Only allow frame from neighbor switch
ycae
We have a situation where a switch needs to sit in the office space and not in a rack. However, we would like to avoid that someone connects another device on that port.
So is it possible to resrict a port on a switch to only allow frames coming from a defined neighbor switch? So that on that specific port no host can be connected, only a switch?
Thanks for your input.
Yves
I Understand that your requirement is nobody should connect his PC or switch into the switch .
If this is right, then i could think of below features:
1.you could use BPDU guard feature to protect any switch connected to you switch . As switch Generately send BPDU to all connected ports. so BPDU guard feature will shutdown that port once it received the BPDU .
2. To Protect PC to be connected on your switch .
configure switchport port-security with violation shutdown option . so if the switch receive otherthan configured mac address than interface will got to error-disable state ans also send SNMP traps.
switchport port-security mac-address 00:24:d7:16:bd:c5     ------> Non existing mac in your network
switchport port-security violation shutdown
note : Second option can protect both switch and PC .So i believe only port-security is enough
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/port_sec.html
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
VS
