 0x00000000
  txppp_regs[0].context                  (addr 0x1049260C): 0x00000000
  txppp_regs[1].accm_map                 (addr 0x10492610): 0x00000000
  txppp_regs[1].special_char             (addr 0x10492614): 0x00000000
  txppp_regs[1].context                  (addr 0x1049261C): 0x00000000
  txppp_regs[2].accm_map                 (addr 0x10492620): 0x00000000
  txppp_regs[2].special_char             (addr 0x10492624): 0x00000000
  txppp_regs[2].context                  (addr 0x1049262C): 0x00000000
  txppp_regs[3].accm_map                 (addr 0x10492630): 0x00000000
  txppp_regs[3].special_char             (addr 0x10492634): 0x00000000
  txppp_regs[3].context                  (addr 0x1049263C): 0x00000000
  rxppp_regs[0].accm_map                 (addr 0x10492800): 0x00000000
  rxppp_regs[0].special_char             (addr 0x10492804): 0x00000000
  rxppp_regs[0].context                  (addr 0x1049280C): 0x00000000
  rxppp_regs[1].accm_map                 (addr 0x10492810): 0x00000000
  rxppp_regs[1].special_char             (addr 0x10492814): 0x00000000
  rxppp_regs[1].context                  (addr 0x1049281C): 0x00000000
  rxppp_regs[2].accm_map                 (addr 0x10492820): 0x00000000
  rxppp_regs[2].special_char             (addr 0x10492824): 0x00000000
  rxppp_regs[2].context                  (addr 0x1049282C): 0x00000000
  rxppp_regs[3].accm_map                 (addr 0x10492830): 0x00000000
  rxppp_regs[3].special_char             (addr 0x10492834): 0x00000000
  rxppp_regs[3].context                  (addr 0x1049283C): 0x00000000
  rxbsc_regs[0].context_cfg_pad_char     (addr 0x10492A00): 0x00000000
  rxbsc_regs[1].context_cfg_pad_char     (addr 0x10492A10): 0x00000000
  rxbsc_regs[2].context_cfg_pad_char     (addr 0x10492A20): 0x00000000
  rxbsc_regs[3].context_cfg_pad_char     (addr 0x10492A30): 0x00000000
  intf_regs[0].intf_ctrl                 (addr 0x10493000):     0x0200
  intf_regs[0].modem_ctrl                (addr 0x10493002):     0xE010
  intf_regs[0].flow_ctrl                 (addr 0x10493004):     0x0000
  intf_regs[0].brg_divider               (addr 0x10493006):     0x0000
  intf_regs[0].modem_intr_status         (addr 0x10493008):     0x000F
  intf_regs[1].intf_ctrl                 (addr 0x10493010):     0x0200
  intf_regs[1].modem_ctrl                (addr 0x10493012):     0xE010
  intf_regs[1].flow_ctrl                 (addr 0x10493014):     0x0000
  intf_regs[1].brg_divider               (addr 0x10493016):     0x0000
  intf_regs[1].modem_intr_status         (addr 0x10493018):     0x000F
  intf_regs[2].intf_ctrl                 (addr 0x10493020):     0x0200
  intf_regs[2].modem_ctrl                (addr 0x10493022):     0xE010
  intf_regs[2].flow_ctrl                 (addr 0x10493024):     0x0000
  intf_regs[2].brg_divider               (addr 0x10493026):     0x0000
  intf_regs[2].modem_intr_status         (addr 0x10493028):     0x000F
  intf_regs[3].intf_ctrl                 (addr 0x10493030):     0x0200
  intf_regs[3].modem_ctrl                (addr 0x10493032):     0xE010
  intf_regs[3].flow_ctrl                 (addr 0x10493034):     0x0000
  intf_regs[3].brg_divider               (addr 0x10493036):     0x0000
  intf_regs[3].modem_intr_status         (addr 0x10493038):     0x000F
  tdm_control                            (addr 0x10493100):     0x0000
  tdm_a_8k_divider                       (addr 0x10493102):     0x0000
  tdm_b_8k_divider                       (addr 0x10493104):     0x0000
  intf_irq_status                        (addr 0x10493106):     0x0000
  freq_count_port_sel                    (addr 0x1049310A):     0x0000
  freq_count                             (addr 0x1049310C): 0x00000000
  pll_regs[0].pll_ctrl                   (addr 0x10493110):     0x0000
  pll_regs[0].pll_8kref_divider          (addr 0x10493112):     0x0000
  pll_regs[0].pll_fback_pre_divider      (addr 0x10493114):     0x0000
  pll_regs[0].pll_fback_post_divider     (addr 0x10493116):     0x0000
  pll_regs[1].pll_ctrl                   (addr 0x10493120):     0x0000
  pll_regs[1].pll_8kref_divider          (addr 0x10493122):     0x0000
