2600 Routing/NAT/DHCP Problem
aducey01
I really need to get this working soon, need to test a site to site vpn for work.
I'm connecting this to a home broadband connection and it's just not working right.  It looks to be natting, jusdging from the debugging, but the internal subnets are not able to ping out to the internet.
It's not a dns issue 'cause I can't ping the numeric ip's to google or yahoo either.
The routes are in the routing table.
I can ping www.yahoo from the router cli and ping the inside hosts.
boot system flash:c2600-adventerprisek9-mz.124-25d.bin
ip dhcp pool internal-client
   network 10.22.22.0 255.255.255.0
   dns-server 66.60.130.158
   default-router 10.33.33.1
   domain-name collabrotech
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no clns route-cache
interface FastEthernet1/15
description LAN Subnet
switchport access vlan 22
spanning-tree portfast
interface Vlan1
no ip address
shutdown
no clns route-cache
interface Vlan22
ip address 10.22.22.1 255.255.255.0
no clns route-cache
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.33.33.0 0.0.0.255 log
access-list 1 permit 10.22.22.0 0.0.0.255 log
2 Accepted Solutions
hi,
clear ip nat translation * then do debug ip nat and ping 8.8.8.8 from the PC.
post the logs and  result here.
Regards.
Alain
make sure you have correct info with ipconfig/all(8.8.8.8 as dns server), verify the hosts file and make sure the dns cache is flushed with ipconfig/flushdns.
If still not working capture packets on the host and post wireshark output here.
Regards.
Alain
17 Replies 17
shamax_1983
Level 3
Level 3
Hello aducey01,
You neet to have "ip nat inside" like this on your vlan interface..
interface Vlan22
ip nat inside
no clns route-cache
Also, in your DHCP pool, your default router is wrong, it should be
default-router 10.22.22.1
Please rate this post if helpful.
Shamal
Thank you for pointing out those glaring mistakes    much appreciated.  I've corrected them and still  I'm still having the same issue though.  Still can't ping internet addresses from the lan addresses 10.22.22.0...
hi,
could you issue ipconfig/release and ipconfig/ renew from your PC?
kindly post ipconfig/ all and tracert 8.8.8.8 from your PC, show run and show ip route output from your 2600 router.
Can you get rid of the log keyword in the NAT ACL.
Regards.
Alain
Here's the show output from the host and the router
****HOST*****
show ipconfig /all
Ethernet adapter RJ45 Connection:
   Connection-specific DNS Suffix  . : collabrotech
   Description . . . . . . . . . . . : Intel(R) 82577LC Gigabit Network Connecti
on
   Physical Address. . . . . . . . . : 64-31-50-79-AC-DD
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::ac0b:1a0b:b6d:2261%10(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.22.22.2(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Thursday, January 10, 2013 6:18:25 AM
   Lease Expires . . . . . . . . . . : Friday, January 11, 2013 7:17:37 AM
   Default Gateway . . . . . . . . . : 10.22.22.1
   DHCP Server . . . . . . . . . . . : 10.22.22.1
   DHCPv6 IAID . . . . . . . . . . . : 258224464
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-DA-A2-A5-64-31-50-79-AC-DD
   DNS Servers . . . . . . . . . . . : 10.22.22.1
   Primary WINS Server . . . . . . . : 136.200.117.17
   Secondary WINS Server . . . . . . : 136.200.232.141
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter VirtualBox Host-Only Network:
C:\Users\aducey>tracert 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
  1     1 ms     1 ms     1 ms  10.22.22.1
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *
*********ROUTER****
R1#
R1#show run
Building configuration...
Current configuration : 3066 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
   dns-server 10.22.22.1
ip name-server 10.22.22.55
ip name-server 174.34.223.139
ip name-server 10.22.22.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 no clns route-cache
interface Serial0/0
 no ip address
 shutdown
 no clns route-cache
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
 no clns route-cache
interface Serial0/1
 no ip address
 shutdown
 no clns route-cache
interface FastEthernet1/0
 description DMZ Subnet
 no switchport
 ip address 10.33.33.1 255.255.255.0
 ip nat inside
 description paloalto-subnet
 switchport access vlan 33
interface FastEthernet1/2
 no clns route-cache
interface FastEthernet1/3
 no clns route-cache
interface Vlan1
 no ip address
 shutdown
 no clns route-cache
interface Vlan22
 ip nat inside
 no clns route-cache
ip forward-protocol nd
ip http server
ip nat inside source list natpool interface FastEthernet0/0 overload
ip access-list extended natpool
 permit ip 10.22.22.0 0.0.0.255 any
 permit ip 10.33.33.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
 no login
 transport input none
line vty 5 15
 no login
