Not getting ISP speed on 1921 router
j.defrank25
Hello guys, hope everyone is well and staying safe. I'm studying for my CCNA and in my lab I have a 1921 router with a EHWIC-4ESG installed, which provides gig speed. I'm paying for 1Gbps to my ISP so would take advantage of that and if I connect any device directly to the modem, I get that speed. But when I connect those same devices to the gig switchports on the 1921, at max, I'll get 250Mbps. Here's what I've tried to far:
1. Changing cables and ports...same results
2. Changing speed on ports to 1000 and duplex to FULL...same
My thinking is pointing me to something in my configuration but I'm not sure what. Any suggestions?
Here's my configuration:
R1(config-if)#sh run
% Invalid input detected at '^' marker.
R1(config-if)#do sh run
Building configuration...
Current configuration : 4424 bytes
! Last configuration change at 08:20:45 EAST Wed Sep 9 2020
! NVRAM config last updated at 08:28:26 EAST Wed Sep 9 2020
version 15.5
no service pad
service tcp-keepalives-in
service password-encryption
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$.Vne$JpIW7s1hSQ.rND74jlN8A1
aaa new-model
aaa session-id common
ethernet lmi ce
clock timezone EAST -4 0
no ip source-route
ip dhcp excluded-address 10.1.3.254
ip dhcp excluded-address 10.1.2.254
ip dhcp excluded-address 10.1.4.254
ip dhcp pool WiFi
network 10.1.2.0 255.255.255.0
default-router 10.1.2.254
dns-server 9.9.9.9
domain-name MyHome
ip dhcp pool EXP
network 10.1.3.0 255.255.255.0
domain-name MyHome
default-router 10.1.3.254
dns-server 9.9.9.9
ip dhcp pool PC
network 10.1.4.0 255.255.255.0
dns-server 9.9.9.9
domain-name MyHome
default-router 10.1.4.254
ip dhcp pool SW1
host 10.1.3.253 255.255.255.0
hardware-address 001d.454e.cc00
ip dhcp pool SW2
host 10.1.3.252 255.255.255.0
hardware-address 001d.45ce.ae00
no ip bootp server
ip domain name joey.net
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FJC2007E299
spanning-tree portfast bpduguard
spanning-tree vlan 30 priority 8192
vtp domain CISCO
vtp mode transparent
vtp version 2
username admin privilege 15 secret 5 $1$ILlm$q2tS0uNPM8qL/W7BkFSoA1
username admin1 privilege 15 secret 9 $9$V40rT5ZlMeZPZE$KFh3viwTwmcAsRnT7kHImwLOylVif2GhWp/kpIic4Vk
redundancy
vlan 20
name WiFi
vlan 30
name EXP
vlan 40
name PC
vlan 1004
bridge 0
stp type ieee
interface Loopback1
ip address 2.2.2.1 255.255.255.248
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.1.9 255.255.255.0
ip access-group INBOUND in
ip access-group OUTBOUND out
no ip redirects
no ip unreachables
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ntp broadcast client
interface GigabitEthernet0/1
no ip address
ip nat outside
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface GigabitEthernet0/1/0
switchport access vlan 40
no ip address
interface GigabitEthernet0/1/1
switchport access vlan 20
no ip address
interface GigabitEthernet0/1/2
switchport access vlan 30
no ip address
duplex full
interface GigabitEthernet0/1/3
no ip address
duplex full
interface Vlan1
no ip address
shutdown
interface Vlan20
description WIFI
ip address 10.1.2.254 255.255.255.0
ip nat inside
interface Vlan30
description EXPERIMENTAL
ip address 10.1.3.254 255.255.255.0
ip nat inside
interface Vlan40
description PC
ip address 10.1.4.254 255.255.255.0
ip nat inside
ip default-gateway 192.168.1.1
no ip classless
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 2 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 10.1.2.0 255.255.255.0 Loopback1
ip route 10.1.3.0 255.255.255.0 Loopback1
ip route 10.1.4.0 255.255.255.0 Loopback1
ip ssh version 2
ip access-list extended INBOUND
deny ip 10.1.0.0 0.0.255.255 any log
deny ip 127.0.0.0 0.255.255.255 any log
deny ip 240.0.0.0 7.255.255.255 any log
deny ip 192.0.2.0 0.0.0.255 any log
deny ip 169.254.0.0 0.0.255.255 any log
deny ip host 0.0.0.0 any log
permit ip any any
access-list 2 permit 10.1.0.0 0.0.255.255
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 deny any log
control-plane
vstack
line con 0
password 7 06220E3347430817574232
line aux 0
session-timeout 5 output
timeout login response 300
password 7 02220549000B0E2F1E1B29
transport input ssh
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 2 in
exec-timeout 5 0
privilege level 15
password 7 072B205E4504180B45472B
transport input ssh
scheduler allocate 20000 1000
ntp server 129.6.15.28 source GigabitEthernet0/0
end
13 Replies 13
balaji.bandi
here is the performance report which you maximum router can go.