  pll_regs[1].pll_fback_pre_divider      (addr 0x10493124):     0x0000
  pll_regs[1].pll_fback_post_divider     (addr 0x10493126):     0x0000
  pll_regs[2].pll_ctrl                   (addr 0x10493130):     0x0000
  pll_regs[2].pll_8kref_divider          (addr 0x10493132):     0x0000
  pll_regs[2].pll_fback_pre_divider      (addr 0x10493134):     0x0000
  pll_regs[2].pll_fback_post_divider     (addr 0x10493136):     0x0000
  pll_regs[3].pll_ctrl                   (addr 0x10493140):     0x0000
  pll_regs[3].pll_8kref_divider          (addr 0x10493142):     0x0000
  pll_regs[3].pll_fback_pre_divider      (addr 0x10493144):     0x0000
  pll_regs[3].pll_fback_post_divider     (addr 0x10493146):     0x0000
io-controller tdm (addr 0x104A0000):
io-controller tdm (csm addr 0x104A0000):
  tdmsw_enbl_7f_60                       (addr 0x104B0000): 0x00000000
  tdmsw_enbl_5f_40                       (addr 0x104B0004): 0x00000000
  tdmsw_enbl_3f_20                       (addr 0x104B0008): 0x00000000
  tdmsw_enbl_1f_00                       (addr 0x104B000C): 0xC0000001
  tdmsw_rate_7f_70                       (addr 0x104B0010): 0x00000000
  tdmsw_rate_6f_60                       (addr 0x104B0014): 0x00000000
  tdmsw_rate_5f_50                       (addr 0x104B0018): 0x00000000
  tdmsw_rate_4f_40                       (addr 0x104B001C): 0x00000000
  tdmsw_rate_3f_30                       (addr 0x104B0020): 0x00000000
  tdmsw_rate_2f_20                       (addr 0x104B0024): 0x00000000
  tdmsw_rate_1f_10                       (addr 0x104B0028): 0x55555555
  tdmsw_rate_0f_00                       (addr 0x104B002C): 0x55555555
  tdmsw_lpbk_7f_60                       (addr 0x104B0030): 0x00000000
  tdmsw_lpbk_5f_40                       (addr 0x104B0034): 0x00000000
  tdmsw_lpbk_3f_20                       (addr 0x104B0038): 0x00000000
  tdmsw_lpbk_1f_00                       (addr 0x104B003C): 0x00000000
  tdmsw_ctl                              (addr 0x104B0040): 0x00000000
  tdmsw_csm_err_adrs                     (addr 0x104B0044): 0x00000000
  tdm_mgmt_event                         (addr 0x104B0050): 0x00000002
  tdm_mgmt_enbl                          (addr 0x104B0054): 0x00000000
  tdm_err_event                          (addr 0x104B0058): 0x00000000
  tdm_err_enbl                           (addr 0x104B005C): 0x00000100
  vmcr[0]                                (addr 0x104B0060): 0x00000000
  vmcr[1]                                (addr 0x104B0064): 0x00000000
  vmcr[2]                                (addr 0x104B0068): 0x00000000
  vmcr[3]                                (addr 0x104B006C): 0x00000000
  sm_tdm_cr                              (addr 0x104B0070): 0x00000000
  pvdm_tdm_cr                            (addr 0x104B0074): 0x00000006
  ntr_cr0                                (addr 0x104B0078): 0x00000000
  ntr_cr0_aux                            (addr 0x104B007C): 0x00000000
  ntr_cr1                                (addr 0x104B0080): 0x00000000
  ntr_cr1_aux                            (addr 0x104B0084): 0x00000000
  tpllr_cr                               (addr 0x104B0088): 0x00000000
  ds0_dump_beg_adrs                      (addr 0x104B0090): 0x00000000
  ds0_dump_end_adrs                      (addr 0x104B0094): 0x00000000
  ds0_dump_ctl                           (addr 0x104B0098): 0x00000000
  tdm_sync_ctrl_int                      (addr 0x104B00A0): 0x00000010
  tdm_sync_status_int                    (addr 0x104B00A4): 0x0002D200
io-controller i2c (addr 0x10510000):
reg + adjust (addr 0x10510000):
  i2c_control                            (addr 0x10510000): 0x00010000
  i2c_scratch                            (addr 0x10510004): 0xFACEDEAD
  i2c_status                             (addr 0x10510008): 0x00000001
  i2c_status_mask                        (addr 0x1051000C): 0x00000000
  i2c_slave_addr                         (addr 0x10510010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10510014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10510018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10511804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10510020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10510024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10510028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1051002C): 0x00000000