end
R1#
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 174.34.223.129 to network 0.0.0.0
     64.0.0.0/32 is subnetted, 1 subnets
S       64.30.98.6 [254/0] via 174.34.223.129, FastEthernet0/0
     174.34.0.0/26 is subnetted, 1 subnets
C       174.34.223.128 is directly connected, FastEthernet0/0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.22.22.0 is directly connected, Vlan22
S*   0.0.0.0/0 [1/0] via 174.34.223.129
R1#show int f0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is AmdFE, address is 000f.904d.b700 (bia 000f.904d.b700)
  Internet address is 174.34.223.139/26
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:18, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 2000 bits/sec, 3 packets/sec
     8266 packets input, 893595 bytes
     Received 5830 broadcasts, 0 runts, 0 giants, 0 throttles
     79 input errors, 0 CRC, 0 frame, 0 overrun, 79 ignored
     0 watchdog
     189473 packets output, 15145428 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
R1#show ip nat trans
R1#ping www.yahoo.com source 10.22.22.1
Translating "www.yahoo.com"...domain server (66.60.130.158) [OK]
Sending 5, 100-byte ICMP Echos to 98.138.253.109, timeout is 2 seconds:
Packet sent with a source address of 10.22.22.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 104/133/192 ms
R1#
*Apr  8 02:51:16.998: NAT: s=10.22.22.1->174.34.223.139, d=98.138.253.109 [336]
*Apr  8 02:51:17.110: NAT*: s=98.138.253.109, d=174.34.223.139->10.22.22.1 [8248]
*Apr  8 02:51:17.114: NAT: s=10.22.22.1->174.34.223.139, d=98.138.253.109 [337]
*Apr  8 02:51:17.214: NAT*: s=98.138.253.109, d=174.34.223.139->10.22.22.1 [9206]
*Apr  8 02:51:17.218: NAT: s=10.22.22.1->174.34.223.139, d=98.138.253.109 [338]
*Apr  8 02:51:17.322: NAT*: s=98.138.253.109, d=174.34.223.139->10.22.22.1 [10089]
*Apr  8 02:51:17.322: NAT: s=10.22.22.1->174.34.223.139, d=98.138.253.109 [339]
*Apr  8 02:51:17.510: NAT*: s=98.138.253.109, d=174.34.223.139->10.22.22.1 [11171]
*Apr  8 02:51:17.514: NAT: s=10.22.22.1->174.34.223.139, d=98.138.253.109 [340]
*Apr  8 02:51:17.670: NAT*: s=98.138.253.109, d=174.34.223.139->10.22.22.1 [12817]
R1#show ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
icmp 174.34.223.139:75 10.22.22.1:75      98.138.253.109:75  98.138.253.109:75
R1#
*Apr  8 02:51:43.974: %SEC-6-IPACCESSLOGDP: list natpool permitted icmp 10.22.22.1 -> 98.138.253.109 (0/0), 1 packet
R1#
*Apr  8 02:52:17.834: NAT: expiring 174.34.223.139 (10.22.22.1) icmp 75 (75)
hi,
Regards.
Alain
I clicked on correct answer accidentally...it's still not working.
I put the ACL into an accept any any state and that seems to have resolved some of this...but still not able to ping internet names.  I'm able to ping numerics though...not able to surf
*Apr  8 05:33:27.114: NAT*: s=8.8.8.8, d=174.34.223.139->10.22.22.6 [0]
*Apr  8 05:33:27.550: NAT*: s=10.22.22.5->174.34.223.139, d=81.18.85.57 [31919]
*Apr  8 05:33:27.918: NAT*: s=10.22.22.6->174.34.223.139, d=72.30.38.140 [0]
*Apr  8 05:33:27.986: NAT*: s=74.125.129.189, d=174.34.223.139->10.22.22.3 [792]
*Apr  8 05:33:27.986: NAT*: s=10.22.22.3->174.34.223.139, d=74.125.129.189 [48207]
*Apr  8 05:33:28.030: NAT*: s=72.30.38.140, d=174.34.223.139->10.22.22.6 [19845]
*Apr  8 05:33:28.066: NAT*: s=10.22.22.6->174.34.223.139, d=8.8.8.8 [0]
*Apr  8 05:33:28.110: NAT*: s=8.8.8.8, d=174.34.223.139->10.22.22.6 [0]
*Apr  8 05:33:28.222: NAT*: s=10.22.22.3->174.34.223.139, d=74.125.224.79 [15436]
*Apr  8 05:33:28.270: NAT*: s=74.125.224.79, d=174.34.223.139->10.22.22.3 [34754]
*Apr  8 05:33:28.270: NAT*: s=10.22.22.3->174.34.223.139, d=74.125.224.79 [15437]
*Apr  8 05:33:28.922: NAT*: s=10.22.22.6->174.34.223.139, d=72.30.38.140 [0]
*Apr  8 05:33:28.954: NAT*: s=72.30.38.140, d=174.34.223.139->10.22.22.6 [26890]
*Apr  8 05:33:29.070: NAT*: s=10.22.22.6->174.34.223.139, d=8.8.8.8 [0]
*Apr  8 05:33:29.114: NAT*: s=8.8.8.8, d=174.34.223.139->10.22.22.6 [0]
*Apr  8 05:33:29.330: NAT*: s=10.22.22.5->174.34.223.139, d=81.18.85.57 [31920]
*Apr  8 05:33:29.718: NAT*: s=74.125.129.189, d=174.34.223.139->10.22.22.3 [57167
change your dns server in the dhcp pool to the one from the provider( or 8.8.8.8) instead of the router IP.
Regards.
Alain
I did that already
   import all
   dns-server 8.8.8.8
still didn't work
hi,
did you release/renew the iP on the PC and flush the dns cache( ipconfig/flushdns) ?
Regards.
Alain
Is there a way do dynamically get dns from the isp?
I thought the import all statement in the client dhcp pool would do that.
Should I have dns relay set up some how?
flushed the routes and nat an renewed dhcp
still not working..
Regards.
Alain
I'll have to look in to how to do that on a linux host as that's what I was pinging from.  using RIP as a routing process and rebooting the isp gear worked with this.  Thanks so much for you help!
