06-08-2017 10:10 AM - edited 03-08-2019 10:54 AM
Hello ,
I have Two questions about ntp Configuration:
first :
If we wana ntp gets the information only by NTP window server, Is the configuration on Switch is Correct :
NTP window server IP : 172.20.70.5
Switch# configure terminal
Switch(config)# ntp access-group peer 20
Switch(config)# access-list 20 permit 172.20.70.5
Switch(config)# end
Switch#
Second :
Should we disable ntp on other interface for security :
Ntp disable { in all access ports }
Thank you so much for your time to respond my questions
Kind Regards,
06-08-2017 10:49 AM
The config looks correct. Also, ntp is a global command and not interface based. So, with an access list you should be fine.
06-08-2017 11:05 AM
Hi Ali!
First: Verifying your configuration, is missing that you enter the command
(config)#ntp server 172.20.70.5,
and you can see with #show clock if the time is correct.
Second: You can disable the ntp by interface with the next command.
Router#configure terminalEnter configuration commands, one per line. End with CNTL/Z. Router(config)#interfaceSerial0/1Router(config-if)#ntp disableRouter(config-if)#endRouter#
You can also prevent the router from providing NTP services on an individual interface with access control lists:
Router#configure terminalEnter configuration commands, one per line. End with CNTL/Z. Router(config)#access-list107deny udp any eq 123 any eq 123Router(config)#access-list107permit ip any anyRouter(config)#interfaceRouter(config-if)#Serial0/1ip access-group107inRouter(config-if)#endRouter#
