not getting ip from DHCP through 2960 switch
csc010854800
PC's are not getting ip address from the DHCP server which is connected beyond 2960 switch.
broadband router(DHCP Server)--------------------------Switch 2960---------------------------PC(DHCP client)
but when i directly connect PC to the broadband router , pc is getting ip address.
i have tried using following options but of no use.
# ip dhcp snooping vlan 1
# ip dhcp snooping trust
# ip dhcp snooping information option allow-untrusted
can anyone provide the config  and help
thanks in advance.
andrew.prince
Level 10
Level 10
Post config of switch and router for review.
manju.cisco
Level 3
Level 3
yes please post your configs,
Is the port where the DHCP server connects to the swtich is an access port or trunk port ??
wilrow113
If you set a static address on a pc and attached to the switch can it ping the dhcp server
Can the switch management address ping the dhcp server and are they in the same subnet
