Odd network performance - 2960-S - Unplug and re-plug network cable
adam.crutchley
Hi Guys,
I have a bit of an odd issue which I hoped somebody may shed some light on.
I have a 2960-S switch which is used by an engineer to build laptops; we have noticed a few issues with network performance degrading over time to the laptops once they have been connected for a while.
The switch is connected to our company LAN, when we initially connect a laptop and ping across to the build server or next hop switch the ping result is under 3ms. But after about an hour the ping rate drops to > 200ms (no building going on just the laptop sat doing nothing throughout this time).
However, if I unplug the laptops Ethernet cable and plug it back in the ping response returns to < 3ms.
This is causing issues with the laptop build process as it starts to interfere with the laptop imaging process.
The switch is running IOS - 15.2(2)E9
The laptops are Windows 10
Any thoughts would be appreciated
Adam
#2960-S
can you post the output of:
show process cpu history
sho proc cpu sorted | e 0.0
Also, there is always a chance that the laptop NICs and/or the cables you are using are causing this. Check if the behavior is consistent for all laptops, and try and change the cable (you might want to try a Category 6 or higher cable)...
Hi Georg,
Thanks for getting in touch, please find the CPU outputs below:
I have tried changing cables  (all are CAT 6), I will try a different model of laptop this weekend as we get them in batches so only have 1 model at the moment.
Rm6-Cab11#show processes cpu history
      111111111111111112222211111333331111111111111111111111111111
      555555566666999991111166666111116666666666777779999977777666
  100
   90
   80
   70
   60
   50
   40
   30                            *****
   20 **********************************************************
   10 **********************************************************
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
      321222222222222222222222222222222222222222222222222222222222
      159444455455414145525775734443559554335245555545155455588575
  100
   90
   80
   70
   60
   50
   40
   30 **     ** **     ** *****     *****   *  ***** * ** ******
   20 ##########################################################
   10 ##########################################################
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
      323333323333432334323432322333332333333233333222333234333233233333333323
      090000172000109001092069098000007003000600002999008821502800902061000892
  100
   90
   80
   70
   60
   50
   40             *    *   **                           *  **         *    *
   30 **********************************************************************
   20 ########################*##############**#############################
   10 ######################################################################
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
Rm6-Cab11#show processes cpu sorted | e 0.0
CPU utilization for five seconds: 18%/0%; one minute: 17%; five minutes: 17%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
155   188275396    38496028       4890  9.99% 11.07% 11.43%   0 Hulc LED Process
   4    15592503      877159      17776  2.79%  0.84%  0.90%   0 Check heaps
161        1077         293       3675  0.19%  0.31%  0.22%   1 SSH Process
Leo Laohoo
15.2(2)E9 is a very, very stable firmware. The place where I work has this version as a standard and we have not seen anything "funny" with this version.
Can you post the complete output to the command "sh interface <PORT> controll"?
Another thing, if it is used to build laptops, what is the Ethernet NIC make and model? What firmware version is it running on?