  data_fifo_addr                         (addr 0x10511800): 0xB1942CE3
reg + adjust (addr 0x10520000):
  i2c_control                            (addr 0x10520000): 0x00010000
  i2c_scratch                            (addr 0x10520004): 0xFACEDEAD
  i2c_status                             (addr 0x10520008): 0x00000001
  i2c_status_mask                        (addr 0x1052000C): 0x00000000
  i2c_slave_addr                         (addr 0x10520010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10520014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10520018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10521804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10520020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10520024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10520028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1052002C): 0x00000000
  data_fifo_addr                         (addr 0x10521800): 0x262C3E98
reg + adjust (addr 0x10530000):
  i2c_control                            (addr 0x10530000): 0x00010000
  i2c_scratch                            (addr 0x10530004): 0xFACEDEAD
  i2c_status                             (addr 0x10530008): 0x00000001
  i2c_status_mask                        (addr 0x1053000C): 0x00000000
  i2c_slave_addr                         (addr 0x10530010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10530014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10530018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10531804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10530020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10530024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10530028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1053002C): 0x00000000
  data_fifo_addr                         (addr 0x10531800): 0x2E2BC4EC
POWER CONSTANT AND MAX_POWER DETAILS
Motherboard power constant = 8B
Motherboard maximum power = 23.1 W
ETHSW_SM POE power consumption = 0.0 W
------------------ show environment table ------------------
SYSTEM POWER SUPPLY STATUS
Power Supply Type: AC
External Power Supply POE -48V Voltage Status: Not Present
SYSTEM FAN STATUS
Fan 1 OK, fan level 1, Low speed setting, 2969 RPM, 35% PWM
SYSTEM TEMPERATURE STATUS
Intake Right temperature: 23 Celsius, Normal
Intake User temperature: 25 Celsius, Normal
Exhaust Fan temperature: 29 Celsius, Normal
Intake Right(Bezel) temperature: 26 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
SYSTEM ALARMS SETTINGS
System fan failure results in warning
Intake Right Over Temperature Alarm = 42C
Intake User Over Temperature Alarm = 42C
Exhaust Fan Over Temperature Alarm = 75C
Intake Right(Bezel) Over Temperature Alarm = 42C
SYSTEM VOLTAGES
12V voltage = 12.228 V, Normal
5V voltage = 5.166 V, Normal
3.3V voltage = 3.344 V, Normal
2.5V voltage = 2.480 V, Normal
1.8V voltage = 1.803 V, Normal
1.2V voltage = 1.205 V, Normal
CPU/ASIC voltage = 1.020 V, Normal
SYSTEM POWER
Motherboard Components Power consumption = 21.7 W
Total System Power consumption is: 21.7 W
Environmental information last updated 00:00:16 ago
ENVIRONMENTAL STRESS EVENTS
Critical Temperature: Maxium = 0
                      Total Duration = 0
Exceed Fan Tray Removal Time: Maximum Time= 0
                               Total Time = 0
Total MCU access error count: 0
------ ENVIRONMENTAL CONTROLLER REGISTERS ------
REG: 0x0 : 0x405
REG: 0x1 : 0x101
REG: 0x2 : 0x0
REG: 0x3 : 0x17
REG: 0x4 : 0x19
REG: 0x5 : 0x1D
REG: 0x6 : 0x1A
REG: 0x7 : 0xB99
REG: 0x8 : 0x0
REG: 0x9 : 0x0
REG: 0xA : 0x0
REG: 0xB : 0x0
REG: 0xC : 0xFF
REG: 0xD : 0xFF
REG: 0xE : 0x813D
REG: 0xF : 0x8000
REG: 0x10 : 0x19
REG: 0x11 : 0x1C
REG: 0x12 : 0x1E
REG: 0x13 : 0x21
REG: 0x14 : 0x23
REG: 0x15 : 0x2F
REG: 0x16 : 0x4A
REG: 0x17 : 0x23
REG: 0x18 : 0x2F
REG: 0x19 : 0x4A
REG: 0x1A : 0x23
REG: 0x1B : 0x2F
REG: 0x1C : 0x4A
REG: 0x1D : 0x23
REG: 0x1E : 0x2F
