Ping on the router interface not working
liviu.sisu
Hi Guys,
I hope I can get support on the following issue. I have the following config on a router 1811 :
interface FastEthernet1
ip address 192.168.161.1 255.255.255.0 secondary
ip address 192.168.163.1 255.255.255.0 secondary
ip address 192.168.164.1 255.255.255.0 secondary
ip address 192.168.160.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1.1
encapsulation dot1Q 101
ip address 10.101.1.254 255.255.255.0
no snmp trap link-status
interface FastEthernet1.2
encapsulation dot1Q 102
ip address 10.102.1.254 255.255.255.0
interface FastEthernet1.3
encapsulation dot1Q 103
ip address 192.168.162.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet1.11
encapsulation dot1Q 11
ip address 10.1.1.99 255.255.255.0
interface FastEthernet1.100
encapsulation dot1Q 100
ip address 192.168.165.1 255.255.255.0
I am trying to ping fastethernet 1's one of the IP addreses, from the router itself :
Sending 5, 100-byte ICMP Echos to 192.168.160.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Debugging icmp packet does not show the packet exiting the interface even.
However, the following works :
Sending 5, 100-byte ICMP Echos to 192.168.162.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Any ideas ?
Liviu Sisu
The only stuff I see which could cause problems is the static nat you have here:
ip nat inside source static 10.11.12.30 192.168.160.1
Here is what I think is happening but we'll ahve to verify with debugs:
when you ping 192.168.160.1 it is natted to 10.11.12.30 and this destination  and in the rib it corresponds to the default route pointing to 192.168.3.3 which is out f0/0 so the router is arping for 192.168.3.3 on f0/1 and it never receives a reply so arp is incomplete and so it  fails.
Could you enable those debugs:
-logging buffered 7
-logging buffered 100000
- access-list 180 permit icmp any any
-debug ip nat detail 180
-debug ip icmp
-debug ip packet detail 180
-debug arp
Then ping 192.168.160.1 repeat 1 then show log and post output
Regards.
Alain.
cadet alain
could you post your  sanitized running-config.
Regards.
Alain.
Building configuration...
Current configuration : 3678 bytes
version 12.4
boot-start-marker
boot-end-marker
enable secret 5 $1$l55/$6a8MFoqIXv3wmuhybSgK5/
aaa new-model
aaa session-id common
resource policy
ip cef
ip domain name alvarion.com
ip ssh time-out 60
class-map match-all SiDSCP6
match access-group 131
policy-map SiDSCP6
class SiDSCP6
  set dscp 6
interface FastEthernet0
ip address 192.168.3.156 255.255.255.0
duplex auto
speed auto
interface FastEthernet0.1
duplex auto
speed auto
policy-map SiDSCP6
class SiDSCP6
  set dscp 6
duplex auto
speed auto
duplex auto
speed auto
ip nat inside
interface FastEthernet2
interface FastEthernet3
switchport access vlan 300
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan102
description Data_1
ip address 10.102.0.254 255.255.255.0
interface Vlan101
no ip address
interface Vlan11
no ip address
interface Async1
no ip address
encapsulation slip
router ospf 1
log-adjacency-changes
network 192.168.3.0 0.0.0.255 area 0
network 192.168.160.0 0.0.0.255 area 0
network 192.168.161.0 0.0.0.255 area 0
network 192.168.162.0 0.0.0.255 area 0
network 192.168.163.0 0.0.0.255 area 0
network 192.168.164.0 0.0.0.255 area 0
network 192.168.165.0 0.0.0.255 area 0
ip route 0.0.0.0 0.0.0.0 192.168.3.3
ip route 10.1.42.0 255.255.255.0 10.1.42.4
ip route 10.1.42.0 255.255.255.0 FastEthernet1
ip route 10.1.200.0 255.255.255.0 192.168.160.31
ip route 10.1.201.0 255.255.255.0 192.168.160.29
ip http server
no ip http secure-server
logging server-arp
access-list 105 permit ip any any
access-list 131 permit ip any 10.101.1.0 0.0.0.255
control-plane
banner motd ^C
webvpn context Default_context
ssl authenticate verify all
no inservice
end
-logging buffered 7
-debug ip icmp
-debug arp
Regards.
Alain.
Hi Alain,
Thanks for the prompt reply.
Since I am able to manipulate the config without any risk (this router is working in a testing lab now), I could easily remove ip nat inside source static 10.11.12.30 192.168.160.1.
Immediately after changing this I started getting replies.
This is understandable.
What I cannot understand is why the other ip addresses, defined on the interface FastEthernet1, could not also reply to ping.
Thanks anyway.,
Liviu Sisu
