nve peer is not up
prohit
Leaf1# show nve vni
Codes: CP - Control Plane DP - Data Plane
UC - Unconfigured SA - Suppress ARP
SU - Suppress Unknown Unicast
Xconn - Crossconnect
MS-IR - Multisite Ingress Replication
HYB - Hybrid IRB mode
Interface VNI Multicast-group State Mode Type [BD/VRF] Flags
nve1 900001 n/a Up CP L3 [vxlan-900001]
nve1 2001001 239.0.0.141 Up CP L2 [1001]
nve1 2001002 239.0.0.141 Up CP L2 [1002]
Leaf1# show bgp l2vpn evpn
BGP routing table information for VRF default, address family L2VPN EVPN
BGP table version is 36, Local Router ID is 30.1.1.1
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-i
njected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - b
est2
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 30.1.1.1:4 (L3VNI 900001)
*>l[5]:[0]:[0]:[24]:[4.1.1.0]/224
100.1.1.1 0 100 32768 ?
*>l[5]:[0]:[0]:[24]:[4.2.2.0]/224
Leaf1# show nve peers
Leaf1#
Leaf1#
Leaf1#
OK @prohit
On leaf config, why interface ethernet 1/1 is not is the ospf process called UNDERLAY ?
Put all physicals interfaces in the same OSPF process as underlay control plane.
Best regards
5 Replies 5
M02@rt37
Hello @prohit,
On your leaf config I don't see interface loopback1. This is the source-interface under nve interface....
Best regards
Sorry, I forgot to mention that.
interface loopback1
  ip address 100.1.1.1/32
  ip router ospf 1 area 0.0.0.0
  ip pim sparse-mode
M02@rt37 I am following this doc: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/92x/vxlan-92x/configuration/guide/b-cisco-nexus-9000-series-nx-os-vxlan-configuration-guide-92x/b_Cisco_Nexus_9000_Series_NX-OS_VXLAN_Configuration_Guide_9x_chapter_0100.html
It does not mentions loopback1 ip config on leaf. But i have configured.
Leaf2# show nve interface
Interface: nve1, State: Up, encapsulation: VXLAN
VPC Capability: VPC-VIP-Only [not-notified]
Local Router MAC: 00c4.dd49.1b08
Host Learning Mode: Control-Plane
Source-Interface: loopback1 (primary: 100.1.1.1, secondary: 0.0.0.0)
Leaf2#
OK @prohit
Best regards
I have updated update source of nve1 interface to loopback0 and that worked.
LEAF1# show nve peers
Interface Peer-IP State LearnType Uptime Router-Mac
nve1 40.1.1.1 Up CP 00:57:27 00c4.dd49.1b08
Invalid interface format at '^' marker.
LEAF1# show int lo0
loopback0 is up
admin state is up,
Hardware: Loopback
Internet Address is 30.1.1.1/32
MTU 1500 bytes, BW 8000000 Kbit , DLY 5000 usec
Encapsulation LOOPBACK, medium is broadcast
Auto-mdix is turned off
166 packets input 16008 bytes
109 multicast frames 0 compressed
0 input errors 0 frame 0 overrun 0 fifo
57 packets output 2166 bytes 0 underruns
0 output errors 0 collisions 0 fifo
0 out_carrier_errors
LEAF1#