REG: 0x1F : 0x4A
REG: 0x20 : 0x23
REG: 0x21 : 0x2F
REG: 0x22 : 0x4A
REG: 0x23 : 0x3E8
REG: 0x24 : 0x2
REG: 0x25 : 0x258
REG: 0x26 : 0xB4
REG: 0x27 : 0x2A
REG: 0x28 : 0x2A
REG: 0x29 : 0x4B
REG: 0x2A : 0x2A
REG: 0x2B : 0x3C
REG: 0x2C : 0x0
REG: 0x2D : 0xF
REG: 0x2E : 0x0
REG: 0x2F : 0x0
REG: 0x30 : 0x3E8
REG: 0x31 : 0x3E8
REG: 0x32 : 0xC8
REG: 0x33 : 0x32
REG: 0x34 : 0x23
REG: 0x35 : 0x26
REG: 0x36 : 0x28
REG: 0x37 : 0x2B
REG: 0x38 : 0x62
REG: 0x39 : 0x62
REG: 0x3A : 0x62
REG: 0x3B : 0x62
REG: 0x3C : 0x62
REG: 0x3D : 0x62
REG: 0x3E : 0x62
REG: 0x3F : 0x62
REG: 0x40 : 0x62
REG: 0x41 : 0x62
REG: 0x42 : 0x0
REG: 0x43 : 0x1B
REG: 0x44 : 0x1D
REG: 0x45 : 0x22
REG: 0x46 : 0x20
REG: 0x47 : 0x18
REG: 0x48 : 0x4
REG: 0x49 : 0x4
REG: 0x4A : 0x5
REG: 0x4B : 0x6
------- POWER SEQUENCER REGS -------
REG: 0x0 : 0x305
REG: 0x1 : 0xC00
REG: 0x2 : 0xC00
REG: 0x3 : 0x0
REG: 0x4 : 0x0
REG: 0x5 : 0x0
REG: 0x6 : 0xE
REG: 0x7 : 0x95BC
REG: 0x8 : 0x305
REG: 0x9 : 0x30A
REG: 0xA : 0x304
REG: 0xB : 0x2EE
REG: 0xC : 0x2EF
REG: 0xD : 0x2ED
REG: 0xE : 0x30F
REG: 0xF : 0x30F
REG: 0x10 : 0x30E
REG: 0x11 : 0x311
REG: 0x12 : 0x314
REG: 0x13 : 0x30F
REG: 0x14 : 0x2AC
REG: 0x15 : 0x2AD
REG: 0x16 : 0x2AB
REG: 0x17 : 0xA6
REG: 0x18 : 0xCA
REG: 0x19 : 0x97
REG: 0x1A : 0x1C9
REG: 0x1B : 0x1CA
REG: 0x1C : 0x1C7
REG: 0x1D : 0x1AC
REG: 0x1E : 0x1AD
REG: 0x1F : 0x1AB
REG: 0x20 : 0x185
REG: 0x21 : 0x186
REG: 0x22 : 0x183
REG: 0x23 : 0x0
REG: 0x24 : 0x0
REG: 0x25 : 0x0
REG: 0x26 : 0x0
REG: 0x27 : 0x0
REG: 0x28 : 0x0
REG: 0x29 : 0x0
REG: 0x2A : 0x0
REG: 0x2B : 0x0
REG: 0x2C : 0x0
REG: 0x2D : 0x0
REG: 0x2E : 0x78
REG: 0x2F : 0x0
REG: 0x30 : 0x0
REG: 0x31 : 0x4600
REG: 0x32 : 0x903
REG: 0x33 : 0x904
REG: 0x34 : 0x901
REG: 0x35 : 0x903
REG: 0x36 : 0xC00
REG: 0x37 : 0x904
REG: 0x38 : 0x1
REG: 0x39 : 0x103
REG: 0x3A : 0x3FF
REG: 0x3B : 0x32
REG: 0x3C : 0x28
REG: 0x3D : 0xFFFF
REG: 0x3E : 0x0
REG: 0x3F : 0x0
REG: 0x40 : 0x0
REG: 0x41 : 0x0
REG: 0x42 : 0x0
REG: 0x43 : 0x0
------------------ service-module Embedded-Service-Engine0/0 status ------------------
Service Module is Cisco Embedded-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module heartbeat-reset is enabled
Embedded Service Engine boot state is RESET
No install/uninstall in progress
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show controllers j1 ------------------
------------------ show ip nbar version ------------------
NBAR software version:  7
1   base                 Mv: 2
2   ftp                  Mv: 3
3   http                 Mv: 14
      Iv:               kazaa2 - 8
      Iv:              youtube - 1
      Iv:                  msn - 1
      Iv:                yahoo - 1
4   static               Mv: 7
5   secure-http          Mv: 1
      Iv:                  aim - 1
6   netbios              Mv: 1
      Iv:                 cifs - 1
7   socks                Mv: 1
      Iv:                yahoo - 1
      Iv:                  msn - 1
      Iv:                  aim - 1
      Iv:           bittorrent - 4
8   nntp                 Mv: 1
      Iv:                yahoo - 1
9   tftp                 Mv: 1
10  exchange             Mv: 1
11  vdolive              Mv: 1
12  sqlnet               Mv: 1
13  rcmd                 Mv: 1
14  netshow              Mv: 1
15  sunrpc               Mv: 2
16  streamwork           Mv: 1
17  citrix               Mv: 12
18  fasttrack            Mv: 2
19  gnutella             Mv: 4
20  kazaa2               Mv: 8
      Iv:                 http - 13
21  custom-protocols     Mv: 1
22  rtsp                 Mv: 5
23  rtp                  Mv: 6
      Iv:   telepresence-media - 1
24  mgcp                 Mv: 2
25  skinny               Mv: 2
      Iv:          cisco-phone - 1
26  h323                 Mv: 1
27  sip                  Mv: 2
      Iv:          cisco-phone - 1
      Iv: telepresence-control - 1
28  rtcp                 Mv: 3
29  edonkey              Mv: 5
30  winmx                Mv: 4
31  bittorrent           Mv: 4
      Iv:                socks - 1
      Iv:                  wow - 1
32  directconnect        Mv: 3
33  smtp                 Mv: 1
34  dns                  Mv: 1
