08-03-2011 11:55 PM - edited 03-07-2019 01:32 AM
Hello community,
I did a traceroute command and I do not fully understand the output. This is what I got:
Sw-KK-C6509-R4A1#traceroute 192.168.1.75
Tracing the route to 192.168.1.75
1 10.150.254.4 0 msec
10.250.200.34 0 msec
10.150.254.4 0 msec
2 10.170.254.3 0 msec
10.250.200.41 0 msec
10.170.254.3 0 msec
3 10.130.254.4 0 msec
10.250.200.37 0 msec
10.130.254.4 4 msec
4 10.130.252.1 0 msec 0 msec 0 msec
5 10.255.197.66 32 msec * 28 msec
Why do I get 3 lines for each hop? Do some of the packets go through one path and some through another?
Show ip route also shows that it learns about 192.168.1.75 from 2 different sites, with the same metric!
Sw-KK-C6509-R4A1>sh ip route 192.168.1.75
Routing entry for 192.168.1.75/32
Known via "ospf 1", distance 110, metric 50
Tag Complete, Path Length == 1, AS 6799, , type extern 2, forward metric 6
Last update from 10.150.254.4 on Vlan254, 1d11h ago
Routing Descriptor Blocks:
* 10.250.200.34, from 10.255.198.5, 1d11h ago, via GigabitEthernet1/23
Route metric is 50, traffic share count is 1
Route tag 3489667727
10.150.254.4, from 10.255.198.5, 1d11h ago, via Vlan254
Is the route marked with * preffered and if yes, why does it say:
192.168.1.75 goes through the providers MPLS, so I don't know if anything changed in the providers network, because I have the same issue with all branches belonging to the same OSPF area.
Thank you all in advance,
Katerina
Solved! Go to Solution.
08-04-2011 12:39 AM
You have there multiple routes for the same destination (subnet). The asterisk doesn't mean that route is preferred in terms that is the only route that packets take. Instead, I quote here as it's easier:
There is also an asterisk (*) next to one of the block entries. This corresponds to the active route that is used for new traffic. The term 'new traffic' corresponds to a single packet or an entire flow to a destination, depending on the type of switching configured.
For process-switching—load balancing is on a per-packet basis and the asterisk (*) points to the interface over which the next packet is sent.
For fast-switching—load balancing is on a per-destination basis and the asterisk (*) points to the interface over which the next destination-based flow is sent.
The position of the asterisk (*) keeps rotating among the equal cost paths each time a packet/flow is served.
You can see here an example:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
I'll show you an example from my live environment. I have one router with two uplinks. The routing protocol is OSPF and the uplink routers both send a default route with the same metric:
sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "ospf 1", distance 110, metric 11, candidate default path
Tag 1, type extern 1
Last update from x.x.x.145 on TenGigabitEthernet2/1, 1d00h ago
x.x.x.145, from x.x.x.16, 1d00h ago, via TenGigabitEthernet2/1
Route metric is 11, traffic share count is 1
Route tag 1
* x.x.x.129, from x.x.x.15, 1d00h ago, via TenGigabitEthernet2/2
Route tag 1
traceroute 1.1.1.1
Tracing the route to 1.1.1.1
1 x.x.x.145 0 msec
x.x.x.129 0 msec
x.x.x.145 0 msec
2 x.x.x.221 0 msec
x.x.x.225 0 msec
x.x.x.221 0 msec
3 x.x.x.114 12 msec 12 msec 12 msec
4 x.x.x.70 20 msec 12 msec 16 msec
I took out the subnet for security reasons, but the last octet the important one here.
HTH,
Calin
08-04-2011 12:39 AM
sh ip route 0.0.0.0
Route tag 1
Route tag 1
traceroute 1.1.1.1
1 x.x.x.145 0 msec
x.x.x.129 0 msec
x.x.x.145 0 msec
2 x.x.x.221 0 msec
x.x.x.225 0 msec
x.x.x.221 0 msec
HTH,
Calin
08-04-2011 02:46 AM
Thanks Calin,
The answer fully covers my questions!