you may not get on router Line speed. required additional license or more, you need to look different model.
BB
Ok. Thanks. If I understand correctly, I'm capped at 2770Mbps? If I calculate correctly that gives me 2.7Gbps. Correct?
Also, I forgot to add that I get about 600-700Mbps on my wireless devices connected to my TP-lInk access point that connects  to one of the LAN ports.
Correct, the maximum documented (aggregate) performance is 2.7 Gbps (table 1), but conversely, figure 1 recommends the 1921 for only WAN links of 15 Mbps.  ISR performance is very variable depending on your configuration and your traffic mix.
If your CPU is hitting 100%, you've bumped into the performance limits of your router.
Changing your configuration might yield more throughput.
BTW, the 2921 doesn't have a performance limit beyond what the hardware is capable of.
Also BTW, something like the 2921 was designed as a WAN router when having gig WAN links wasn't really expected.
Great thanks for the response. Let me see if I understand correctly...Sorry I'm new to networking, just been doing it for about 5 months now.
What you're saying is that the CPU of the 1921 is maxed out, therefore limiting my speed? Like a hardware limitation?
"Changing your configuration might yield more throughput."
Any recommendations?
Also, do you know if the 2921 is loud? I had gotten the 1921 because I had read that it didn't make much noise, that's why I got it.
"What you're saying is that the CPU of the 1921 is maxed out, therefore limiting my speed? Like a hardware limitation?"
Yup!
"Any recommendations?"
Would need to see your current config.
"Also, do you know if the 2921 is loud? I had gotten the 1921 because I had read that it didn't make much noise, that's why I got it."
Would depend on your definition of "loud".  In general, "Enterprise" class network devices are often tucked away in a closet or data center, not usually something you want next to your desk.  So, they can be somewhat noisy.  Much of their noise comes from their fans, which often are variable speed.  If they start to heat up, their fans get much louder.
Yup!
I was hoping that wasn't the case....
I posted my routers config in a previous post. As far as my physical set up I only have the 1921 connected to the ISP modem. Also a AP connected to the 1921.
Would depend on your definition of "loud".  In general, "Enterprise" class network devices are often tucked away in a closet or data center, not usually something you want next to your desk.  So, then can be, somewhat, noisy.  Much or their noise comes from their fan(s), which are often variable speed.  If they start to hit up, their fans get much louder.
Well, for example, I also have two Catalyst 3750s, which I don't use much, only for experimental stuff so I leave them off unless I want to mess around and they are pretty loud compared to the 1921. I can still hear the 1921s fan but its not unbearable. This whole set up is in my bedroom, so Im trying to keep it the sound at a minimum.
"I posted my routers config in a previous post."
Oops, indeed you do!  My bad.
ACL with logging, is a slow process.  I assume you gotten few, if any, hits for your "INBOUND" ACL?  You might consider removing that ACL.
Post results from "show proc cpu s|ex 0.00".
Ok, removed the ACLs completely.
I've attached a pic of the output
That particular CPU shows half your processor CPU being used by SSH.
Can you do a similar posting when you push to max throughput?
This is the same output once I ran the command again this morning.
How do I do that?
How did you "discover" your throughput limit?
I "discovered" it via the document that was posted by user balaji.bandj
Ruben Cocheno
@j.defrank25
you probably are not getting all throughput due the that particular model not supporting at all, i do recall those router would required a extra license to bump up the total traffic aggregate, but i beleive it only starts with the 4k routers.
so if you don't want to replace that, probably you can call your ISP to drop the speed and cache in some money :), after a few months you can replace that old router with something high grade. Also check your ssh sessions on your router, you might have some pending consuming resources and dropping some performance when comes to forward traffic.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
