OSI and TCP/IP model
rivanfrank
I made a table for OSI model and TCP/IP model and diffrent protocols. If you have any additions, comments feel free to reply. There are a lot of protocols out there and these are only few and I want to separate each protocol to its correct layers.
Any addition or comments will be much appreciated.
Thanks.
5 Replies 5
InayathUlla Sharieff
Hi Rivan,
The listed protocols sounds good to me. If you want complete list of protocols which runs on each layer then click on the below links for each layer.
Protocols run on Session layer:
http://en.wikipedia.org/wiki/Application_layer
http://en.wikipedia.org/wiki/Session_layer
http://en.wikipedia.org/wiki/Presentation_layer
http://en.wikipedia.org/wiki/Transport_layer
http://en.wikipedia.org/wiki/Network_layer
http://en.wikipedia.org/wiki/Datalink_layer
http://en.wikipedia.org/wiki/Physical_layer
Inayath
*Plz rate the usefull posts and close the thread if no further info is needed.
That's why i made this table because some of the protocols in wikipedia are misleading like for example the "ethernet" both can be found in physical and data link layer.
blau grana
Level 7
Level 7
http://www.netsky.org/ipl.jpg
http://www.protocols.com/pbook/tcpip1.htm
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
You can check the following link for more detail about OSI model and protocol stak which works on different layer.
http://en.wikipedia.org/wiki/OSI_model
lyushaoli
Hi Rivan,
I have this problem too. Some of the protocols in wikipedia are confusion. On the one hand, ARP deals with MAC address, which are part of layer 2. On the other hand, ARP deals with IP address, which are part of layer 3. The TCP/IP layer model offers an answer: layer 2 is a network interface layer between IP and hardware. ARP fits nicely into the definition because it provides the address interface function.
Best Regards,
Shao-Li
