100 M copper, on a ME 3600X-24FS ?
dheinen
Perhaps someone has this in operation?
So far, I have not been able to find a definitive answer,  just speculation.
ME3600X-24FS switch (all SFP ports).
Is there a way to get 10/100 BaseT copper, using a CLC-T  or a SFP-GE-T ?
(or even just 100 copper).
Thank You !
Dean Heinen
Arumugam Muthaiah
Hi Dean,
Yes, you can use both these SFP on ME 3600 switch, please see the detail below,
Cisco ME 3600X-24FS (fiber) with 24 Gigabit Ethernet SFP ports and two 10 Gigabit Ethernet SFP+ ports
SFP-GE-T= 1000BASE-T SFP transceiver module for Category 5 copper wire, extended operating temperature range, RJ-45 connector
SFP-GE-T is Cisco fiber optic transceiver that works with 1000Base-T. SFP-GE-T is with extended working temperature and it is with DOM support.  SFP-GE-T is small form transceiver with RJ45 connector interface and it is with spring latch for high density applications, SFP-GE-T is low power dissipation and it is hot pluggable.
Minimum Software Release Required for SFP-GE-T (10/100/1000)
DOM Support: 12.2(52)EY
Cisco IOS Release: 12.2(52)EY
GLC-T is 1000Base SFP fiber optic transceiver module via Category 5 copper line, Cisco GLC-T fiber transceiver provide 1Gbps data transfer and it provides full-duplex Gigabit Ethernet connectivity to high-end workstations and between wiring closets over existing copper network infrastructure
Minimum Software Release Required for GLC-T (10/100/1000)
Refer:
Cisco ME 3600X Series Ethernet Access Switches
http://www.cisco.com/en/US/prod/collateral/switches/ps6568/ps10956/data_sheet_c78-601946.html
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Arumugam Muthaiah
Hi Dean,
Refer:
Aru
Aru,
Thanks for the clarification and information !
Dean Heinen
