NTP Configuration
Suresh Babu
Level 3
Level 3
Hello All,
I have done the NTP configuration as below but my switch is not syncing with the server
Switch (Config)# NTP server x.x.x.x
Please let me know if anything am i missing here..
Rgds
it will sync to NTP once the clock is near the clock of NTP server otherwise it will take ages.
Regards.
Alain
12 Replies 12
JY109
Is the configured ntp server require authentication?
Provide "show ntp status" for further troubleshoot
Sent from Cisco Technical Support Android App
srikanth ath
Level 7
Level 7
Hello suresh,
Kindly let us know where is the NTP server.
and provide below o/p
Router#
show ntp associations
Below is an example for NTP configuration on the core router and making lower end devices to synch with core router which acts as an NTP server.
Note: NTP server resides some-where outside/internet.
Initially make wan gateway router to synch up with the external NTP server as
Ntp server 129.89.29.191
Henceforth the router will synch its hardware time to NTP server.
To make below switches to synch up with the NTP server.
We have to issue
ntp server 8 …..> which tells the router to behave in as NTP server.
Then on the LAN distribution/core switches
ntp server 192.168.100.1 (the internal ip of the router interface)
Please rate the helpful posts.
srikanth
Giuseppe Larosa
Hello Suresh,
as suggested by Jim post
sho ntp status
Be aware that NTP synchronization does not happen very quickly it may require some time.
Hope to help
Giuseppe
Please provide the following outputs too
show run | in ntp
show clock
show ntp association detail
Karthic
Check the required outputs
switch#sh run | i ntp
ntp server 172.X.X.X
switch#sho clock
*23:28:04.135 UTC Tue Jun 8 1993
switch#sh ntp associations detail
172.X.X.X configured, insane, invalid, unsynced, stratum 16
ref ID 0.0.0.0, time 00000000.00000000 (00:00:00.000 UTC Mon Jan 1 1900)
our mode client, peer mode unspec, our poll intvl 64, peer poll intvl 16
root delay 0.00 msec, root disp 0.00, reach 0, sync dist 0.000
delay 0.00 msec, offset 0.0000 msec, dispersion 16000.00
precision 2**5, version 3
org time D40C3918.EC8B4394 (14:07:20.923 UTC Tue Sep 25 2012)
rcv time AFBF9ED2.8D415AD2 (23:27:14.551 UTC Tue Jun 8 1993)
xmt time AFBF9ED2.8CF0BB4D (23:27:14.550 UTC Tue Jun 8 1993)
filtdelay =     0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
filtoffset =    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
filterror =  16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
as I explained set your clock manually to something near correct time before setting the clock to use NTP, reconfigure NTP and then the clock should sync with the NTP server.
Regards.
Alain.
Hello Alain,
you are right NTP specifications allows to sync when clock differences are within 128 seconds
Best Regards
Giuseppe
hi alain,
this is great info and would help me to speed up NTP sync when setting up our routers! +5
cadet alain
if your switch clock is too far away from time provided by the  NTP server it will take ages for the switch to be syncronized
So verify first that there is no too much difference between the times and if so change it to something near real time on the switch with set clock command.
Regards.
Alain
Hi alain,
NTP server is colocated,
And instead of setting the clock manually, Shell we make that to happen automatically by syn with server
Rds
Regards.
Alain
Hi Alain,
Thanks for the guide..
Rgds
