TACACS enable problem
tedauction
Level 5
Level 5
Hello, I have TACACs login authentication configured on my 2960 running 12.2(44)SE5.
The problem is that when I break my connection to the TACACs server (for testing failover local login) I keep on getting prompted with the following:
Switch>enable
% Error in authentication.
How do I remove the need for an enable password.
p.s I know I can do it by entering 'privilege level 15' on the line con, but I don't want to do this as some of my users should not have such a high privilege level.
Here is my current config:
Current configuration : 2096 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
username myUser privilege 15 password 0 abc123
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login CONSOLE local
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization exec default local if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport trunk allowed vlan 57
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan57
ip address 10.100.7.57 255.255.255.0
no ip route-cache
ip default-gateway 10.100.7.1
ip http server
ip tacacs source-interface Vlan57
tacacs-server host 10.21.250.212
tacacs-server timeout 10
tacacs-server directed-request
tacacs-server key [email protected]:`%aZP3~nV
control-plane
line con 0
login authentication CONSOLE
line vty 5 15
end
5 Replies 5
johnd2310
Level 11
Level 11
Are you doing the test from the console or telnet/ssh?
John
**Please rate posts you find helpful**
I am running the test from the console.
In your config have you configured enable secret or enable password?
John
No I do not any enable password configured.
You need to configure enable secret.
John