35  hl7                  Mv: 1
36  fix                  Mv: 1
37  msn                  Mv: 1
      Iv:                socks - 1
      Iv:                 http - 13
38  yahoo                Mv: 1
      Iv:                socks - 1
      Iv:                 http - 13
      Iv:                 nntp - 1
39  mapi                 Mv: 1
40  aim                  Mv: 1
      Iv:          secure-http - 1
      Iv:                socks - 1
41  cifs                 Mv: 1
      Iv:              netbios - 1
42  cisco-phone          Mv: 1
      Iv:                  sip - 2
      Iv:               skinny - 2
43  youtube              Mv: 1
      Iv:                 http - 12
44  skype                Mv: 3
45  wow                  Mv: 1
      Iv:           bittorrent - 4
46  microsoftds          Mv: 1
      Iv:                 cifs - 1
47  telepresence-media   Mv: 1
      Iv:                  rtp - 6
      Iv:                 rtcp - 3
48  telepresence-control Mv: 1
      Iv:                 rtcp - 3
      Iv:          cisco-phone - 1
      Iv:                  sip - 2
49  sap                  Mv: 1
50  iana                 Mv: 1
51  dicom                Mv: 2
{} Mv: , {Nv: ; }
            {Iv:    - }
------------------ show crypto key mypubkey rsa ------------------
------------------ show license udi ------------------
Device#   PID   SN  UDI
*0     CISCO1921/K9          FGL162224AR     CISCO1921/K9:FGL162224AR
------------------ show license feature ------------------
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             no       yes
datak9                   yes          yes         no             no       yes
SSL_VPN                  yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
WAAS_Express             yes          yes         no             no       yes
------------------ show license file ------------------
License Store: Primary License Storage
  Store Index: 0
    License: 11 ipbasek9 1.0 LONG NORMAL STANDALONE EXCL INFINITE_KEYS INFINIT
             E_KEYS NEVER NEVER NiL SLM_CODE CL_ND_LCK NiL *148ZLPT72898MK9400
              NiL NiL NiL 5_MINS CISCO1921/K9FGL162224AR             SN> xYOZT1wxp3satPbgH98zLal86rCOa4f96h4cAXPEqFLgjsVs6xvumxQ
             uzGUfzS72VUny6DySE4A6Vffkv8dE,wfcDtlVQhOnAkRntlBTT7:qLY3GIZ,EopVo
             hkijjtINJJVb$AQEBIf8B///lxRA0g9CbFgqSyJgz4lsfdcj18KIOOmRICc+
             5u2LGBazUvvnVQmKH6TmPsVlRb5FHebPkGlARtYd1UQO7GJ3KnufZ9oZ6JdFniDf5
             HrQ8DrXdpCz5RgZE+y8fbN200xiXA5cB3fwcJqoPIFZm2HmD1qFfsyTAzuio66t6X
             k5y8xo1lbVhvoh/FZfy5iRY3oE=
    Comment:
       Hash: dbvHOGl7P9AKGmpWk8fUFsqfS1A=
License Store: Built-In License Storage
  Store Index: 0
    License: 12 securityk9 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALON
             E ADD INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL S
             LM_CODE DEMO NiL NiL Ni NiL NiL 5_MINS NOTLOCKED<
             SN>NOTLOCKED
RTU o752vzSJKZrdH4u4ZtcK3Bw6ml3WxZh
             u1tBMjO3Ug6Lksw2do3TfGHKyFrX1R8iELHZXXc1gkMK:QJkHnk509:V92eExG7eO
             HJzc0j:KNx37fPfwHgOvy17IlfYznZRK:sLqftl5PrdD0Te8m805D8iy31$A
             QEBIf8B///Qi+RhPeDffX673lUKCuNMEDzt9tuuVAOnJSWOWt+YibyFo2qPGfJs9t
             V4fif4QI2RqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21
             MNUjVbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/
             5Ko8XCY=
    Comment:
       Hash: 2SdvlCANIKgA2eCVZ0Gf288w5iE=
  Store Index: 1
    License: 12 datak9 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALONE AD
             D INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL SLM_C
             ODE DEMO NiL NiL Ni NiL NiL 5_MINS NOTLOCKEDN
             OTLOCKED
RTU nRbEsTOOMHl:ZVeYWhLM3h9H07EgKZ3DaEy
             nEbPSxo351:UZl9AFe,LigmXV4HRsfr8WjQpcF3ERNZKED4gFeUVffxungWvFnxm1
             KVSr6PUSLZteliWF0s3CtK0rqFEMGm3gg9c:iw16ZwGrqDNVLPmTVi$AQEBI
             f8B///rbW/aK5VZHZnU1Kp7HiDRqan+uFOVBHo5UvsbCOc8yu24gnlQ94mLbol/BZ
             FAJcKRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21MNUj
             VbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/5Ko8
             XCY=
    Comment:
