Opening Port on Router
mahesh18
Level 6
Level 6
                   Hi Everyone,
I need to open Port  3389 on my router to have RDP  to PC.
Need to know how can i open it.
Router is doing NAT and connected to ISP.
Also Router has connection to Layer 3 switches and PC is connected to one of those L3 switch.
Mahesh
2 Accepted Solutions
Reza Sharifi
Hi Mahesh,
Try something link this:
access-list 100 permit tcp any eq 3389
ip nat inside source static tcp xx.x.x.x 3389 interface gigabitEthernet x/x
Hi Mahesh,
so XXXX  will be the IP  of PC  right?
correct
gigabitEthernet x/x  which interface is this ? switch port connected to  PC
this is the interface that is connected to the ISP (outside interface)
5 Replies 5
Reza Sharifi
Hi Mahesh,
Hi Reza,
Mahesh
Hi Mahesh,
correct
Hi Reza,
Many thanks i will give it try today.
Here too much snow in calgary these days.
Mahesh
Good Luck Mahesh!!
Keep warm
Reza
