Not Enough Memory Prompt
gdwingnuts
I have a Cisco Catalyst 4948.  I am attempting to TFTP a new IOS and am receiving the Not Enough Memory prompt.  When I run the dir bootflash command the switch shows only one IOS usiing (16170184) bytes.  Total bytes are (60817408) with only (16272396) free.  When I enter the "show bootflash)" command I see three IOS files which would explain the lack of storage space available.  I have run the "delete bootflash" command but I still see the two old bootflash files when I run the "show bootflash" command.  What am I missing here?  The switch is operational and running fine.
Jon Marshall
Have you tried squeezing the bootflash to recover the space ie.
4500# squeeze bootflash:
Jon
Jon Marshall
Jon
Thanks Jon.  Squeezing worked :-)