       Hash: YYhDTITGzmA0GQrQAhU3aYslL7I=
  Store Index: 2
    License: 12 SSL_VPN 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALONE A
             DD 5000_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL SLM_CODE
              DEMO NiL NiL Ni NiL NiL 5_MINS NOTLOCKEDNOTL
             OCKED
RTU 9UvDFIk:2jm5KTiolmCY3N2pkKO,8JnxaVUkYb
             OKBPfCwxdbHU9lwPjVpUlrwBdGfYNR2jo3C5acyEijrLlnVafruPIVf46dsLjZ0d7
             T5LgPf3IhjoB71kw8OpNSQQao,QL6LRx8LC7O0Cv:RmHLRbxJLM$AQEBIf8B
             ///6Ju9KAlGq1e5YoiodsUIZXv/uaTPy2bvcvp2R+iFKubdAEnqnH3IqGhw9XD6gj
             9qRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21MNUjVbh
             oN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/5Ko8XCY
    Comment:
       Hash: CHOO6th+oUibR+H2tSpraC4RGvw=
  Store Index: 3
    License: 12 ios-ips-update 1.0 LONG TRIAL DISABLED DISABLED DISABLED STAND
             ALONE ADD INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL N
             iL SLM_CODE DEMO NiL NiL Ni NiL NiL 5_MINS NOTLOCKED
             ID>NOTLOCKEDRTU tzDxtBd3ARcHcbsl:bTo3DRp7AI
             M:czMKZe5ixaNnZLScz0vElR92jlsCKNeA5B3LNx8fsnEmFa5E6QG,yxWbBVCv2CN
             LbA7LcgrNvgX2IOo3tfda:TpXJP8yqlxBv910j36DEg5L494kNHZSLiCwnkmVr$
             LC>AQEBIf8B//9r/97v+LovAn5aedjof/46XFQVtVTfx0qKoiXr125bCwjL6QCJXN
             e7vPq2IrMxlYaRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ
             8H21MNUjVbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q
             3SF/5Ko8XCY=
    Comment:
       Hash: 7lCXQ1d2qI0/CrSzyvzp8kEPvvs=
  Store Index: 4
    License: 12 WAAS_Express 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDAL
             ONE ADD INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL
              SLM_CODE DEMO NiL NiL Ni NiL NiL 5_MINS NOTLOCKED             >NOTLOCKEDRTU UMlOrKzqTDPL781K0GXULLyfYQ3la
             pXunm2mRIo2PRVSsvCtXMiktKpcAuLaJAy5VdME9HRaDmTbkg:bmRctNVLL,wFj39
             NUkFtwbM:jFeC8fj4fOFh5mWnL15hMOffAQYLr1f8vEO6KjZsu:hcGVo7w3s$
             >AQEBIf8B//9igvJEtCMXYK+bApf7QiW+Io9RQIlfzRN917hw5xGWPcO9E4aW/K/N
             3/TvR0Yf8u2RqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H
             21MNUjVbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3S
             F/5Ko8XCY=
    Comment:
       Hash: m+wXSaRIY8c3WuRYN0UZ272V4mM=
------------------ show license detail ------------------
Index: 1  Feature: SSL_VPN                           Version: 1.0
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
     Evaluation total period: 8  weeks 4  days
     Evaluation period left: 8  weeks 4  days
     Period used: 0  minute  0  second
License Count: 0/0  (In-use/Violation)
License Priority: None
Store Index: 2
Store Name: Built-In License Storage
Index: 2  Feature: WAAS_Express                      Version: 1.0
License Count: Non-Counted
Store Index: 4
Index: 3  Feature: datak9                            Version: 1.0
Store Index: 1
Index: 4  Feature: ios-ips-update                    Version: 1.0
Store Index: 3
Index: 5  Feature: ipbasek9                          Version: 1.0
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Index: 6  Feature: securityk9                        Version: 1.0
Store Index: 0
------------------ show license status ------------------
  License Type Supported
permanent               Non-expiring node locked license
extension               Expiring node locked license
evaluation              Expiring non node locked license
evalRightToUse          Right to use evaluation non node locked license
rightToUse              Right to use non node locked license
paid subscription       Expiring node locked subscription license
                         with valid end date
extension subscription  Expiring node locked subscription license
evaluation subscription Expiring node locked subscription license
  License Operation Supported
install    Install license
clear      Clear license
annotate   Comment license
save       Save license
revoke     Revoke license
call-home  License call-home
  Call-home Operation Supported
show pak   Display license pak via call-home
