Openflow Plugin on Catalyst 3850
acalabrigo
Community Member
I'm running the Cisco Plugin for Openflow 2.0.4 on Catalyst 3850 switches and have encountered an issue. Flow rules containing the mod_vlan_vid action do not function correctly. The switch does not send an error to the controller, but the flow rules never match packets and do not expire despite the idle timeout being set. Has anyone encountered this issue before?
Josh Harmacinski
Frequent Visitor
Frequent Visitor
How did you get the open-flow ova to install? I keep reading your supposed to use the virtual-service install command in enable mode, but my switch doesn't have it. I'm trying to figure out what I'm missing.
Running code 16.8.1a right now.
