Only seeing broadcast traffic on cisco 3750 monitoring port
CiscoNewbie8878
I am not a network engineer but I am the one stuck trying to get the port monitoring to work.
I have a switch with three regular ports and one monitoring port
port 1 is in vlan 100 and in connected to an external switch.  There is an ACL for incoming traffic applied to this port
port 2 is in vlan 200 and is connected to a laptop for access to the network
port 3 is a server in vlan 200
port 12 is the monitoring port connected to a laptop with wireshark installed
port 12 is a trunk port foir vlan 1,100, 200
for security reasons all IPs were removed from vlan 1   (not sure if this is causing the problem)
monitor session 1 source vlan 100, 200
monitor session 1 destination interface gigabitethernet 1/0/12
28 Replies 28
balaji.bandi
can you post running config  as below :
show run interface gigabitethernet 1/0/12
show monitor session
BB
#show run interface gigabitethernet 1/0/12
Interface GigabitEthernet1/0/12
  switchport trunk encapulation dot1q
  switchport trunk allowed 1,100,200
  switchport mode trunk
  switchport nonegotiate
end
#show monitor session 1
Type local session
Source VLANs     :
   both                 : 100,200
Destination Ports : Gi1/0/12
Encapsulation     : Native
      ingress         : Disabled
Do below steps :  ( assuming that Interface GigabitEthernet1/0/12 is connected to Laptop running wire-shark as per your earlier post)
config t
default Interface GigabitEthernet1/0/12
end
Post the below output :
show run Interface GigabitEthernet1/0/12
show Interface GigabitEthernet1/0/12
BB
I wonder if it would make any difference if you did the port monitor source as a single vlan instead of as 2 vlans?
I would also suggest trying the monitor session specifying the individual ports rather than specifying the vlans?
Rick
Rick
okay I set the monitoring port interface to the defaults and right now I'm just trying to monitor vlan 200.  I have a tcping session running on my client laptop (port 2) and wireshark on the monitoring port (port 12).  Still not seeing any TCP traffic being monitored
show run int gigabitethernet 1/0/12
interface GigabitEthernet1/0/12
end
Type                 : local session
source VLANs   :
      both            : 200
destination        : Gi1/0/12
   ingress           : Disabled
show int status:
Gi1/0/1 connected 100
Gi1/0/2 connected 200
Gi1/0/3 connected 200
Gi1/0/12 monitoring 1
If the device connected to Port gi 1/0/12 with Wireshark running you should able to see the traffic from VLAN 200.
what is the configruation of the PC/Laptop connected to port 1/0/12 ? do you configured any IP ?
BB
No ip address configured for the monitoring laptop
ipconfig just shows the bogus 169.254.x.x address
The  windows network configuration for the local Area Connection:
Unchecked                 Client for Microsoft Networks
Unchecked                 QoS Packet Scheduler
Unchecked                  File and Print Sharing
Unchecked                  IPv6
Checked                      IPv4 (use DHCP is selected)
Checked                      Topology Discover Mapper I/O Driver
Checked                     Topology Discover responder
MISC setting on the switch.  I don't know if any of these are preventing the monitoring of TCP traffic...
no service pad
service tcp-keepalives-in
no aaa new-model
switch 1 provision ws-3750
system mtu routing 1500
no ip source-route
ip routing
some crypto stuff...
crypto pki trustpoint
spanning-tree mode pvst
spanning-tree extend system.id
ip tcp synwait-time 10
some ntp setting
here is good example and tested working one for reference :
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-switches/940-cisco-switches-span-monitoring.html
BB
I tried monitoring just port 1, just port 2 and port 1-2.  Still no luck.
both Gi1/0/1
       Gi1/0/12
both Gi1/0/2
       Gi1/0/12
both Gi1/0/1-2
       Gi1/0/12
Just wondering, what are the devices connected to switch,.
What is the configuration of PC, can you post ethernet config screen shot and wireshart output to see what you getting.
since we can visualise what you see on your PC.
or upload Pcap file to ticket.
BB
Thank you for trying monitoring individual ports. If Gig1/0/12 is the span monitoring port then no regular network traffic would be sent to it and there would be no point in trying to monitor it.
What about trying to monitor just Gig1/0/1?
And one other question. Gig1/0/12 is the monitoring port. Is that the port where the monitoring PC is connected?
Rick
Rick
I have tried just monitoring port 1/0/1 and yes the monitoring laptop is connected to port 1/0/12.  I have configured the switch as best as I can and am leaving it to more experienced networking people here to figure out if it is working or not.  If I find out what the issue is I will update this post.
Thanks for the update. Would you post the output of show monitor session 1
Rick
Rick
