Notification of alarms via email (EEM) of chassis temperature
ErickArteaga234
hi all
I have a question regarding the EEM feature, I have a catalyst 4500 switch with the version (cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin ").
I have looked for documentation regarding the sending of temperature alarms and that these are sent via email, I have carried out a test through an interface and this is satisfactory.
when entering the command "show environment temperature "
throws me the following:
Module Sensor                                       Temperature Status
1         Air inlet                                       34C (56C,68C,71C) ok
1        Air inlet remote                             23C (46C,59C,62C) ok
1        Air outlet                                       36C (66C,76C,79C) ok
1       Air outlet remote                            29C (60C,71C,74C) ok
2        air inlet                                         26C (43C,58C,61C) ok
2      air outlet (front)                              27C (51C,66C,69C) ok
2       air outlet (back)                             28C (43C,58C,61C) ok
3      Stub A                                           34C (58C,71C,74C) ok
3      Stub B                                            27C (54C,68C,71C) ok
3      XPP                                                46C (67C,81C,84C) ok
3      VFE                                                57C (79C,90C,93C) ok
3      NFE                                                46C (68C,80C,83C) ok
3      CPU                                               46C (69C,83C,86C) ok
3       FPGA                                             32C (57C,71C,74C) ok
4       Stub A                                            31C (58C,71C,74C) ok
4       Stub B                                            26C (54C,68C,71C) ok
4       XPP                                                45C (67C,81C,84C) ok
4       VFE                                                 52C (79C,90C,93C) ok
4      NFE                                                  42C (68C,80C,83C) ok
4      CPU                                                  43C (69C,83C,86C) ok
4       FPGA                                              31C (57C,71C,74C) ok
5       Air inlet                                            34C (56C,68C,71C) ok
5       Air inlet remote                                  25C (46C,59C,62C) ok
5       Air outlet                                           35C (66C,76C,79C) ok
5       Air outlet remote                                29C (60C,71C,74C) ok
6       Air inlet                                              34C (56C,68C,71C) ok
6       Air inlet remote                                   25C (46C,59C,62C) ok
6       Air outlet                                           36C (66C,76C,79C) ok
6       Air outlet remote                                31C (60C,71C,74C) ok
7       Air inlet                                              38C (56C,68C,71C) ok
7       Air inlet remote 27C (46C,59C,62C) ok
7       Air outlet 39C (66C,76C,79C) ok
7        Air outlet remote 33C (60C,71C,74C) ok
My question is, can temperature alarms be generated and these can be sent via mail, I can generate by means of EEM, the sending of the first temperature threshold of each module and sensor?
note: I share my script, based on one where cpu notifications were sent
event manager environment _email_to (xxxxxx)
event manager environment _email_server (xxxxxx)
event manager environment _dns_server (xxxxxxx)
event manager environment _email_from (xxxxxxx)
event manager environment _email_from_cc (xxxxxxx)
event manager applet environment
event syslog pattern "%ENVMON-:"
trigger
action 1.0 syslog priority notifications msg "envi error - mailC1 sent"
action 1.5 mail server "104.x.x.x" to "_email_to" from "_email_from" cc "_email_from_cc" subject "Environment" body "$_syslog_msg"
action 2.0 info type syslog history
action 2.5 syslog msg "$_syslog_msg"
action 3.0 cli command "show environment temperature"
action 4.0 set lines "0"
action 5.0 foreach line "$_cli_result" "\n"
action 6.0 if $lines gt "30"
action 7.0 break
action 8.0 append output "$line"
action 9.0 increment lines
regards!
Ok no issue, the way you configured CPU, you get an alert in event when the chassis temp go higher  ( you can also do with SNMP if you have any NMS in house)
based in the Logs you can generate email. (same way you do in EEM)  - for now all OK you wont be able to test (not you can simulate in production)
just for reference how the alerts generated when the chassis get higher temp.
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/www.cisco.com/content/en/us/td/docs/switches/lan/catalyst4500/XE3-10-0E/configuration/guide/xe-310-cg/pwr_envr.html.xml
BB
balaji.bandi
For now you doing based on the syslog alert trigger sending email, this is working, just to clarity of requirement, you looking ""show environment temperature " command send email using EEM Script ? is this correct ?
action 1.0 cli command "show environment temperature | redirect flash:environ.txt"
action 2.0 cli command "more flash:environ.txt"
action 3.0 mail server "x.x.x.x" to "myname@bb.com" from "eemcisco@bb.com" subject "Environment report" body "$_cli_result"
action 4.0 cli command "del /force flash:environ.txt"
BB
Hi ....Tanks for helping me !!
Not entirely, I was wrong to explain it, sorry. When entering the “show environment temperarure” command... and validating the temperature of the box, he observed that there is a temperature alarm threshold for each module and sensor... so I'm trying to automate an email (alert)... when a certain module or sensor .. exceeds that threshold.
Regards!!
BB
