Nx 7000 NTP problem
Muhammed AKYUZ
hi,
i am not able to work ntp on Nexus. Same config works on other nexus.
NX1(config)# ntp commit
NX1(config)# 2000 Jan  1 11:13:07.117520 ntp: ntp_get_session_info: fc_ct_get_session_context failed [0x40bb0007]
2000 Jan  1 11:13:07.118988 ntp: ntp_conf_peer: Added element  1d0a0a0a to peer_list
2000 Jan  1 11:13:07.119149 ntp: ntp_conf_peer: Added element  1e0a0a0a to peer_list
2000 Jan  1 11:13:07.119278 ntp: ntp_conf_peer: Added element  1f0a0a0a to peer_list
2000 Jan  1 11:13:07.119402 ntp: ntp_conf_peer: Added element  200a0a0a to peer_list
2000 Jan  1 11:13:07.122960 ntp: ntp_conf_peer: Added element  1d0a0a0a to peer_list
2000 Jan  1 11:13:07.123061 ntp: ntp_conf_peer: Added element  1e0a0a0a to peer_list
2000 Jan  1 11:13:07.123150 ntp: ntp_conf_peer: Added element  1f0a0a0a to peer_list
2000 Jan  1 11:13:07.123240 ntp: ntp_conf_peer: Added element  200a0a0a to peer_list
NX1(config)# end
NX1# 2000 Jan  1 11:13:17 NX1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on 192.168.201.5@pts/25
NX1#
NX1# sh clock
11:13:20.422 TURKEY Sat Jan 01 2000
NX1# sh run ntp
!Command: show running-config ntp
!Time: Sat Jan  1 11:13:28 2000
version 6.0(1)
ntp distribute
ntp server 10.10.10.29 use-vrf management
ntp server 10.10.10.30 use-vrf management
ntp server 10.10.10.31 use-vrf management
ntp server 10.10.10.32 use-vrf management
ntp source-interface  mgmt0
ntp commit
NX1# sh ntp peers
NX1# 2000 Jan  1 11:15:13.125365 ntp: ntp_handle_show_peer_list: Could not get peer list, ret_val = 1077346326, num_recvd = 0
NX1# sh ntp peers ?
  <CR>
  >      Redirect it to a file
  >>     Redirect it to a file in append mode
  |      Pipe command output to filter
NX1# sh ntp peer-status
NX1# 2000 Jan  1 11:15:24.636950 ntp: ntp_handle_show_peer_summary: Could not get peer summary, ret_val = 1077346326, num_recvd = 0
What should be the problem?
24 Replies 24
Jerry Ye
You are using CFS to sync NTP time, is this what you want to do?
Also, is this configured under admin VDC or other VDC contexts?
jerry
Actually, i do not want to usee CFS. Standart NTP config is ok. But only cfs worked o other switch.
we have 4 ntp servsers. Nexus default vdc should sync from one of the servers. but it does not work. do you have any suggestion?
None CFS config should work. You can turn off CFS for NTP with the following command (from my memory):
no ntp commit
no ntp distributed
I am also assuming you can reach the NTP server via the management interface.
jerry
last config is:
NX1# ping 10.10.10.29 vrf management
PING 10.10.10.29 (10.10.10.29): 56 data bytes
64 bytes from 10.10.10.29: icmp_seq=0 ttl=126 time=1.02 ms
64 bytes from 10.10.10.29: icmp_seq=1 ttl=126 time=0.686 ms
64 bytes from 10.10.10.29: icmp_seq=2 ttl=126 time=0.638 ms
64 bytes from 10.10.10.29: icmp_seq=3 ttl=126 time=0.706 ms
64 bytes from 10.10.10.29: icmp_seq=4 ttl=126 time=0.619 ms
--- 10.10.10.29 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.619/0.733/1.02 ms
NX1# sh run ntp
!Time: Sat Jan  1 12:16:52 2000
version 6.0(1)
we have 3560 swtiches. ntp server works ok on 3560s..
Can you post the output of
show ntp status
show ntp session status
jerry
NX1# show ntp status
Distribution : Disabled
Last operational state: Commit operation failed
NX1#
NX1# show ntp session status
Last Action Time Stamp     : Sat Jan  1 12:15:27 2000
Last Action                : Clear
Last Action Result         : Fail
Last Action Failure Reason : ntp(0x40370035)- Fabric Distribution not enabled for NTP
NX1#
Sorry, asked for the wrong commands, can you post the following?
show ntp peer-status
jerry
nothing comes..
