NTP authent
Michal Valach
Hello all,
I have question, can somebody explain me please why is authentication done after I
add "key 1" to the "ntp server X.X.X.X" command on R2 as highlighted below?  Before this command I did not see in #sh ntp assoc det   word "authenticated"
Router2#sh run | i ntp
ntp authentication-key 1 md5 104D000A061843595F 7
ntp authenticate
ntp trusted-key 1
ntp server 10.10.10.1 key 1
Thank you
Hi Michal,
Because if you configured only
this mean that you don't need the client to authenticate the server, So the client will be able to syncronizes with any NTP server ( as the client is the side which enforce the authentication NOT the server)
which means that the server can serve many clients ( with and without authentication) simulatenously, But for the clients which require authentication the server must have a matched key configured, and for other clients it doesn't matter if the server has authentication keys configured or not
if you need to restrict the server to serve some customers use the serve-only ACL , and for the client to authenticate from specific servers use the peer ACL
i hope that i covered your questions .
feel free to discuss
Regards.
7 Replies 7
johnlloyd_13
Level 11
Level 11
Hi Michal,
I've had the exact issue last time and someone answered me on this thread
https://supportforums.cisco.com/message/3611572#3611572
Are you also going for your IINS?
I saw this thread, but there is not expalnation why I have to put the key for each server if global authentication is enabled.
Hi All,
because the NTP authentication works in a different manner, as the client who is the one authenticating the server.
so you need to tell the client which key to use when authenticating a server.
Regards.
Thank you for you reply, and can you also tell me please why NTP is working in case I do not put
ntp server 10.10.10.1 key 1 ?
Hi Michal,
Regards.
Thank you very much for clear explanation, can you advise me some book or cisco material please? I have tryied to find something where is NTP in detail, but unsecesfull.
Hi Michal,
you can read " Hardening Cisco Routers " book as a start, then try to read Cisco's white papers for more details if you want.
