NVRAM (Not enough memory)
allkall@yandex.ru
Community Member
Hi everyone!
Cisco #1:
Код:
#dir nvram:
Directory of nvram:/
  184  -rw-        3439                    <no date>  startup-config
  185  ----        3565                    <no date>  private-config
  186  -rw-        3439                    <no date>  underlying-config
    1  ----          88                    <no date>  persistent-data
    2  -rw-           0                    <no date>  ifIndex-table
    3  -rw-         593                    <no date>  IOS-Self-Sig#1.cer
    4  -rw-         593                    <no date>  IOS-Self-Sig#2.cer
    5  -rw-         593                    <no date>  IOS-Self-Sig#3.cer
    6  -rw-        2945                    <no date>  cwmp_inventory
   14  -rw-         583                    <no date>  IOS-Self-Sig#4.cer
   18  -rw-         583                    <no date>  IOS-Self-Sig#5.cer
196600 bytes total (2152 bytes free)
NVRAM
That is only 16421 bytes are occupied, but the system says that 194448 bytes are occupied!
Cisco #2
#dir nvram:
  180  -rw-        6961                    <no date>  startup-config
  181  ----        3563                    <no date>  private-config
  182  -rw-        6961                    <no date>  underlying-config
    1  ----          82                    <no date>  persistent-data
    3  -rw-         595                    <no date>  IOS-Self-Sig#1.cer
    4  -rw-         595                    <no date>  IOS-Self-Sig#2.cer
    5  -rw-         595                    <no date>  IOS-Self-Sig#3.cer
    6  -rw-         576                    <no date>  IOS-Self-Sig#4.cer
    7  -rw-         576                    <no date>  IOS-Self-Sig#5.cer
    8  -rw-         576                    <no date>  IOS-Self-Sig#6.cer
    9  -rw-         576                    <no date>  IOS-Self-Sig#7.cer
   10  -rw-         576                    <no date>  IOS-Self-Sig#8.cer
   11  -rw-         576                    <no date>  IOS-Self-Sig#9.cer
   12  -rw-         576                    <no date>  IOS-Self-Sig#A.cer
   13  -rw-         576                    <no date>  IOS-Self-Sig#B.cer
   14  -rw-         576                    <no date>  IOS-Self-Sig#C.cer
   15  -rw-         576                    <no date>  IOS-Self-Sig#D.cer
   16  -rw-         576                    <no date>  IOS-Self-Sig#E.cer
   17  -rw-         576                    <no date>  IOS-Self-Sig#F.cer
   18  -rw-         576                    <no date>  IOS-Self-Sig#10.cer
   19  -rw-         576                    <no date>  IOS-Self-Sig#11.cer
   20  -rw-         576                    <no date>  IOS-Self-Sig#12.cer
   21  -rw-         576                    <no date>  IOS-Self-Sig#13.cer
   22  -rw-         583                    <no date>  IOS-Self-Sig#14.cer
   23  -rw-         592                    <no date>  IOS-Self-Sig#15.cer
   24  -rw-        2945                    <no date>  cwmp_inventory
   27  -rw-         793                    <no date>  hub-cnt-01#7.cer
   28  -rw-         780                    <no date>  hub-cnt-01#1CA.cer
196600 bytes total (157352 bytes free)
On this Cisco, everything is fine, that is, there is a lot of free space.
Why on Cisco #1 all memory is full?
10 Replies 10
Reza Sharifi
Do these switches run the same IOS version?
Also, is there enough space in flash?
What is the output of "dir" or "sh flash" on each switch?
Hi! Thank for reply.
Cisco #1
USS#sh ver
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 15.1(1)XB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 20-Dec-09 23:56 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH12, RELEASE SOFTWARE (fc1)
USS uptime is 4 weeks, 4 days, 4 hours, 16 minutes
System restarted at 08:08:42 VLAT Fri Mar 29 2019
System image file is "flash:c181x-adventerprisek9-mz.151-1.XB.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1812-J (MPC8500) processor (revision 0x400) with 209920K/52224K bytes of memory.