with debug:
2000 Jan  2 06:37:10.353162 ntp: ntp_process_mts_msg: Opcode received: MTS_OPC_NTP_SHOW_REQ
2000 Jan  2 06:37:10.364914 ntp: ntp_doquery: sendrequest, num attempts = 30
2000 Jan  2 06:37:10.383651 ntp: ntp_doquery: sendrequest, num attempts = 29
2000 Jan  2 06:37:10.393850 ntp: ntp_doquery: sendrequest, num attempts = 28
2000 Jan  2 06:37:10.404032 ntp: ntp_doquery: sendrequest, num attempts = 27
2000 Jan  2 06:37:10.414196 ntp: ntp_doquery: sendrequest, num attempts = 26
2000 Jan  2 06:37:10.424369 ntp: ntp_doquery: sendrequest, num attempts = 25
2000 Jan  2 06:37:10.434534 ntp: ntp_doquery: sendrequest, num attempts = 24
2000 Jan  2 06:37:10.444710 ntp: ntp_doquery: sendrequest, num attempts = 23
2000 Jan  2 06:37:10.454893 ntp: ntp_doquery: sendrequest, num attempts = 22
2000 Jan  2 06:37:10.465088 ntp: ntp_doquery: sendrequest, num attempts = 21
2000 Jan  2 06:37:10.475260 ntp: ntp_doquery: sendrequest, num attempts = 20
2000 Jan  2 06:37:10.485440 ntp: ntp_doquery: sendrequest, num attempts = 19
2000 Jan  2 06:37:10.495608 ntp: ntp_doquery: sendrequest, num attempts = 18
2000 Jan  2 06:37:10.505782 ntp: ntp_doquery: sendrequest, num attempts = 17
2000 Jan  2 06:37:10.515952 ntp: ntp_doquery: sendrequest, num attempts = 16
2000 Jan  2 06:37:10.526124 ntp: ntp_doquery: sendrequest, num attempts = 15
2000 Jan  2 06:37:10.536289 ntp: ntp_doquery: sendrequest, num attempts = 14
2000 Jan  2 06:37:10.546466 ntp: ntp_doquery: sendrequest, num attempts = 13
2000 Jan  2 06:37:10.556631 ntp: ntp_doquery: sendrequest, num attempts = 12
2000 Jan  2 06:37:10.566804 ntp: ntp_doquery: sendrequest, num attempts = 11
2000 Jan  2 06:37:10.576968 ntp: ntp_doquery: sendrequest, num attempts = 10
2000 Jan  2 06:37:10.587142 ntp: ntp_doquery: sendrequest, num attempts = 9
2000 Jan  2 06:37:10.597307 ntp: ntp_doquery: sendrequest, num attempts = 8
2000 Jan  2 06:37:10.607475 ntp: ntp_doquery: sendrequest, num attempts = 7
2000 Jan  2 06:37:10.617637 ntp: ntp_doquery: sendrequest, num attempts = 6
2000 Jan  2 06:37:10.627807 ntp: ntp_doquery: sendrequest, num attempts = 5
2000 Jan  2 06:37:10.637976 ntp: ntp_doquery: sendrequest, num attempts = 4
2000 Jan  2 06:37:10.648159 ntp: ntp_doquery: sendrequest, num attempts = 3
NX1# 2000 Jan  2 06:37:10.658325 ntp: ntp_doquery: sendrequest, num attempts = 2
2000 Jan  2 06:37:10.668506 ntp: ntp_doquery: sendrequest, num attempts = 1
2000 Jan  2 06:37:10.668603 ntp: ntp_doquery: ntp_doquery through
2000 Jan  2 06:37:10.668643 ntp: ntp_handle_show_peer_summary: Could not get peer summary, ret_val = 1077346326, num_recvd = 0
2000 Jan  2 06:37:10.668700 ntp: Sending cmi response with return_code = 0x40370016
2000 Jan  2 06:37:10.668735 ntp: setting global CMI msg req to NULL
NX1#
NX1#
Can you execute follwoing configuration on your Nexus 7K router and check.
ntp distribute
ntp server SERVER_IP
ntp commit
Sri
ntp distribute and ntp commit will enable CFS on NTP which the original poster doesn't want to use.
jerry
ntp distribute
ntp commit
i have tried that many times, it did not work.
you can try the following
clear ntp session
And check it with show ntp peer-status. If still doesn't work, remove all ntp server command and reapply them again.
NX1(config)# clear ntp session
NX1(config)# ntp server 10.10.10.29 use-vrf management
NX1(config)#
NX1(config)# do sh clock
07:34:11.014 TURKEY Sun Jan 02 2000
I am assuming this is configured in the default VDC. If yes, I would like to see the NTP configuration of the server (if it is IOS). Just want to make sure there is no ACL blocking it.
jerry
Sent from my iPhone
