NTP on Nexus 6000
Hello all,
I have 2 Nexus switches and i want to configure them to use TIME.WINDOWS.COM ntp server.
I used "ntp server TIME.WINDOWS.COM" command, they accepted it but when i check the time it's wrong despite that it seems that they have synched (time is without asterisk)
Nexus-01#sh clock
11:47:39.364 UTC Thu May 3 2018
I have disabled and re-enabled feature ntp, but still nothing.
Any ideas?
Also, can you please explain me what is clock protocol none  in show run output? Is it related with my case?
Thank you
8 Replies 8
johnd2310
Level 8
Level 8
When you use dns name for ntp server, the switch will resolve the name to ip address and use the ip address. what is the output of the show ntp peer-status?
Can you switch get to TIME.WINDOWS.COM?
Have you tried another ntp server like pool.ntp.org?
John
**Please rate posts you find helpful**
Yes, it can resolve it.
I use this NTP server in other switches (3850) and i haven't any issue.
output from show ntp peer-status :
INFO: System clock is not controlled by NTP in this VDC
You can use "clock protocol <protocol> vdc <vdc_id>"
to change the current setting.
OS doesn't accept any further command after clock protocol ntp
clock protocol ntp ?
<CR>
Reza Sharifi
"clock protocol ntp" means you will be using an NTP server. So, can you try:
clock protocol ntp
and than
and test?
I have already done this but unfortunately didn't work.
ntp clear drift
reauthenticate ntp
I executed clear ntp session but nothing changed.
I took the below message
Fabric Distribution not enabled for NTP
What is the output of "sh ntp peer-status"?
Below the output from sh ntp peer-status
Total peers : 1
* - selected for sync, + - peer mode(active),
- - peer mode(passive), = - polled in client mode
remote local st poll reach delay vrf
=52.168.138.145 0.0.0.0 16 64 0 0.00000 management