install    Install license via call-home
revoke     Revoke license via call-home
resend     Fetch license via call-home
  Device status
Device Credential type: DEVICE
Device Credential Verification: PASS
Rehost Type: HARDWARE
SWIFT url status
Swift URL set to default value : https://tools.cisco.com/SWIFT/Licensing
------------------ show license statistics ------------------
  Administrative statistics
Install success count:   0
Install failure count:   0
Install duplicate count: 0
Comment add count:       0
Comment delete count:    0
Clear count:             0
Save count:              0
Save cred count:         0
  Client statistics
Request success count:   1
Request failure count:   0
Release count:           0
Global Notify count:     0
------------------ show buffers ------------------
Buffer elements:
     544 in free list (500 max allowed)
     585 hits, 0 misses, 617 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50):
     48 in free list (20 min, 150 max allowed)
     66 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 28, permanent 25, peak 28 @ 00:04:09):
     28 in free list (10 min, 150 max allowed)
     72 hits, 1 misses, 0 trims, 3 created
Big buffers, 1536 bytes (total 51, permanent 50, peak 51 @ 00:04:24):
     51 in free list (5 min, 150 max allowed)
     54 hits, 0 misses, 0 trims, 1 created
VeryBig buffers, 4520 bytes (total 11, permanent 10, peak 11 @ 00:04:24):
     11 in free list (0 min, 100 max allowed)
     0 hits, 0 misses, 0 trims, 1 created
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 00:04:33):
     1 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 5, permanent 0, peak 5 @ 00:04:24):
     5 in free list (4 min, 10 max allowed)
     0 hits, 0 misses, 0 trims, 5 created
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 00:04:22):
     126 in free list (132 min, 132 max allowed)
     11 hits, 0 misses
IPC buffers, 4096 bytes (total 2, permanent 2):
     1 in free list (1 min, 8 max allowed)
     1 hits, 0 fallbacks, 0 trims, 0 created
IPC Medium buffers, 16384 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     0 hits, 0 fallbacks, 0 trims, 0 created
IPC Large buffers, 65535 bytes (total 2, permanent 2):
     0 hits, 0 misses, 0 trims, 0 created
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 512 in cache
     0 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 1664 bytes (total 768, permanent 768):
Normal buffers, 1676 bytes (total 3840, permanent 3840):
     3840 in free list (128 min, 4096 max allowed)
Private particle pools:
HQF buffers, 0 bytes (total 2000, permanent 2000):
     2000 in free list (500 min, 2000 max allowed)
GigabitEthernet0/0 buffers, 1664 bytes (total 1024, permanent 1024):
     0 in free list (0 min, 1024 max allowed)
     1024 hits, 0 fallbacks
     1024 max cache size, 768 in cache
     256 hits in cache, 0 misses in cache
GigabitEthernet0/1 buffers, 1664 bytes (total 1024, permanent 1024):
------------------ show buffers usage ------------------
Statistics for the Small pool
Caller pc    : 0x222013D0 count:        2
Resource User:       Init count:        2
Number of Buffers used by packets generated by system:   50
Number of Buffers used by incoming packets:               0
Statistics for the Middle pool
Number of Buffers used by packets generated by system:   28
Statistics for the Big pool
Number of Buffers used by packets generated by system:   51
Statistics for the VeryBig pool
Number of Buffers used by packets generated by system:   11
Statistics for the Large pool
Statistics for the Huge pool
Statistics for the Syslog ED Pool pool
Caller pc    : 0x22776348 count:        7
Resource User: EEM ED Sys count:        7
Number of Buffers used by packets generated by system:  133
Statistics for the IPC pool
Caller pc    : 0x21309084 count:        1
Resource User:       Init count:        1
Statistics for the IPC Medium pool
Statistics for the IPC Large pool
Statistics for the Header pool
Number of Buffers used by packets generated by system:  768
Statistics for the FS Header pool
Caller pc    : 0x21143E3C count:        2
Resource User:       Init count:       15