Processor board ID FHK130825QK, with hardware revision 0000
10 FastEthernet interfaces
1 ISDN Basic Rate interface
1 Virtual Private Network (VPN) Module
62720K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO1812-J/K9 FHK130825QK
USS#sh flash:
-#- --length-- -----date/time------ path
1 3278 Feb 19 2009 08:10:12 sdmconfig-1811-1812.cfg
2 931840 Feb 19 2009 08:10:30 es.tar
3 1505280 Feb 19 2009 08:10:52 common.tar
4 1038 Feb 19 2009 08:11:08 home.shtml
5 112640 Feb 19 2009 08:11:24 home.tar
7 28467800 Oct 01 2012 14:34:48 c181x-adventerprisek9-mz.151-1.XB.bin
32985088 bytes available (31035392 bytes used)
Cisco #2
NAK#sh ver
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 21:49 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH13, RELEASE SOFTWARE (fc1)
NAK uptime is 4 days, 16 hours, 38 minutes
System returned to ROM by reload at 19:49:51 VLAT Thu Apr 25 2019
System restarted at 19:50:42 VLAT Thu Apr 25 2019
System image file is "flash:c181x-adventerprisek9-mz.151-4.M3.bin"
Last reload type: Normal Reload
[email protected].
Processor board ID FHK130825LE, with hardware revision 0000
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1812-J/K9        FHK130825LE
NAK#sh flash:
1 1038 Dec 13 2010 12:36:00 +10:00 home.shtml
2 3278 Dec 13 2010 12:36:00 +10:00 sdmconfig-1811-1812.cfg
3 112640 Dec 13 2010 12:36:00 +10:00 home.tar
4 1505280 Dec 13 2010 12:36:04 +10:00 common.tar
5 6389760 Dec 13 2010 12:36:10 +10:00 sdm.tar
7 1697952 Dec 13 2010 12:36:20 +10:00 securedesktop-ios-3.1.1.45-k9.pkg
8 415956 Dec 13 2010 12:36:28 +10:00 sslclient-win-1.1.4.176.pkg
9 931840 Dec 13 2010 12:36:38 +10:00 es.tar
10 30521884 Jan 25 2013 00:58:02 +10:00 c181x-adventerprisek9-mz.151-4.M3.bin
22425600 bytes available (41594880 bytes used)
Philip D'Ath
Meraki Community All-Star
I'll take some gueses.  Perhaps one is formatted with the more "modern" FAT16/FAT32 and the other with Cisco's older original filesytsem.
My next guess is filesystem damage.  Try using fsck to fix it.
https://www.cisco.com/c/en/us/td/docs/ios/12_2/configfun/command/reference/ffun_r/frf006.html#wp1017918
I don't understand why you are talking about flash memory when it comes to NVRAM?
Does this model actually have NVRAM?  Isn't it simulated in flash?
Philip D'Ath
Why don't you try making a copy of the files that you can, formatting NVRAM and then putting them back.
Command format only applies to flash:. What then is the nvram: formatting command?
USS#sh file systems
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw archive:
- - opaque rw system:
- - opaque rw tmpsys:
- - opaque rw null:
- - network rw tftp:
- - opaque ro xmodem:
- - opaque ro ymodem:
* 64020480 32985088 disk rw flash:#
196600 2512 nvram rw nvram:
- - opaque wo syslog:
- - network rw rcp:
- - network rw pram:
- - network rw http:
- - network rw ftp:
- - network rw scp:
- - opaque ro tar:
- - network rw https:
- - opaque ro cns:
Try one of these:
erase nvram:
format nvram:
I found out that we have several devices with this problem.
I executed the command, but as you can see the free space did not increase and the files were not deleted.
test#dir nvram: Directory of nvram:/ 190 -rw- 0 <no date> startup-config 191 ---- 0 <no date> private-config 192 -rw- 0 <no date> underlying-config 1 -rw- 0 <no date> ifIndex-table 2 -rw- 2945 <no date> cwmp_inventory 8 ---- 72 <no date> persistent-data 147 -rw- 794 <no date> hub-cnt-01#2.cer 148 -rw- 780 <no date> hub-cnt-01#1CA.cer 196600 bytes total (44996 bytes free) test#erase nvram: Erasing the nvram filesystem will remove all configuration files! Continue? [confirm] [OK] Erase of nvram: complete test# .May 1 09:37:03: %SYS-7-NV_BLOCK_INIT: Initialized the geometry of nvram test#dir nvram: Directory of nvram:/ 190 -rw- 0 <no date> startup-config 191 ---- 0 <no date> private-config 192 -rw- 0 <no date> underlying-config 1 -rw- 0 <no date> ifIndex-table 2 -rw- 2945 <no date> cwmp_inventory 8 ---- 72 <no date> persistent-data 147 -rw- 794 <no date> hub-cnt-01#2.cer 148 -rw- 780 <no date> hub-cnt-01#1CA.cer 196600 bytes total (44996 bytes free) test#
