Offset-lists and RIP ?
philipbarker
IOS 12.4 under router rip:
"offset-list Add or subtract offset from rip metric".
Then when I type 'offset-list 1 out ?'
I get the following <0-16> Offset.
So ..... How can you subtract from the metric using 0-16 ? Also what would be the purpose of adding or subtracting 0 ???.
Is this s/w just a bit buggy or am I missing something ?
Phil.
So I am assuming the word 'subtract' is erronous in the IOS ???
Yes. The online help is useful for additional command options. Never trust what the explanation says, consult the documentation.
__
Edison.
Edison Ortiz
Can you provide a link?
Per http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_o1g.html#wp1036466
"The offset value is added to the routing metric."
__
Edison.
Hi Edison,
Just use the '?' under router rip and you will see 'Offset-list Add or subtract offset from RIP metrics' as one of the options. If you type 'offset-list 1 in ?' at this point the IOS offers '<0-16> Offset'.
I cannot see the point in offering 0 as an option nor can I see the ability to use -ve integers. So I am assuming the word 'subtract' is erronous in the IOS ???
Phil.
__
Edison.