Caller pc    : 0x2123163C count:        1
Caller pc    : 0x226F993C count:        8
Caller pc    : 0x228888AC count:        1
Caller pc    : 0x2323D7D0 count:        1
Caller pc    : 0x21A09384 count:        1
Caller pc    : 0x2323E4C8 count:        1
Number of Buffers used by packets generated by system:   32
Statistics for the SW Crypto Header pool
Caller pc    : 0x23B28818 count:        1
------------------ show inventory ------------------
NAME: "CISCO1921/K9 chassis", DESCR: "CISCO1921/K9 chassis"
PID: CISCO1921/K9      , VID: V04 , SN: FGL162224AR
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x0DC00000  0x0FFFFFFF    37748736  Iomem  R/W    iomem
0x20000000  0x2DBFFFFF   230686720  Local  R/W    main
0x2100F4D8  0x24DCB52B    64733268  IText  R/O    main:text
0x24DDAC00  0x2732CC7F    39133312  IData  R/W    main:data
0x2732CC80  0x27E75D3F    11833536  IBss   R/W    main:bss
0x27E75D40  0x2DBFFFFF    98083520  Local  R/W    main:heap
0x30000000  0x3FFFFFFF   268435456  Local  R/W    Main_memory_1
0x80000000  0x8DBFFFFF   230686720  Local  R/W    main:(main_k0)
0xA0000000  0xADBFFFFF   230686720  Local  R/W    main:(main_k1)
Free Region Manager:
------------------ Mempool statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   27E75D40   366518976    25071348   341447628    95510048   247510400
      I/O    DC00000    37748736    14393992    23354744    23354744    23350012
-------------- Top 100 allocator pc summary -----------
Allocator PC Summary for: Processor
    PC          Total   Count  Name
0x236FB824      12040       2  Watched Boolean
0x22718AF4       9764       1  EEM Shell Director
0x24DC0380        452       2  MRIB IPv6 Init Process
0x23732FAC        244       2  SDB String
0x22A9FBD0        196       1  MRIB route entry
0x21DF496C        168       1  MRIB route entry
0x2292BA48        156       1  HTTP
0x23733130        152       2  MRIB IPv6 Init Process
0x2292068C        140       1  HTTP
0x22943098        136       1  HTTP
0x2236F884        112       1  Parser Mode
0x21DF4924        108       1  MRIB IPv6 Init Process
0x22A9FB88        108       1  MRIB IPv4 Init Process
0x2291FE54        100       1  HTTP
0x22354FD0         84       1  Parser Linkage
0x2236F8F8         76       1  Parser Mode Q1
0x23274898         76       1  AAA MI SG NAME
0x2236F91C         76       1  Parser Mode Q2
Allocator PC Summary for: I/O
    PC          Total   Count  Name
------------------ show dmvpn detail ------------------
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
N - NATed, L - Local, X - No Socket
# Ent --> Number of NHRP entries with same NBMA peer
NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
UpDn Time --> Up or Down Time for a Tunnel
AP_PATANCHERU_ASRS#
AP_PATANCHERU_ASRS#
AP_PATANCHERU_ASRS#=
Please find the attachment..
suhas
Hi Suhas,
as per this document:
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
this module is well supported on 1921 router with min ios requirements.
Cisco 1900, 2900, and 3900 Series Integrated Services Routers
• 15.0(1)M
IP Base
So you can try to remove and insert again.
Hi Team,
I havign the same problem, I reinserted it so many time ,even i restarted the router after each time i inserted. Moreover when i tried that HWIC-2T card in my spare router 1821 its detecting.
Thank you
Hi sandeep,
   what IOS have you suggested  that is minimum version & currently i am using c1900-universalk9-mz.SPA.151-4.M4.bin that is higher version it should be supported for HWIC-2T.
HI Suhas & Gourav,
If its not the problem of IOS version and then may be its a bug.
So you have to open a TAC case with cisco and try to resolve your problem.
Please rate if it helps.
hi folks,
I also have gone through the same issue and I had no other chance and I replaced 1921 with 1841.
remedy:
EHWIC will work in 1921, you can use the converters like MROTEK PINE E1 to convert the input to ethernet output and can use it in 1921.
Tanveer
Yes as said by sandeep first raise a TAC case with cisco
Please rate the helpful posts.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
pragmattic
