NTP assoc error packets
neofit.solovan
Level 2
Level 2
Hi all,
I'm setting up a FreeBSD box to be used as NTP server within my network, which most of the time will be a stratum 2 NTP.
While I do have some sync problems between the FreeBSD box and the Stratum 1 (work in progress due to a firewall between them) I do see some strange errors on my routers and switches while issuing "show ntp assoc det".
Please see below in bold:
configured, ipv4, insane, invalid, unsynced, stratum 3
ref ID 81.21.76.27 , time DF66EA6B.C498C97E (10:50:51.767 CEST Tue Oct 9 2018)
our mode client, peer mode server, our poll intvl 256, peer poll intvl 256
root delay 33.44 msec, root disp 876.63, reach 0, sync dist 16836.15
delay 0.00 msec, offset 0.0000 msec, dispersion 15937.50, jitter 0.00 msec
precision 2**21, version 4
assoc id 35170, assoc name 144.210.60.118
assoc in packets 4710, assoc out packets 4786, assoc error packets 3988
org time 00000000.00000000 (01:00:00.000 CEST Mon Jan 1 1900)
rec time DF66EACB.8DC1D5AC (10:52:27.553 CEST Tue Oct 9 2018)
xmt time DF66EACB.8DC1D5AC (10:52:27.553 CEST Tue Oct 9 2018)
filtdelay = 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filtoffset = 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filterror = 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
minpoll = 6, maxpoll = 10
While the assoc errors are incrementing, there is another odd thing: the reach value is most of the time 0 (0 the received updates are minimum - 377 constant updates). Now I'm not sure if this value is regarding the stratum 1 NTP or to my NTP (no firewall between these devices).
Ntp In packets	   		:  41034
Ntp Out packets           	:  55569
Ntp bad version packets   	:  0
Ntp protocol error packets	:  0
Ntp Software Name   	:  Cisco-ntpv4
Ntp Software Version	:  Cisco-ntpv4-1.0
Ntp Software Vendor 	:  CISCO
Ntp System Type     	:  Cisco IOS
Can anyone explain how are the assoc errors generated?
N
johnd2310
Level 11
Level 11
HI,
You need to fix the issues between the FREEBSD server and the stratum 1 appliance. You switches and routers will not sync with a server that is not synced
You switch or router has sent ntp packets but has not received any successful/valid returns, hence the reach is zero. The switch/router is having issues with the packets from you server.
John
**Please rate posts you find helpful**
