NX-OS EIGRP Configuration 101
shamg1974
Hello all,
I'm getting acquainted with the Nexus 5548UP router and I realized EIGRP is not the same in NX-OS. So, I need to declare a route-map and declare EIGRP within each interface.
Here's my config (basic, I know):
IP access list All-Routes
        10 permit ip any any
route-map All-Routes, permit, sequence 10
  Match clauses:
    ip address (access-lists): All-Routes
router eigrp 90
  no eigrp log-neighbor-changes
  eigrp router-id 10.90.1.1
  redistribute static route-map All-Routes
  redistribute ospf 1 route-map All-Routes
interface Vlan99
  bandwidth 100
  ip address 172.16.1.1/24
  ip router eigrp 90
  ip passive-interface eigrp 90
Does this look okay?
Bobby Grewal
5 Replies 5
Jerry Ye
It looks fine.
jerry
Thanks Jeye.
One more question -- just to confirm....I can use just the one route-map All-Routes for all of my redistribution, correct? I won't need to create multiple ones?
Thanks again,
Bobby
You can use only one. I will prefer to use different one. Since some of them might different.
jerry
Hi jeye,
There is no need to specify a seed metric in this os?
Regards.
Alain.
Hi Cadet,
Thanks for bringing this up. Metric is no longer configure in the same string as the redistribution command. You have to configure the metric, either through the  default-metric configuration option or through a route map.
So in the above config, we need to add one more line:
router eigrp 90
default-metric 1000000 0 255 1 1500
jerry
