nve
Johnson_Mo
Level 3
Level 3
team,
I have a setup of vxlan with NVE on Nexus switches version version 10.1(1). when I do show nve peers detail, shows nothing:
SW1:
!Command: show running-config
!Running configuration last done at: Mon Dec 18 01:00:24 2023
!Time: Mon Dec 18 02:38:58 2023
version 10.1(1) Bios:version
feature license smart
vdc switch id 1
limit-resource vlan minimum 16 maximum 4094
limit-resource vrf minimum 2 maximum 4096
limit-resource port-channel minimum 0 maximum 511
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
feature ospf
feature pim
feature vn-segment-vlan-based
feature nv overlay
username admin password 5 $5$ILPGPB$nulqEIIsleYo6zOISDu1ptLlSjNB046rHLMHSVg6Z0A
role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 0x1db084e267224c5638ffb7f2af2ed16a
priv aes-128 0x1db084e267224c5638ffb7f2af2ed16a localizedkey
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
callhome
email-contact [email protected]
destination-profile CiscoTAC-1 transport-method http
destination-profile CiscoTAC-1 index 1 http https://tools.cisco.com/its/servic
e/oddce/services/DDCEService
transport http use-vrf management
enable
ip pim rp-address 12.12.12.12 group-list 224.0.0.0/4
ip pim ssm range 232.0.0.0/8
ip pim anycast-rp 12.12.12.12 10.10.10.10
ip pim anycast-rp 12.12.12.12 20.20.20.20
vlan 1,50
vlan 50
vn-segment 5000
vrf context management
interface nve1
no shutdown
source-interface loopback0
member vni 5000 mcast-group 230.1.1.1
interface Ethernet1/1
ip address 100.1.1.1/30
ip router ospf 10 area 0.0.0.0
ip pim sparse-mode
no shutdown
interface Ethernet1/2
switchport
switchport access vlan 50
no shutdown
interface mgmt0
vrf member management
interface loopback0
ip address 10.10.10.10/32
ip pim sparse-mode
interface loopback1
ip address 12.12.12.12/32
ip pim sparse-mode
icam monitor scale
SW2:
!Running configuration last done at: Mon Dec 18 00:59:44 2023
!Time: Mon Dec 18 02:42:08 2023
vdc switch id 1
feature ospf
feature pim
feature nv overlay
username admin password 5 $5$FEHBCM$UBCIPl7tk6a8TCFs9rSbUytG2WiBe0q1JKH/sJ78/T4
role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 0x32b259cced5530f15ec066f235c96390
priv aes-128 0x32b259cced5530f15ec066f235c96390 localizedkey
callhome
enable
vlan 1,50
vlan 50
vn-segment 5000
interface nve1
no shutdown
ip address 100.1.1.2/30
no shutdown
switchport
no shutdown
interface mgmt0
interface loopback0
ip address 20.20.20.20/32
ip pim sparse-mode
interface loopback1
ip pim sparse-mode
any idea why is not NVE comingup?
thanks in advance
10 Replies 10
M02@rt37
Hello @Johnson_Mo
OSPF neighborship is OK ? Please share router ospf 10 configuration ; ensure that you have a specific router-id under ospf process on each Switch.
Best regards
NSK# show nve peers
NSK# show nve vni
share output of above
MHM
switch# show nve vni
Codes: CP - Control Plane DP - Data Plane
UC - Unconfigured switch# show ip ospf neighbors
OSPF Process ID 10 VRF default
Total number of neighbors: 1
Neighbor ID Pri State Up Time Address Interface
20.20.20.20 1 FULL/DR 12:22:54 100.1.1.2 Eth1/1
SA - Suppress ARP
SU - Suppress Unknown Unicast
Xconn - Crossconnect
MS-IR - Multisite Ingress Replication
NVEs on both sides are up and OSPF is up as well.
this is on GNS3, could it be license issue?
@Johnson_Mo
Add ip pim sparse-mode on physical interfaces Ethernet 1/1 on the 2 Switch. On SW2, I don't see it.
Best regards
added for both and nve peer still down
Ok @Johnson_Mo
Loopback 0 is used for your underlay CP ? and what about Loopback 1 ? Overlay data-plane ? It should not be the source interface of NVE interface ?
Best regards
LO1 is RP and LO0 is overlay
@Johnson_Mo
Lo0 is also used for underlay no ?
Best regards
LO0 is only to source the NVE from, so it is overlay only
switch# show nve vni <<- there is nothing appear for this command
one more note
the VXLAN use multicast for BUM but that not break the role of Multicast
shared Tree use RP
source Tree dont use RP but it can use SSM
I see here you merge two mode in one config
I prefer RP so remove the SSM from your config
and share the output of command above
MHM
