osi layer.
ilnaiduccna
Hi folks,
Can any body give full clear info about below question.
1. In which layer of the OSI mode error detection & correction will happen?
2. What about the CIDR?
3. What will VLSM do?
Naidu.
Danilo Dy
1. Layer 2
- Check this nice OSI from WildPackets http://www.telematica.gr/Product/Cat/pdf/osi.pdf
2. What is your question about CIDR (Classless Inter-Domain Routing)?
3. Check this link for VLSM and CIDR http://www.cisco.com/warp/public/701/3.html
Dandy
Hi Dandy,
Thanks you for your help.
1. Layer 2 is it Datalink Layaer only.
2. yes I want info about CIDR only like how it will work and use of it.
Naidu.
1.Error detection is done at Layer2.Error correction may ge done at this layer.Howerver it is the resoponsiblity of the layer4 to do error correction.
Please take a look at the following links:
http://en.wikipedia.org/wiki/Transport_layer
http://en.wikipedia.org/wiki/Data_link_layer
2.Classless interdomain routing, is the standard based interpretation of the ip address in the form A.B.C.D/n where n=number of bits in the network portion of the address.
For more details please check the following link
http://en.wikipedia.org/wiki/CIDR
HTH,
Amit
