OK to hot-plug modules into a C4506-E?
Willard Dennis
Tried to look on the Cisco site for this switch model, could not readily find the answer...
I have a C4506-E switch with a Sup 6L-E running cat4500e-LANBASEK9-M, Version 12.2(53)SG1, RELEASE SOFTWARE (fc1)
I just got a WS-X4648-RJ45-E module, and I need to insert it. Can I do it while the system is in operation, or will it take downtime?
Will
2 Accepted Solutions
Jon Marshall
The 4500 and 6500 were designed to be able to hot swap modules in the chassis (that's part of what you pay for).
Having said that i have done a fair few hot swaps and 99% fof them worked fine. But there is the odd one where inserting a new linecard reset the switch.
So the answer is that you should be fine to do it but if you can at least do it at a "quiet" time on your network that would be better.
Jon
manju.cisco
Level 3
Level 3
Here i found the link .......... the power supplies and line cards are plug are play
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_white_paper09186a0080103dd4.shtml
manju.cisco
Level 3
Level 3
I think it you should be able to do it........but lets wait for some more opinions
Jon Marshall
Jon
manju.cisco
Level 3
Level 3
Willard Dennis
Thanks guys. As it turns out, there was a paper manual in the module box entitled "Catalyst 4500 Series Supervisor Engines and Switching Modules Installation Note" that states:
All Catalyst 4500 series switches support hot swapping, [...]
So I just should have opened the module box first!
Thanks for the quick response though... The module has been inserted and is up and running.
