Openflow on 9200L
LXIC
I want to undertake a project that involves setting up an SDN network via OpenFlow using Cisco Catalyst 9200L switches. I saw on forums three years ago that OpenFlow support starts from the 9300 series. Is this still the case? Are there any workarounds, or should I consider using newer switches?
Thanks in advance, and sorry if this topic has already been posted or if it's not in the right place.
marce1000
                 >...that OpenFlow support starts from the 9300 series. Is this still the case?
   - It looks like it is ; from https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/1710/b_1710_programmability_cg/m_1710_new_changed_cg.html
OpenFlow
Cisco IOS XE Fuji 16.9.1
  • Cisco Catalyst 9300 Series Switches
  • Cisco Catalyst 9400 Series Switches
  • Cisco Catalyst 9500 Series Switches and Cisco Catalyst 9500-High Performance Series Switches
marce1000
OpenFlow
balaji.bandi
as per i know still the same case, Cat 9200 still don't have support- only Cat 9300 upwards have support.
BB
M02@rt37
Hello @LXIC
It is still the case as concerned OpenFlow and C9000 series:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/217210-understand-openflow-on-catalyst-9000-ser.html
While OpenFlow is a widely used SDN protocol, there are other SDN solutions and protocols available. Cisco provides its own SDN solutions, such as ACI or Cisco Software-Defined Access called "SD-Access". SD-Access solution supports C9200 platform.
Best regards
